WANTED: A series Auto Transmission
That's right folks Dattogal is in the market for a datto.
But I only drive auto, so if anyone has their auto box just sitting around it's MUCH WANTED
DG xx
Posted on: 2005/12/19 7:35
It Does What?!!
Gone over to the Dark Side...
Traded my Mustard 1200 coupe with "nissan fully automatic" a15
Intermittent wipers, air con, remote central locking and fully sick stereo for a:
"Family Car"
Mrs 1200rallycar
Re: WANTED: A series Auto Transmission
From Brisbane, Australia
Learn to drive a stick shift, much easier than swapping 'boxes.
Saves weight
Reduces driveline loss
Makes the car more responsive.
Sorry, I can't see any use for an auto . . .
PS A15s have heavy flywheels, good for learning in.
Posted on: 2005/12/19 22:19
From sydney
ive got 1 just been recoed with convertor $50 and its all yours
Posted on: 2005/12/19 23:04
Don't encourage her!
Posted on: 2005/12/19 23:57
From Sydney
I've got a pedal box.
Posted on: 2005/12/20 1:48
From Quairading, Western Australia
Hey Dattogirl learning to drive a manual is easy!
I sorta learnt how to drive a manual (XD ute with 3 on the tree... that had/has I still have it but it doesn't go (it's in the needing stage - it needs a rebuild ) a bent steering column - the gears were all over the place!
but because of the bent column I never got to learn how to downshift....
I then got "The Defect" a March '77 120Y 4 door sedan that was an auto... about 4-6 months ago it got a manual conversion and I have NEVER looked back!
Posted on: 2005/12/20 2:11
From Victoria
Damm just gave one away.
Posted on: 2005/12/20 4:15
Pay no attention to these single minded stick shift hero's DG, they just love the feel of their knob in their hand. If you want an auto, then go for it.
The Jatco trans that was used in our favorite small Datsuns is a fairly basic design, as auto trans go, but they are sturdy & reliable. With an A15 engine that's built for torque, in near-to-standard trim, you will be pleasantly surprised just how smooth & strong your little Datsun can be, & lets face it, a smooth & strong performing car is always a joy to drive.
My son's 1200 coupe is an auto & I was beginning to think, how hard would it be to use one in my 1000, but the project is too far along to change now. With a stock 1200 engine my son's coupe is a bit on the slow side, but a strong torquey A15 would transform it.
Make sure that the internals of the trans are all correctly adjusted by having it serviced at a Datsun friendly auto trans specialist. Nothing worse than a sloppy trans.
You go girl,... automaticly.
Posted on: 2005/12/20 10:53
Love your Datsun.
Treat it well.
Quite a regular
From Adelaide, Australia
I've got one. Got all the goods you need for an Auto conversion. Pedal box and the lot included, you'll need a tailshaft tho, but I'll swap you for your manual gear.
This auto is fresh out of a B310 and is in perfect condition. Let me know, I'm in Adelaide.
Posted on: 2005/12/21 14:14
Thats a good deal.
JUst remeber that teh 1200 auto from 74 or 75 onwards is the same as many fitted to other jap cars like mazda rx7 even.
If you do a search of the model no on the net youll be surprised at how many other cars have them. You could also use the upgrade model with the 4 speed but youll need mikes talent in electrics to hook up the electric overdrive setup which doesnt run off a computer as I originally thought.
Even my old 4 speed auto liteace had a carb and 4 speed overdrive.
Posted on: 2005/12/28 3:58
