« 1 2 (3)
#21 Re: CA18DET_MAN
shaun Posted on: 2005/11/20 10:36
i can definetly recommend andrews crossmember
i have nothing againest maddat but andrews x-member is by far cheaper and is still very professional
top bloke too great to do business with
#22 Re: CA18DET_MAN
reallyuted Posted on: 2005/11/21 12:14
cheers guys but i scored 1 cheap from someone close by but helped big time when my mates 180 sx blew a hose 5 mins from his house i am truely in debt a carton of cold beers!!
#23 Re: CA18DET_MAN
shadow Posted on: 2005/11/21 13:48
hi there. Just some advice on how you completed your conversion would be great. I have ca18det engine, gearbox, crossmembers and radiator. I have been told that with these, the radiator wont fit, and the gear shift sits too far back with the ca18det gearbox. Is this correct?
#24 Re: CA18DET_MAN
converted Posted on: 2005/11/21 16:40
dunno just whack it in and tell us??
#25 Re: CA18DET_MAN
converted Posted on: 2005/11/21 16:47
#26 Re: CA18DET_MAN
flyby Posted on: 2005/11/22 0:51
Do a search dude, all your answers are here.
#27 Re: CA18DET_MAN
DON_1200 Posted on: 2005/11/22 3:29
hi all!!
i am about half way through my ca18det into 1200 ute conversion. i have used the crossmember for the engine and box from maddat. i also bought a hydraulic clutch kit and brake cable from them. so far so good..
i havnt fitted the gearbox just yet but am ready to do so. i went with the skyline 5 speed stumpy as i was told that there is no mods needed at all to fit it into the original tunnel and the shifter also lines up with the hole. i beleive this bearbox would have to be the way to go. although you will be paying for a second box, you can sell the ca box and you will be saving time and money in the tunnel work.
cheers guys, adam.
#28 Re: CA18DET_MAN
short_coupe Posted on: 2005/11/26 0:10
the radiator should fit, to make the conversion easier you should fit an auto tunnel to your car. can i post piccy;s somewhere here to show you where the shifter comes out through the floor? on my 1200 coupe
Heath
« 1 2 (3)
