discs without booster
From south coast nsw
can you fit stanza stuts and disc brakes without using a brake booster?. you couldnt could u.in my time ive never seen a car with disc brakes with no booster.i tried to find some info in the tech section but failed.
Posted on: 2006/1/23 8:21
Re: discs without booster
From Melbourne, Australia
yep no problems!!!
in a 1200 i would suggest you only really need a booster once you go to four wheel discs
the 1200 coupes and late utes came with discs on front and no booster
i used stanza struts and brakes on my rally car with vanette drums on the back with stock coupe master cylinder and NO brake booster, it had very good brake pedal feel
Posted on: 2006/1/23 8:25
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Brisbane
You can use the stock brake clyinder that is in your ute now (which is the front clyinder), but you need to take the brake bias valve out to accomadate the Dsic brakes.
Thats all i remember doing for my stanza disc setup, i had a datto guru helping out too. Which always helps
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From Sydney
No problem at all, just expect a heavy pedal. Most racing cars dont use " vacuum assisted brakes" as you have more feel when braking.
I ran stanza brakes in my coupe for several years with no booster. worked just fine. The only tip I would suggest is to upgrade the brake master cylinder to a larger bore diameter. Most of the larger datsun range of a similar era would be a suitable donor. I used one from a 240K. 7/8 inch bore.
Posted on: 2006/1/23 8:29
serious ive had stanza struts sitting in my garage 4 six months now and ive been putting it off cause i thought id have to put a booster in which sounded a little bit tricky ,thanks dudes .does any one know where i can read up on the whole procedure so i dont make a mess of it.
Posted on: 2006/1/23 8:33
will the 240k fit staight in
Posted on: 2006/1/23 8:35
From Sydney Australia
tandem master is a good idea but.......no booster no worries (even with 4 disks) unless you have a very weak leg!!!!
Posted on: 2006/1/23 8:38
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
click on my "www" link below, i havent even visited my own site for ages and ages but theoretically theres a good description still there
Posted on: 2006/1/23 8:40
1200 Coupe Rallycar
cheers guys, a. big help really.
Posted on: 2006/1/23 8:42
