Hand Brake
From Datsun 1200 Club
Category: Brake System
Datsun 1200 has a parking brake system with the handle conveniently located between the two front seats. Also known as "emergency brake", "parking brake" or "handbrake" (the primary brakes are called the "service brakes").
12959.jpgAlbum 12959
74965 #Hand Brake Cover is called by Nissan the "parking brake lever COVER".
26363.jpgAlbum 26363
36310 Hand Brake Lever Assembly (comes in black, brown and grey)
36315-H1001 GRIP-HAND BRAKE (Hand Brake Lever Handle)
28730.jpgAlbum 28730
36402 front handbrake cable
The front cable is different lengths to suit different body shapes, there is some interchangeability but sometimes you end up too short
36402-H1025 CABLE ASSY-hand brake, front B110 supercedes 36402-H1001
36402-G1000 CABLE ASSY-hand brake, front B120 (up to 1973-11)
36400 rear cable (complete set)
UTE: Parking Brake Cable goes out the back wall
26409.jpgAlbum 26409
Hand Brake Cover
74965-H1000 original type was a beautifully minimalistic piece. Datsun called it the hand brake boot.
26363.jpgAlbum 26363 hbc-.jpgAlbum click to view hbc.jpgAlbum click to view 4489_5ac16b31bab35.jpgPost 487963 4489_5ac16b3e1fddc.jpgPost 487963 4489_5ac16b447ca2b.jpgPost 487963
B210 intially used the H10 cover but in the second year switched to the H73 part.
B210 cover also fits and is the official supersession part since back in the day.
Top: replacement H73     designed for B210 from July 1974 part, same as B210 | Bottom: original B110 design
8190.jpgAlbum 8190
Emu-skin cover
H59 cover includes magnetic seat belt holders
29669.jpgAlbum 29669 29670.jpgAlbum 29670
Unlike the two other covers, this requires a bracket to bolt to the tunnel
29671.jpgAlbum 29671
Used by late USA and late Excellent GB211 (1600)
ブレーキカバー
Cable Routing
Front half is same for all 1200
21610.jpgAlbum 21610
Rear half
9389.jpgAlbum 9389
Coupe
2886.jpgAlbum 2886
sedan
9390.jpgAlbum 9390
9391.jpgAlbum 9391
Ute - cable comes out the cab lower rear panel
13738.jpgAlbum 13738
Warning Light
Dash-top Indicator Lamp
Some utes had a PARK BRAKE lamp on top of the dash that lit up when the handbrake was activated and IGN was ON.
26134.jpgAlbum 26134 26133.jpgAlbum 26133
18685.jpgAlbum 18685
Light Switch
The light switch was added to the hand brake lever.
Light
Parking Brake Lever
1972 USA Owners manual (Page 13 ... 13):
When the parking brake is applied, the brake warning light will glow
29373.jpgAlbum 29373
Dash-top Lamp (AUSTRALIA)
Cluster Gauge Lamp (USA/late JAPAN)
Dash Lamp (early JAPAN)
  • 74965-H7300 BOOTS-HAND BRAKE [Large style]
    22106.jpgAlbum 22106
    • replaced: 74965-H1000 BOOT-HAND BRAKE B110 [small style]
  • 74965-H1000 COVER ASSY-PARKING BRAKE LEVER B120 8910-
  • 74965-G1060 B120 7804-8910 [Brown]
  • 36011-89901 SWITCH-HAND BRAKE USA
  • 36011-H1900 SWITCH-HAND BRAKE WARNING 0570- USA
    • Also fits B210 USA
    • Also fits B210 JAPAN from '75-4
Aftermarket Cable
  • 48-1/4" Overall Length, 2 Per Car
  • RAYBESTOS BC92888 $39.79
  • ACDELCO 18P154, 18033072 $48.79
21472.jpgAlbum 21472 21471.jpgAlbum 21471
B140
2005 bakkie with Bench Seat has the hand brake lever next to the door.
22420.jpgAlbum 22420
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Hand_Brake"
This page has been accessed 28,802 times. This page was last modified 08:03, 5 February 2024. Content is available under Datsun 1200 Club.
