Browsing this Thread:
1 Anonymous Users
Heat and Smoke damaged 1200 Coupe on TradeMe. |
From Invercargill, New Zealand
Hopefully this will rise from the ashes - been a well built car with a long ownership. Trade Me
Posted on: 2018/8/5 12:19
Re: Heat and Smoke damaged 1200 Coupe on TradeMe. |
Saw that last night. Certainly a really nicely built little car with some serious gear. I am pondering over whether to have a crack at it myself but the big question mark is what sort of damage has the smoke done? If its been hot enough to melt the hood lining then one can only wonder what the wiring loom is like... Lets see where the bidding gets to. Cheers Dave
Posted on: 2018/8/5 21:47
From Sydney
$8k to $10k worth of parts alone. Most of that in the motor alone, going by the build specs. I think if it sells for less than $10k it's a bargain.
Posted on: 2018/8/5 23:08
 ----------------------------------------- 1971 B110 Sedan GX Spec 1970 KB110 Coupe Track Car 1970 KB10 Coupe ----------------------------------------- S13 caliper b...
From Las Vegas USA
Off on a total tangent; does anyone know what brand of dry sump pump that is? I have one that looks identical.
Tom
Posted on: 2018/8/6 1:38
Registered Users Contentmaster Usermaster
Seems low temp damage, as the headliner is only partially melted, ditto for the cowl top grilles. The heat was outside the car (building fire). Engine alone gotta be worth a bit, and bidding starts at $1 out of auckland, is the owner a member here? Quote: 1972 Datsun 1200 B110 Coupe race car with log book.
Heat/Smoke Damaged in building fire. Was driving before fire.
Requires a lot of work and I have no idea what the rebuild cost would be.
Includes huge selection of spares.
Rego on hold, cert plate but would require a lot of work and re certifying before being road legal.
A15, 1564cc,11.5:1 Comp Arias Forged Pistons & H-Beam Conrods ARP Rod Bolts Race Cam with Double Valve Springs Chromemoly Pushrods, Custom Rockers Ported Head, 2mm Oversized Valves, 3 Angle Seats Balanced Knife Edged Crank & Flywheel 45mm Weber Carbs & Ported Manifold Extractors & 2.25" Mandrel Exhaust 3 Stage Dry Sump, Griffin Cooler 10L Oil Tank, Braided Lines, Bored Oil Galleries Custom Pulleys, crank trigger, Idler & Suzuki Alternator 4 x AEM Smart Coils, Link G4+ Atom ECU Ali Radiator & Electric Water Pump Rebuilt Nissan 60A 5 Speed Custom driveshaft Shortened H160 Diff, AE86 Cussco 2 Way LSD 4.67:1 Double Diaphragm Pressure Plate Carbon Kevlar Clutch Plate Wilwood 4 Pot brakes on 280mm Front Rotors 240Z Aluminium Drum Brakes Wilwood Adjustable Brake Bias Valve Bigger Master Cylinder, Braided Brake Lines
Front Coilovers with Bilstein Inserts Rose Jointed Lower Arms Adjustable Radius Rods & Steering Arms HD Front Swaybar with Solid Mounts Adjustable Camber Plates Flattened Leaf Springs, extra leaf & 25mm blocks Rear Panard Rod, Swaybar, Mount & Links Koni rear shocks Ali Door Cards, Rear Floor, 20L Fuel Cell Homologated 6 Point Roll Cage Fibreglass GX Bonnet, Front Guards, Bobtail bootlid and 100mm bolt on Flares, Front Spoiler Skid Pan Front Strut Brace 20L Fuel Cell, Electric Pump & Braided Lines 15 x 8" 0et Rota RKR Wheels 225/45/15 NT01 Nitto Semi Slicks 350mm Wider Track & 50mm Longer Wheelbase
Posted on: 2018/8/6 2:09
From Sydney
Frenzied bidding. Sold for $11,550
Posted on: 2018/8/12 23:38
will it be fixed? or just parted out?
Posted on: 2018/8/13 10:19
did some 1200 fan buy it?
Posted on: 2019/4/21 23:09
From WEST AUSTRALIA
EDIT
Posted on: 2019/4/22 0:46
Edited by KULH on 2019/4/27 1:26:57
