The Timing Cover is the aluminum part on the front of the engine that covers the Timing Chain. It also has a timing mark on the cover and houses the crankshaft pulley seal.
The Timing Cover bolts to the front of the engine block and covers the Timing Chain. The Water Pump bolts to the timing cover.
Depending on the country, 1971 or 1973 saw newer timing covers which differ from earlier covers.
Water pump bolts to the timing cover. And the cover bolts to the front of the block, and passes water through two ports (the square hole, and the round hole).
Matched Set
Japan got this change in June 1970. North America: all A-series engines from 1972 including 1973 A12.
Early Set Multiple-mark Crankshaft Pulley Single-mark Timing Cover
Late Set Single-mark Crankshaft Pulley Multiple-mark Timing Cover
The same covers are used by A10, A12, A12A, A13, A14 and A15, except for the first type:
1. Original Datsun 1000 timing cover, for single-row timing chain 13035-18000 ASSY-COVER TIMING CHAIN 2. to June 1970, with single timing mark (pulley has multiple marks) 13035-18001 ASSY-COVER TIMING CHAIN [updated to fit Double timing chain & pressure tensioner] 3. from June 1970, with multiple timing marks (pulley has single mark) 13035-H1000 (or from second source: 13035-H1010) [Fits all A10 blocks]
Interchange is same for same. The last two will interchange if the complete set of pulley & cover is used.
Gasket
- FEL-PRO Part # TCS24531 RockAuto.com $6.74
- BECK/ARNLEY Part # 0380071
Seal
See Crankshaft Seal
Corrosion
Tach Drive
Race engines sometimes use a mechanical tachometer drive off the camshaft, with the Timing Cover modified to suit.
See Tach Drive
Customized
Access cover for adjustable timing gear
B110 RAW LIST
13035-H1000 ASSY-COVER TIMING CHAIN 13035-18001 ASSY-COVER TIMING CHAIN 13042-18000 SEAL-OIL CRANKSHAFT FRONT 13510-H1000 SEAL-OIL CRANKSHAFT FRONT (NOK) 13083-18001 TENSIONER-CHAIN TENSION SIDE 13084-18000 SUPPORT-TENSIONER TENSION SIDE 08110-62010 BOLT M6 FIXING TENSIONER 11046-73402 DOWEL-WATER PUMP 11023-32200 DOWEL-WATER PUMP 08110-64010 BOLT-HEX 08915-1361A WASHER-LOCK 08915-13610 WASHER-LOCK 13044-18001 GASKET-TIMING CHAIN COVER
