Some Datsuns were fitted with sidedraft carburetors right from the factory. Usually fitted with twin Hitachi variable venturi carburetors which are very similar to S.U. (Skinners Union) carburettors from Britain. The Datsun 1200 GX models were fitted with twin Hitachi HJE38W 38 mm carburetors. Some Japan-market B210s were fitted with A12T or A14T engines which also used twin-Hitachi carbs. Many Datsun fans refer to the Hitachis sidedraughts as "SUs", so keep that in mind when you read information. It may be about the factory Hitachi sidedrafts, or it may be about the (non-Datsun) British SU sidedrafts.
Reportedly, Hitachi licensed the SU design, but I have yet to see a reference for that (Nissan manual, etc).
Datsun twin-carb setups used two basic Hitachi sizes:
- 38 mm (1-1/2 inch bore) on most cars
- 46 mm (1-7/8 inch bore) on Z-cars. These are too big for Nissan A engines (even if you use one) and reportedly the late model flat top 46s are a bad design.
Three Different Designs
Factory Hitachi setups for A-series engine include the A12GX, A12T and A14T types. These were fitted to JDM B110, B210 and Datsun Cherry vehicles. South Africa also sold many Twin-Carb B110s.
- A12GX for B110 (1971-1973) - Extra Large Oval Ports (30 x 34.5 mm)
- A12T for B210 (1974-1975) - Extra Large Oval Ports
- A14T for B210 (1976-1978) - Standard Oval Ports (28 x 34 mm)
A12 GX Engine
The Datsun 1200 GX (Grand Luxe Twin-carb) models were always fitted with the A12 GX Engine. This engine featured a matched pair of left- and right- hand Hitachi HJE38W sidedraft carbs. These are the true "dome-top" Hitachis, already setup for performance. They can use standard SU needles so tuning it quite easy.
11041-H2300 HEAD ASSY-CYLINDER A12 GX B110
See main article A12GX Engine
A12T Engine
See main article: Hitachi Twin Carb A12T
JDM 1973-1975 B210 GX models had the A12T twin-carb engine. While very similar to the A12 GX Engine, the A12T engine used different flattop Hitachis and a slightly different intake manifold with a few more fittings. These are decent carburetors that contrary to talk are not watered-down "emission carbs". The B210's A12T cylinder head is identical the A12 GX head, except the passage for old-style rocker oiling may not be drilled in B210 heads.
11041-H5702 HEAD ASS'Y-cylinder A12T
NOTE: B210 "GX" refers to the car and does not necessarily mean the car included a twin-carb engine as the B110 GX did. While 1973-1975 Japan-market B210 GX models did include the A12T engine, outside Japan most B210 GX models were fitted with a single-carb (A12S) engine.
JDM Datsun Cherry (E10) models also used the A12T engine, including the famous Cherry X1-R vehicle.
11041-M0801 HEAD ASSY-CYLINDER A12T
The M08 head looks like the A12GX head. Most likely the fittings and accessory bolts are slightly different from the A12GX version.
A14T Engine
Starting in July 1976, the B120's A12T was replaced by the A14T. This corresponded with the B211 model change (B210 minor facelift). Some (but not all) GX models used the Twin-carb engine; even in Japan other 1976-1978 GX models used a single carb engine. Unlike the A12GX and A12T engines with their monster intake ports, the A14T used standard A14 oval ports (28x34 mm), which are smaller than A12GX ports (30x35mm). A14T used a single tube exhaust manifold (A12 twin-carb engines used twin-outlet exhaust manifold).
11041-M2460 HEAD ASSY-CYLINDER A14T
Datsun Cherry (F10) models with A14T engine also used the very same cylinder head.
- A14T Manifold matches standard A14 gasket
- One improvement over the A12GX engine is that the A14T uses a small thermostat where the water goes into the manifold
A14T engines used flat-top carbs, heavily modified from the A12 type Hitachis apparently to manage emission control.
