Toyota 4A engine
Revision as of 04:02, 11 March 2007; view current revision
Category: Engine Modifications
The Toyota 4A engine variations are a popular swap into Datsun 1200s. These are 1600cc engines, so are a significant upgrade in terms of cubic inches alone. However, it is the DOHC 4AGE that shines with impressive power. Also notable is the 4AGEZ supercharged engine from the Toyota MR2.
NOTE to newbys: Beware of mentioning rotary-powered or Toyota 4AGE-powered 1200s. Some club members may get offended! But really, these are also excellent engines that fit in fairly well. Just don't tell anybody ;-)
Source for Engine
RWD 4A Engines
  • AE71 was the 1983 Corolla, with carbureted 4AS SOHC engine.
  • AE85/AE86 was the last RWD series (1984-1986) with fuel injected DOHC 4AGE engine
826.jpg Toyota Twin-Cam
Gearbox
Use the gearbox that came with the engine. Don't try to fit it to the Datsun gearbox, because the Toyota box is much stronger.
Differential
The AE86 differential is strong, and bolts into the Datsun 1200.
Projects
In Victoria, Canada there is a fantastic 4AGE-powered 2-door sedan:
In Rooihuiskraal there is this one:
Swap Notes
9499.jpg Sump Fitment
9494.jpg front clearance
9491.jpg rear clearance
9508.jpg Air Inlet
9495.jpg Shifter
9509.jpg VW Golf Radiator
9673.jpg Water pump hose
9522.jpg Pedal Boxes
Brake booster
