(1) 2 3 »
fast indicators on 93 rodeo
From Coondle, WA Australia
I am fixing up my dads 93 holden rodeo and its been a win so far.
One thing has got me stumped.
The indicators are going flat out at about twice the speed they should.
All the globes are working.
replaced the relay
Other than replacing the control stem (which is the last option)
anyone got any ideas on what could be causing it?
The hazard switch is sticky. Could this be an issue?
Posted on: 2011/5/6 8:53
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: fast indicators on 93 rodeo
From Brisbane, QLD
Got led tail lights on it?
Posted on: 2011/5/6 9:02
From Sydney, Australia
Yeah what DAT012 said!
Posted on: 2011/5/6 9:06
B110 sedan
From penrith,sydney,aus
what about the flasher unit, could be that or i know with other holdens the hazards switch can cause problems
Posted on: 2011/5/6 9:14
2 door 1200 sedan project l20b stroker
From Ringwood, Melbourne, AUS
I think the flasher unit expects a certain resistance or something like that and if it doesn't get it, it will flash fast.
So led's can cause it if it is a normal flasher and also vice versa..
Posted on: 2011/5/6 12:31
Deano
No LED taillights guys. Its not that.
The hazard switch is suspect, so ill swap that out and see if that fixes it
and get back
cheers
Posted on: 2011/5/6 12:42
From Albany, Perth Australia
could be an earth problem....
Posted on: 2011/5/6 12:56
1200 Smerf Mobile
If it was the earth cricut, then I would expect to find globes out, and that would explain the issue but then again it could be. I spose its called electricky for a reason.
Its uniform on both sides.
Its not the relay- Thats been replaced.
Its not globes - they all work.
Posted on: 2011/5/6 13:40
Check the plugs that connect the tail lights with the rest of the car
Posted on: 2011/5/6 14:07
1200 Smerf Mobile
From Perth WA AUS
A bad earth can make lights do strange things, often flashing a brake light instead of the indicator light.
Double check earth connections first, but it may be still the flasher unit even if it's a new one.
Or it could be something else :)
Posted on: 2011/5/6 14:16
Datsun 1200 2Dr sedan.
(1) 2 3 »
