Rust
(Redirected from Water Box Rust)
Category: Body
Like any steel-bodied car, the Datsun 1200 is prone to rust. Unlike the Datsun 1000, the body panels are not galvanized but only painted on the inside. Eventually rust will attack your car, sometimes from the inside out. This means that keeping the car's paint waxed -- though it will help -- will not prevent rust.
Rust Treatment Methods
Rust treatment is not specific to the Datsun 1200, you treat it the same way as any other car. Search for rust treatment guides here: Rust Treatment.
  • The best solution is cut the rust out and replace with sheet metal patches
  • The best treatment is POR15, perhaps
A lot of rust and a few holes
2632.jpgAlbum 2632
Rust around the taillights is another area to inspect
2633.jpgAlbum 2633
Bottom of suitcase full of rust & holes, [need] more new sheet [metal]
2634.jpgAlbum 2634
More rust & holes
2635.jpgAlbum 2635
Fender Corner Rust
In the front the solution is to patch the Sills
1412.jpgAlbum 1412 3299.jpgAlbum 3299
In the rear, patch the Fender
11967.jpgAlbum 11967
Floor Rust
Lift the front mats to examine the floors -- floor rust -- very common. New panels can be purchased as of 2017.
1494.jpgAlbum 1494 1493.jpgAlbum 1493
wagon rear floor
13022_4e3cb9b4e57d1.jpgPost 378695 13022_4e3cba168ae1f.jpgPost 378698 13022_4e3cba3e841d5.jpgPost 378698
Engine
Engine with water damage to the bores must be re-honed
2636.jpgAlbum 2636
Battery Tray Rust
Grind off the battery tray rust, sand it down, and cover with primer paint
7060.jpgAlbum 7060
Water Box Rust
The most common "hidden" rust problem is with the "water box" -- the part of the firewall/cowl where fresh air enters the cabin.
Discussion: POST water leaks
1173.jpgAlbum 1173 1174.jpgAlbum 1174 1175.jpgAlbum 1175
See Firewall for how these panels fit together to form the 'box'.
23934.jpgAlbum 23934
Water normally comes in though the air vents behind the bonnet, hits the baffle and runs down to a drain hole. If any part of the body in the area is rusted, water will instead leak down onto the fenders. You will only see this drain hole when a welded section is removed from inside the inner guard.
4175.jpgAlbum 4175
The drain hole is behind the Reinforcement stiffener piece:
19189.jpgAlbum 19189 10257_4df73b9b04ed3.jpgUpload click to view
Solution? Cut the rust out and replace with new sheet metal
19951.jpgAlbum 19951 19952.jpgAlbum 19952 19953.jpgAlbum 19953 19954.jpgAlbum 19954 19955.jpgAlbum 19955 19956.jpgAlbum 19956
4707.jpgAlbum 4707 5542.jpgAlbum 5542 6970.jpgAlbum 6970 6971.jpgAlbum 6971 6972.jpgAlbum 6972 6973.jpgAlbum 6973 9923.jpgAlbum 9923
174_57c61874beca1.jpgPost 480921 174_57c6188aa9f0d.jpgPost 480921 174_57c6189397025.jpgPost 480921
Fuel Tank Rust
What if you have a rusty Fuel Tank?
Discussion: repairing rusty fuel tank
Light surface rust like this can clog the fuel filter. Remove the rust and treat the inside to prevent it from re-ocurring
12328.jpgAlbum 12328
Wheel Well Rust
9235.jpgAlbum 9235
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Rust"
This page has been accessed 25,496 times. This page was last modified 10:48, 19 November 2018. Content is available under Datsun 1200 Club.
