(1) 2 3 4 »
swap meet at my house ?
From mandurah
just wondering if anyone had anything that they want to sell or swap cos i need to get rid of heaps of stuff and i need a couple of things
for sale or swap
CA18DET ,complete minus harness and turbo ,comes with a computer =$ best offer
3x A12s 2 are running ,one needs a carby it will run ,the third needs rocker gear and a rebuild but is complete = $100 each for the running ones and $50
for the early model
sedan for parts ,pick a part and its yours
coupe rear seat in good condition but needs a recover $20
sedan rear seat condition unknown as of yet $20
a set of cheviot hot wires and crappy tyres $50
toyota hilux 5 speed with an adaptor plate to suit a CA $75
CA18DET block, rods, pistons, crank, head and turbo manifold $75
1200 sedan wiring harness complete $20
doors ,sedan front and back $20 a door
gaurdes and bonnets $20 for a bonnet $20 for a gaurde
sedan shell RARE convertable (might be worth something in time to come) take it away
tail shafts ,1200 hilux and some random ones $20
struts and brakes
early 120y struts and brakes $70
1200 coupe struts with brakes $70
sunny struts and brakes (brett owns them) ?
hilux 4 pot in good condition =cost me $120 but i will sell for $90 for the pair
1200 coupe front struts and brakes ,needs new pads and rotor have been skimmed and driven with 3 times $90
CA18DET jig ,keep or borrow ,i dont care make heaps of them !!!
15 inch tyres in good condition and could be used as burn out tyres or every day car tyres $20 each
random 13 inch steelys with tyres 13s $30 each
A12 /A14 pulleys and fans $10
master cylinders ,13/16 7/8 and a couple of others $20
master cylinder of a 120y with good booster $50
sedan front cut ,smashed up ,vin plates ?
silvia fuel tank and pump $50
steel fuel line 3 M new $10
L series GX carbys ,$100
random braided line pieces new and some fancy blue and red fittings $15 each
A14 block Good but needs a rebore and a plain) $50
A14 pistons and rods ,40thou over in good condition $50
mint A14 crank ,could maybe do with a polish if you were to put new bearing in with it ,whats it worth ?
EFI inlet manifold ,modified excel manifold ,needs porting and some weding done and i did a pretty rough job to just get it mounted onto the head and now the rest is fine machine work $50
14 inch rally tyres $15 each with rims
steel grille in good nick ,of my ute $40
4 56A 4 speed boxs and im pretty sure they all work fine ,$50 each
1200 heater boxs ,in good condition $40 each
CA flywheel and clutch (ceramic puck) $50
a box of lifters ,A14 valve springs and a heap of A12 engine parts $50 for the lot
dash frame in great condition minus surround (its a late model dash from memory) $20
120y diff locked stronger than a ute diff $100, and open centre 120y diff ,complete drum to drum $120
hilux axels and a pumpken ,minus some of the housing and the gears $25
standard 1200 coupe seats ,on rails with crappy seat covers $20
spare A12 flywheel $20
A14 clutch and pressure plate ,mint pressure plate and the clutch disk is worn $30
commodore rear calipers ,good for hydro hand brake on a R31 diff as they bolt on $50
things i need
CASH or SWAP for parts ,anything A14 or A15
or anything that could be usful in my CA coupe ,mainly fiddly bits
and i owe jordy, brett ,nigel and bailz ,so they get first pick and for free
Posted on: 2010/7/9 13:53
Edited by estyre on 2010/7/10 14:37:46
Edited by estyre on 2010/7/10 14:55:52
Edited by estyre on 2010/7/12 9:37:20
Edited by estyre on 2010/7/12 15:42:39
Re: swap meet at my house ?
From Perth WA AUS
I wouldn't mind the 1200 ute diff, coupe dash and seats. Might talk about brakes tomorrow aswell.
Posted on: 2010/7/9 14:00
Datsun 1200 2Dr sedan.
From mandurah
its yours !! ill get it all in a pile now so its ready for the morning ,oh and the diff is in the coupe
120y diff is stronger and i have one that isnt locked now ! but i think you will need to change the yoke to fit it ,hhmm i think i have one of them somewhere though
Posted on: 2010/7/9 14:02
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth WA AUS
Thanks mate, will see you tomorrow.
Posted on: 2010/7/9 14:04
From Albany, Perth Australia
time to pillage again hehehe...first in best dressed
Posted on: 2010/7/9 15:12
1200 Smerf Mobile
whats the hilux adapter for the Ca18? someone made it at home or proff, is it tested? How was it made
Posted on: 2010/7/10 0:30
From mandurah
it was made on a mill and is accurate to with in 1 thou so it slides onto the hilux box and then a CA bellhousing bolts un to it and it just needs the centre hole cut out and the starter motor hole to be cut but they arent needing to be done on a mill
it is made out of about 10mm thick plate so it is pretty strong
to suit a hilux/T50 box (i think) the hilux box is a steel cased,shorter version of the supra box and is equally as strong
Posted on: 2010/7/10 14:31
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
will u post??
if so ill take the late cross member
Posted on: 2010/7/10 15:34
Car free
From Melbourne Vic
i'll take "A14 pistons and rods ,40thou over in good condition $50" if you post? Pm me your account details if so
cheers
Leigh
Posted on: 2010/7/11 2:24
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
wish i could get the 120y diff, would be great- obviously would swap out the locked center.
Posted on: 2010/7/12 0:39
(1) 2 3 4 »
