I've just purchased a 1963 Triumph Spitfire and it has an A12 GX motor in it.
It's got the high oval port head and twin hitachi (SU copy) carbs with it.The problem is that the motor was in pieces when I got it.
I need help finding these parts (willing to buy from anyone in OZ that will help) - or pls tell me where I can buy them or at least in the case of the bolts what the specs are:
The Hitachi carbs are missing:
+ one suction chamber,
+ one piston,
+ one screw in damper thingo,
+ one piston spring,
+ all linkages/choke mechanisms,
+ and both needles.The block is missing:
+ sump screws,
+ timing cover bolts,
+ rocker cover nuts,
+ water pump bolts
+ the bolt that holds on the crank pulley wheel
+ the bolts that hold on the fan
+ and the nuts that hold the carbs to the manifold.I know this is a lot of stuff but I'm really keen to get the motor running, and if you can help me out I'll make sure you get something for your efforts (even if it's just a pic of me smiling fiendishly at the finished mota).
There are pictures of my car at
Triumph Owners