Nissan B211 Parts catalog showing some GX models were fitted with single-carb (A14S) engine:
A14T Features:
- A lot of emission controls
- EGR port on top of manifold
- Throttle servo
- Flat-top triangular-bell Hitachis
- Automatic chokes (electric)
- Vacuum ports on each end, top of manifold
- No PCV valve fitting
Carb side:
Retro-fitting
For true bolt on experience, you will need a complete setup:
- Intake manifold
- Exhaust manifold (twin down-pipe cast headers). The clearance differently than regular manifolds
- Two carbs
- Fuel lines
- Accelerator cable & linkage
- Choke cables
- Air cleaners
In general on a given manifold you can use SU, Zenith-Stromberg (ZS) or Hitachi sidedrafts, but note that the linkage, hose locations and air cleaner attachment will vary.
NOTE: The Hitachi sidedraught carbs are on the left side of the A-series engine. On a RHD car there is clearance aplenty, but on a LHD car fitting an air cleaner it a bit tricky. But this is more easily fitted to LHD than a twin-Weber setup.
Variations
Dome Tops vs Flat tops:
- Dome Tops are early models
- Flat Tops are 1974-up (from July 1973) some with emission controls
NOTE Linkage differs between different models.
38 mm
38 mm (1-1/2")
HJB
38 mm (1-1/2"):
- HJB38W-1: 1963-1964 SP310 1500 Roadster G engine
- HJB38W-3: May 1965-1967 Roadster SPL311-1600 (R16 engine), CSP311 Silvia
HJE
38 mm
- HJE38W-1: 1964 DP410MTK (410 Bluebird)
- 16010-10615
- Used two right-hand carbs, with right-angle forward-facing fuel inlets
- Used twin-snorkel air cleaner, with dual interior right-angle air horns.
- HJE38W-2: 1966 411 SS Bluebird (DR411)
- 16010-16710
- HJE38W-3: 411 Bluebird 1600 (DP411MTK)
- 16010-15800, 16010-18810
- Used two right-hand carbs, with right-angle engine-facing fuel inlets
- Different mounting angle
- Same air cleaner as 410
- Used bar linkage, (similar to a twin Mikuni setup)
- HJE38W: B110GTK, KB110GTK Datsun Sunny 1200 GX
- 16010-H2330 front
- 16010-H2331 rear
- A12 GX from '70-Jul
- 16010-H2332 front
- 16010-H2333 rear
- A12 GX from '71-11
- 16010-H2334 front
- 16010-H2335 rear
- From '73-1
- 16010-H2336 front
- 16010-H2337 rear
- Fuel bowl outlets: Banjo fitting
- Fuel bowl inlets: Engine-facing nipples
- HJE38W
- 16010-H2332 PE10 A12T front
- 16010-H2333 PE10 A12T rear
- HJE38W-5C PE10 A12T (from '71-11)
- 16010-M0830 front
- 16010-M0850 rear
- HJE38W-5E PE10 A12T (from '73-1)
- 16010-M0831 front
- 16010-M0851 rear
- HJE38W-8A PE10 A12T (from '73-3)
- 16010-M0832 PE10 A12T front [flat tops]
- 16010-M0852 PE10 A12T rear [flat tops]
- HJE38W-8 B210 A12T
- 16010-H5731 front [flat top]
- 16010-H5751 rear [flat top]
- OPTION hot air cleaner
Unknown Type 38mm
- B210 A14T [Flat Tops, new type]
- Triangular shaped throttle plates
HJL/HTL
38mm
- HJL38W-1A: 1969 P510 SSS [P510TK], CSS [KP510TK]
- 16010-22002, 16010-22004
- Fuel inlet, engine facing banjo
- HJL38W-2A: P510 SSS, CSS OPTION
- 16010-22005
- 1971 510 SSS P510TK (1600), KP510TK, H510TK (1800), H510ATK, KH510ATK
- same fuel inlets as B110 GX
- HJL38W-5 L14T circa 1972 PB110
- Fuel bowl outlets: upward pointing nipples
- Fuel bowl inlets: Engine-facing nipples angled up
- Fat air cleaner from 7110
- 1972 510 SSS
- Fat air cleaner
- HTL28W-6: 1972-1973 610 twin carb ass'y
- 16010-U0800
- HJL38W-6A: 1973 610 L16T, L18T (from '72-7)
- 16010-U0831 front [flat top]
- 16010-U0851 rear [flat top]
- HTL38W-7: 1973 610 L16T, L18T (from '73-3)
- 16010-K1430 front [flat top]
- 16010-K1450 rear [flat top]
- 1975 610
- 16010-K1431 front [flat top]
- HJL38W-8 PB210 L14T [Flat Tops]
- HJL38W-7 710 L16T [flat tops]
- 16010-K1430 front
- 16010-K1450 rear
- HJL38W-7 710 (from '73-6)
- 16010-K1431 front
- 16010-K1451 rear
- N510 1971 catalog
- 16010-N0410 L16T, 1800 SSS
- 16010-U0800 L16T
- 16010-U0831 L16T
- 16010-U0851 L16T
- 16010-A8700 1971 L18T, late 1600 SSS
46 mm
46 mm (~1-13/16)
- HJL46W: ?
