Datsun 1000 Disk brakes!!
Just curious as to what others have done in regarding 1000 front disk brake conversions?
Posted on: 2002/10/24 7:32
Re: Datsun 1000 Disk brakes!!
From Perth, West Aussie
I don't know if you've seen this article but it was written by dattoman, a listmember here.
http://datnet.org/new/techinfo/1000brakeupgrade.shtml
so you have a 1000 yourself phunkdocta? I am going to do the said conversion on my 1000 just as soon as its over the pits. you can check out my messy website on my www thing on this post.
Posted on: 2002/10/24 9:39
Thanks for the info I shall check it out!
Yeah I've got a VB10 1000 wagon!
For my front brakes I used XD Falcon : disks, calipers, stub axles and top and bottom ball joints! it was straight forward to fit the ford ball joints ( just a bit of dye grinding and re-drilling). The stub axles were the same length from ball joint to ball joint and the steering arm is in the right position. the only thing required was the ford tierod holes were to big so I am welding them up and having them re-drilled to take the 1000 tierod from the bottom ( this will make sure the steering arm is in the correct position and bump steer will be eliminated )
One other thing that was required was the part of the cross member that mounts the bump stop was cut off and the bump stop repositoned on the old crossmember bolt.
( the ends of the cross member were reworked to provide strength for the parts that were removed )( the crossmember was cut to provide clearance for the brakes when turning)
This brake conversion altered the front wheel offset and requires 15" wheels
( I had 14" wheels remade to the correct offset but they hit the calipers because of this offset! so I just put the 15"s)
So that I have 4 the same wheels, I fitted a narrowed XD diff to the 1000.
The master cylinder is a 1200 twin cylinder and I fitted a remote booster under the dash!
These brakes might sound like a lot of work but atleast they willn't have to be upgraded again!
Now I just have to finish the rest of the car!
When I get around to it that is!
Posted on: 2002/10/24 10:53
From Perth
Yeah that is my 1000 front end on Datnet.
Embarassing really as I'm not 100% happy with the conversions. It works great it just looks alittle bodgy.
I'm working on making it better when I get time.....which isn't very often mind you.
Hard to belive there are so many 1000 nuts out there.
I thought I was the only one in need of therapy.
Posted on: 2002/10/24 11:35
The first attempt is always about nutting out all the fidilly problems!
And easy there! Us need therapy no! I think all these 1200 freaks do though! lol!
Dude I'm from the old school with the dudes that built Wanyes 1000 coupe in your pic ( They only built the turbo engine and set it up though! none of the other weird #### like the wheels was their work!)
Posted on: 2002/10/24 12:08
I would prefer to go for the smaller discs anyway, as have decided the 13x6 superlites are the best look for my car. I bet your wagon now pulls up on a 10c piece phunkdocta! (p.s. what you got under the hood?)
Posted on: 2002/10/24 12:13
don't know if it stops! haven't had it on the road yet!
A15 custom fuel injection and a T3 turbo off VG20
Posted on: 2002/10/24 12:27
Sorry Phunk, I just found this link!
You are truly mad
I think Ill pay the 440 for the nissan balljoints and keep my pissy sigma diskbrake front, lol.
Posted on: 2003/3/4 3:04
From Melbourne. Vic
check out my web site
www.cm510.com/datto1000
i run series V rx7 callipers and rotors on 13" rims.
have a look and let me know what you think??
Cheers
Stevo
Posted on: 2003/3/5 14:46
Stevo if anyone looked and perved at my girl as much as perved at your car I would have killed them
Yes you know I love your brakes but how the hell did they fit those things on???
Posted on: 2003/3/6 13:40
