relocation of batery help?
From Canberra, ACT
hey guys was wondering whats the best way of doing this im moving it out of my 1200 ute and putting it in the back where what would i need too do this.im moving it because the intercooler piping runs straight through there i wanna know
what guage wire is best
best route for the wiring what switchs or relay stuff
also should i get a battery box and also put that inside a little tool box just to protect my battery
also pctures would be great ; )
[moderator edit: removed slur. Datsun1200.com welcomes all 1200 fans regardless of country or ethnic background]
Posted on: 2010/6/17 7:55
Edited by ddgonzal on 2010/6/17 20:41:12
Re: relocation of batery help?
From South Africa, Bloemfontein
I am also interested. There is a couple of wires going from my + side of the battery to the different electrical equipment. I am curious what people did with these wires. Did you guys just run a thick wire from the battery to the front and connected it to the starter like normal and then all the thinner wires connected to the starter at the + side as well?
Posted on: 2010/6/17 8:30
1977 Datsun 1200GX
From Snohomish, WA USA
I just moved my battery to the trunk. #2 gauge wire works fine. I mounted a positive stud terminal to the front shock tower under the hood. Just connect everything there just like its the battery. I built a metal tray the size of my battery. I then set the tray inside a battery box and drilled holes through the tray, the box and the frame. Strapped the battery to the tray and set it in the box and then bolted it down. Made the battery connections and tested the ground by running an ohm meter from the front of the car to the back. Put the lid on the box and strapped the lid on. Done. Works great.
Posted on: 2010/6/17 8:50
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
From Melbourne, Australia
grab a dry cell battery and upgrade to that at the same time
furst time i did it i connected everything back to the starter motor terminal, but that becomes a pain down there, and the terminal start to twist up when your doing the nut up tight enough. ended up breaking the terminal on my starter at one stage
when we did the electrics a while back in the current rally car we mounted a fuse box up where the original battery sits roughly, then you can run a single fat wire from the starter to the new fuse box and run everything from that, properley connected, accesible and properly fused too!
Posted on: 2010/6/17 12:53
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
By 'dry cell' do you mean a gel cell (battery that can be turned upside down wihout leaking)?
That's a good idea about a fuse/junction box. You could even put a master disconnect switch right there under the bonnet.
Posted on: 2010/6/17 20:45
From Geelong, Vic
i did the same as 1200rc, used a normal lead acid battery in the sedan, but got a better sized dry cell for the wagon. and run everything off a main fuse/relay box where the battery used to be
Posted on: 2010/6/18 1:50
From Canberra, ACT
roughly how much are are the dry cell batterys and what size fuse like a 25amp??
Posted on: 2010/6/18 7:30
"Dry cell" is just a generic term. For automotive batteries, a gel cell lead-acid battery is about 2x the cost of a regular flooded lead-acid battery. I'm not sure if there is any advantage unless you want to mount the battery on its side. AGM batteries are another type and can be charged and discharged faster (for electric car usage).
Optima and Oddyssey are two famous brands.
You can mount the battery in a battery box, which is sealed and has a vent hose that you can run outside the car.
Posted on: 2010/6/18 7:40
From dominican republic
sorry to use this post but i think its better than creating a new one.
want to know were can i putt the battery in the back of the ute(not inside)forget about the wiring just want to know the battery location????
saludos.
Posted on: 2011/2/8 19:57
