engine for a datsun 1000
im looking at a datsun 1000 ute and im wanting to put a turbo engine in it. i was thinking about using a ca18det, will this engine fit in and will i be able to get it registered. is there one that fits relatively easy, or should i just go for the 1200 ute.
Posted on: 2005/4/11 23:25
Re: engine for a datsun 1000
From WA
think brakes / suspension / steering / diff . chassis strengthening before engine.
Posted on: 2005/4/12 3:47
From Central Vic
As much as i love the look of the 1000 utes there is one major draw back a leaf spring frount makes everything so much harder for the conversion
so what would i need to do with the steering, suspension, chassis strengthing to be able to put a turbo engine in it has a running a12 should i just stick with that engine. i read that a ca18 doesnt fit real well either. what are a15 egines like, is it worht putting one i those in.
Posted on: 2005/4/12 4:21
From WA
an A15 with a draw thru supercharger (2in SU and an SC12/14) would be your cheapest bet.
Posted on: 2005/4/12 7:09
Why's that?
Posted on: 2005/4/12 9:17
From Brisbane, Narangba
Mate even a 120hp or so hot a15 would be very quick in a 600kg car. Stick with A-series for price, ease and still a fair bit of speed.
Posted on: 2005/4/12 9:33
From Central Vic
when i consulted an engineer about my coupe conversions he thought i was talking about a thousand coupe and he basicall said that the frount end design would limit its ability to pass the strength and relibility section he wanted upgraded everything pretty much
This may depend on engineer
Posted on: 2005/4/12 16:54
From Warburton vic
What about a micra engine they are very light & can make good hp. I no where there is a micra turbo man that flys
Posted on: 2005/4/13 1:03
From Coondle, WA Australia
yeah dude
stick with the a series.
a hot a15 will go like that clappers. its easy to paste in, parts are cheap and easy to find, and less stuffing around
Posted on: 2005/4/13 5:22
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
