« 1 (2)
Re: My car needs a diet....lets here some wieghts
From Perth
I was of the opinion that the 1200 coupe which won the IPRA nationals in 2005 weighed in uder 850kg WITH DRIVER. So I would guess around 770kg without driver.
And he is running an SR20Turbo.
Posted on: 2006/1/19 11:22
From Gold Coast
Rallytwit wrote:
OK Sunday I went ot our tech day and wiegh in. The car and been scales in a few years and I wnated to check corner wieghts. So first: the cross wieght is off by 54lbs , no biggie there. But holy cow my car weighs 1764........could be the all the street gear, passenger seat and added bracing I put on in anticipation of some tarmac rally. The car gained 90lbs and I've ballooned out to a 146lbs (nearly 30lbs in 20 years).
Man no wonder why the 85HP wonder doesn't roar dwon straights.......OK so who else is driving a blimp??
Adam's 1200 Coupe has a 1500 ute diff which weighs about 9kg heavier than the stock alloy diff, a fairly hefty cage and a Toyota T50 gearbox which weighs 13kg heavier than the stock Datto box.
The car runs in the Improved Production class which means full glass, but no seating etc.
It weighs 768kg on the Queensland Raceway weighbridge with full oil and a full tank - no driver
The engine is an A series block running 1608cc so the engine weight is identical to a normal A series
Hope this helps
Adam's Dad
Posted on: 2006/1/19 11:46
From Durban, South Africa
my stock nissan 1400 is 758Kg
Posted on: 2006/1/19 12:35
From Las Vegas USA
Thanks guys , well after reading this it appears my car is about where most cars with cages and all the road gear are.
Tom
Posted on: 2006/1/19 17:51
From Costa Mesa, CA
my 1200 2dr sedan with gutted interior, ca18det and stock rearend weighed in at 1675lbs. about 760kg.
Posted on: 2006/1/27 21:28
From Melbourne - Werribee
720kg with cage and a minimalist approach to interior trim :)
i have since gone to town in many areas and hope that it get back on the road under 700 although there isnt a lot to remove in the 1000s but it did have big battery and steel diff nose, heavy mag wheels, rear seat, spare tyre etc
of interest was that the split was 400 kg front and 320 rear, not too bad
hope to improve on that too!
Posted on: 2006/1/29 0:29
From Central Vic
full trim less back seat and passanger seat
stanza brakes ute diff toyota box blue bird radiator
trx rims 790kg
on that subject whats the lightest rims at a budjet
ive always thought 13*7 hotwires
Posted on: 2006/1/29 1:48
to buy or not to buy???? OK
This is the reason I have five coupes
« 1 (2)
