« 1 2 3 4 (5) 6 »
Re: A series Ford CFI bolt on!!
Hi All first post
Yes I'm a Ford boy but I love datto/nissan engines which is why I'm dropping a VG30-DET in to my capri.
The Fuel Pressure Reg (FPR) is there to keep a consistant pressure DIFFERENCE between the injectors and manifold of usually 40 or 45 psi. The reason for this is so that when the computer opens the injectors for a set amount of time the same volume of petrol flows out irrespective of inlet manifold pressure.
If there was no FPR when an injector was opened for 1 second the amount of fuel delivered would be different. Ie crusing at high vacuume 1 sec would deliver more fuel than 1 sec at WOT.
I'm about to turbo my escort van and I want to EFI it on the cheap so I'm looking at the CFI setup, hopefully will get one in this weeked.... any links to any other CFI setups?
Here's the last engine I built http://www.retrotech.co.nz/pinto2.html
186 Rear wheel HP out of a Ford 2L EFI'ed, ported and turbo'ed
Posted on: 2006/1/12 22:51
Sorry double post
Posted on: 2006/1/12 23:55
Well its seems it is the the way to go for a budget setup using the standard hitachi manifold. However it seems it will have to be a turbo setup unless someone out there has made one work on a 4 cyl NA?
Nice work on your capri, very clean and well sorted with some ingenious solutions and a great mid range spike to say the least!.
I would definately consider a 2.2 L series with the same setup you could almost double the rwhp with them and rods and cranks are forged from factory.
You might also be interested in this....
http://ozdat.com/forum/viewtopic.php?t=3817
But in reality I would consider a ka24de they have 2.4liters which can be taken safely for boost out to 2.6 liters or stroked with a diesel crank to 3.1 liters, using L20 or z22 rods and factory standard 36mm inlet valves.
400wrhp should be a problem. I can get the ka24de with 48,000 on the clock for 450au from a local wreckers in Melbourne.
If you had your heart on a v6 the VQ2.5de is supposed to be a lighter and better beast.
Posted on: 2006/1/13 0:08
The TB wont care if it's turbo or not all it's doing is adding fuel for NA it will just add less fuel.
That's my friend Jon's capri. We got the bottom end done by a friend who's an engine reconditioner, he also did the valve guides and seats but I ported it, built the head and we installed and tuned it on the road before the dyno session. The spkie is because the exhaust is too small (2.25 inch) and chocking the topend power...
Here's the link to my capri http://www.retrotech.co.nz/rides/mk1capri/capri/capri.htm we have recently moved servers and just about all my pics and pages got lost so I have to upload them again...
You can see the dyno run of the supercharger setup I did and a pic tho...
I've already mounted the VG30-DET and box in my capri got the intercooler in and with the turbo and injector upgrade it should be an easy 400 HP
Posted on: 2006/1/13 0:46
From Ipswich,QLD
Having a brief read on what people have written it all sounds people have gotten onto a good thing, Ive asked a mate of mine who is pretty cluey on this subject about the wiring of the computer .He said theres two triggers One is a crank angle sensor which focused on the rpm and the engine timing the other trigger can be found in the dizzy and fires the injector ...By wiring these two together and running them to the coil in theory it should work
Please someone tell me if im wrong .
It would be good to get a wiring diagram going ........
Posted on: 2006/1/13 9:29
From Newscastle, Australia
When I was researching EFI for my new driveline, I spoke to Jeff Taylor. At that time I was going down the A12turbo route. He mentioned the camira injection (delco) which like the Pulsar one is programmable. It also is designed for 4 cyl and uses ign as trigger. It is reasonably crude but the difference is not peak power...carbs can still outperfrom EFI for that, but drivability (especially out of corners) is what you want. he also mentioned the Magna throttle body for fuelling. All very cheap and will give good results. as it is closed loop ie lamba feedback it will be easy to tune and keep tuned. Keep us posted with your progess....
Posted on: 2006/1/13 9:47
Dont die wondering.....
From Melbourne, Australia
well i just spent 20mins writing a reply and it logged me off during that so when i tried to post it i lost it all......................shiat
anyway cost me $300 a go to tune it, and thats not finely tuned for optimum, many places can do it, but it's hard to find out who exactly
think about :
fuel pump
fuel pressure regulator
fuel line upgrade
fuel return lines-where to?
surge tank??? maybe not needed
throttle cable
injector clean
air cleaner, i guess whatevers on the falcon
new O2 sensor ($60-70) cause you cant get second hand ones out
i used the camira dizzy module on a factory a-series electronic dizzy (weld up the mechanical advance), that works perfectly
i also adapted the camira water temp sensor and O2 sensor onto my car
the camira computer is a good thing, only thing is getting re-tuned after making changes, like i found an air leak in my inlet o needed to re-tune it (it was leaking when it was tuned) and now i want to upgrade my exhaust i need to get it re-tuned for the exhaust. at $300 a go that means after the exhaust i will likely have spent $900 on tuning
edit: i still agree with my original coment that if you are going to bother seting up everything you need for injection you may aswell go that little extra and make or have made an inlet manifold for 4 direct injectors. as the cost wont differ greatly, your still buying all the expensive stuff already
Posted on: 2006/1/13 11:12
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Ipswich,QLD
Hey 1200 rally car have you thought of microtech fuel only computer the computer loom and hand set can be brought for around the 1000 dollar mark new would save you heaps of money and you can learn to tune it yourself speak to craig at dyson rotary he has explained a fair bit to me about them you can download the tunning program from the microtech web site for a look ...
Posted on: 2006/1/13 11:51
From Ipswich,QLD
Ok with some more study ive found that in
the ford computer can only be tuned by ford the board uses a bios type system and ford only have settng avilable for them which are near impossible to get .the delco 808 can be wired up to the tbi injetion or mpfi systems.kalmaker sel the tuning program for the delco this is an expensive way to go .....for a cheep fuel only computer id suggest using some of the early microtech screw type computers the were set up to run two or three injector
some of them will handle turbo apps .with an option of being able to disable injectors too ,Or has anyone here tried the mega squirt system basically a computer you build yourself some of the people on the ford forums are using them but seem to spend a fair bit of time tuning it to get it to run which id say you would have to any way ..If we got a few going people could send there tune settings to each other and compare notes ...another thing talked about on the ford forum was the performace between the two types of injection was the mpfi had more torque down low and was better on a cold stars then the tbi and about 10 hp increase .............Try DIYAutoTune.com they are selling the megasquirt systems already assembled they seem fairly priced with a good site full of info on the megasquirt systems...........
EDit > also found www.msefi.com a big help the more i read the better the system seems
Posted on: 2006/1/15 6:50
120fly: Nope, way more complicated than winding 2 wires together and sticking them to the coil. The Dizzy probably controls the timing optically or magneticly so it would need an ignitor to fire the coil, then there's dwell to take in to account as well. some older dizzys control this with the disk/wheel but most do it in the ECU/Igniton module.
FYI an Ignitor is just like a relay, the computer fires the ignitor the ignitor fires the coil (some control dwell). This way the computer doesn't have to flow the coil current.
1200rallycar:
You have a really good point about going MPI insted of TBI(CFI) and I agree completly. If anyone is injecting their Toy car the TBI will restrict power so it will end up coming off and being replaced with MPI.
My reasons for going down this path is that this is just my daily driver and I'm only aiming for 100ish HP out of my esky, with the turbo and injection which should be easy. It looks like the CFI will be a close fit to my webber manifold.
I have 2 programmable ECU's to choose from, fuel pump, FPR etc so all I need is some EFI hose.
It suks when you loose 20mins of posting so just before I hit post I select all the txt and copy it. This way if it does bomb I can just paste it back in
Posted on: 2006/1/15 21:37
« 1 2 3 4 (5) 6 »
