Datsun 1200 weatherstripping, pedal pads, door seals, window seals
Body Panels
Fender/gaurd/wing to body.
Pedals
* Pedal Stopper * Brake pedal cover - manual * Brake pedal cover - automatic * Clutch pedal cover
Clutch
See main article: Clutch#Rubber_Parts
Engine Seals
Also see: Engine Gasket Kit
Crankshaft front seal Rear Main Seal Oil pan front & rear seals
Gearshift
See main article: Transmission Gear Control
Interior shift boot (large)
Transmission shifter seal boot (small)
Leaf Springs
Windscreen
See main article: Windshield#Rubber_Seals
Windscreen (windshield/front window)
Side
Side Welts cover the edges of the door frame, also known as "pinchweld" or Edge Trim. 2-doors also have a side window frame that is coverd by a welt.
Side Window frame: See Side Window Welt Door frame: See Interior Side Trim Part Numbers
generic aftermarket can be used for both Welts, you will need 8mm heigh and 5mm wide "pinchweld" and about 2.7 m per door (ute)
Same generic welt is used by B110, B210 and B310.
Doors
Door bump stop
Door Ventilator (quarter glass)
ドア ウェザー ストリップ ドア インサイド モール
Rear Doors
Wagon (Van) 82242-H1400 WEATHERSTRIP-rear door partition (2)
Sedan 4-dr 82242-H1000 WEATHERSTRIP-rear door partition (2)
Bonnet
See main article: Hood#Small_Parts
Bonnet (hood) bump stops
Bonnet Core Support Rubber
Bonnet Hinge Seals
Wagon Hatch
90891-H1400 WEATHERSTRIP-back door
Trunk
See main article: Trunk#Weatherstrip
Suppliers
Note that 1200 fans around the world purchase new seals from Scott's mail order.
Worldwide
- Nissan dealer has many rubber parts still available
- Scott's Old Auto Rubber
- eBay (quality from great to poor, check the ratings)
Australia
- Sydney: American Auto Parts
- Sydney: Spectrum Rubber
- Melbourne/Oakleigh, Victoria: Scott's Old Auto Rubber
- Online: Rare Spares
Canada
New Zealand
- NZ - Para Rubber bulb seal for quarter windows
United States
- Trim Lok "Trim Seal" I use the largest tube (3/4",19mm) mounted in the "A" position. This is the same trim used around the door openings of the 1200. Good for the 2-dr sedan pop-out windows.
- California: Too Intense Restoration often has genuine Nissan seals.