- HJG46W: Roadster U20 (SRL311-2000)
- HJG46W-3A: S30 (240Z) Manual Trans -0871
- HJG46W-R3A rear carb
- HJG46W-F3A front carb
- HJG46W-4: S30 Automatic 0870-0871
- 1972 changed to water-heated carbs
- HJG46W-8: S30 1972 manual trans
- HJG46W-R8B rear carb
- HJG46W-F8B front carb
- HJG46W-9: S30 1972 auto trans
- HJG46W-R9A: rear carb
- HJG46W-F9A: front carb
- HBM46W-1 1973-1974 (240Z & 260Z Flat Tops)
http://www.zparts.com/zptech/articles/mal_land/ml_sucarb2/SUcarb_111601b.htm
Parts Donors
- A-series import engines from Japan
- Datsun Competition setups
- Datsun Roadsters: Reportedly, all Roadsters were fitted with Hitachis except the 2000 Roadster (2-liter engine) which came with Solex/Mikuni carbs.
- Datsun 411 SSS (circa 1966)
- Datsun 510 (1600) SSS
- Datsun 610 (180B) SSS
- Datsun 710 (160J) SSS
Damper Oil
The damper (aka dashpot) is oil-filled. Nissan recommended 20W or 10W30 Elephant Oil, but any brand of motor oil will work. Others have reported success with ATF (automatic transmission fluid), sewing machine oil (generally 10W), or motorcyle oil. The lighter oils tend to run the carb on the lean side.
Tuning
See main article: Hitachi Twin Carb Adjustment
Troubleshooting
Go here for lots of information: The Hitachi-SU Tech Pages - Troubleshooting.
References
- Nissan Motorsports catalog (#99996-CAT98 and other years)
- Nissan Schematic catalog (#99996-M8015)
Parts Suppliers
- Z-Therapy sells parts and complete setups http://www.ztherapy.com
- Get the 510 SSS carb setup. The jetting is slightly different but otherwise they are the same
- craigslist and other local sources (from time to time)
- eBay from time to time
The parts although not common, are not rare in USA. Quite a few twin setups were found on import engines in the 1980s, and quite a few were purchased from Datsun Competition, so they can be found.
ZTherapy is in the USA, and always has them on hand.
See:
Nissan Competition
From the 1984 Nissan Competition catalog.
GX/SU INDUCTION SYSTEM
The GX/SU induction system was a production line option on non-USA versions of the 1200 and B210. Requires use of GX cylinder head. The GX system can be adapted to virtually any A-series engine.
16010-H2336 38MM SU CARB (FRONT) 16010-H2337 38MM SU CARB (REAR) 14003-H2330 GX INTAKE MANIFOLD 11826-H2300 BLOCK TO MANIFOLD HOSE 14035-H2300 MANIFOLD GASKET 14330-H2303 GX HEAT SHIELD (1) 16031-H2300 OVERFLOW TUBE/FRONT 16031-H2301 OVERFLOW TUBE/REAR 16174-H2300 INSULATOR (2) 16175-A5100 INSULATOR GASKET (2) 16361-H2300 THROTTLE SHAFT ASSY 16376-H2300 ACCELERATOR CABLE BRACKET 17523-H2302 FUEL TUBE (1) 18410-H2302 CHOKE CABLE (1)
Links
- The Hitachi-SU Tech Pages
- Datsun Service Manual for Hitachi
- buy SU/ZS carbs
- SU tech info from 311s.org
- discussion: NWDE
- http://www.mydatsunroadster.com/2005_07_01_archive.html
- http://www.efn.org/~msayer/zcm/SUTUNE.html
- http://www.ztherapy.com
- http://www.mydatsunroadster.com/2005_08_01_archive.html
See:
