Performance
Revision as of 10:21, 19 August 2007; view current revision
Category: General Information
A broad overview of Datsun 1200 Performance
NOTE: Power ratings vary by country and year. Check the underhood plate in your 1200. Most plates have the SAE* rating (see below) of 68 or 69 hp.
Engine Ratings
12226.jpg 1972 68 HP 9233.jpg 1971 69 HP
</td></tr>
yearengineHPrwhpKw@rpmtorque (lb-ft)N-m@rpmNotes
1971A12694051600070973600rear-wheel HP
 A12 used 25  30 (est)  Supertune Dyno
 A12 tuned 38  44 (est)  Supertune Dyno
1971A12 USA69 51600070973600SAE Gross HP (?)
1972A12 USA68 51600069963600SAE Net HP (?)
1972A12GX83 626400721004400JIS hp rating
1973A12SSS905567    rear-wheel HP
1973Datsun Rotary120 8965001161604400Wheels Magazine
1976A14 FED70 52    1976 USA ad, 4-speed
1976A14 CAL68 51    1976 USA ad, 4-speed
1980A1465 485600   US Wagon (from plate)
1980A14 FED80 606000   US model (from plate)
1974A12GX63 46.86224608332731200GXman
 A15 race114 85.0111856823266696590 (est)124 (est)6600Steveo1000's A15
 A15 race111 83790086118.9385900Steveo's A15
1997A1463 476000   B140 Review
2004-2006A1463 47600070972500Nissan South Africa
 A14? 99     Dattoman_1000's engine
 A14+ 104 7248   Rally1200's A
 A12 turbo 69     stock block turbo
 A15ETT 10276rw    twin-turbo
 A15 69 5370 (est)   mild build-up
4971.jpg Supertune 1200
</td></tr>
RPMRWHP StockTorque lb.ft. (est)RWHP TunedTorque lb.ft. (est)
200010261437
250014291940
300017302442
350020302944
400023303242
450025293541
500022233840
5500NANA3231
Acceleration Performance
0-60 mph15.1 secs
1/4 mile19.6 secs @ 67 mph
lb/hp29.5
80 mph stop302 ft
Road & Track Road Test (November, 1970)
ACCELERATION [1200 SSS] (Standard 1200 as tested October 1971 given in brackets):
.. 0 - 60mph ............. 11.9s . (14.0s) .. Standing quarter mile . 18.1s . (18.8s)
MOTORMAN magazine
Consumer Reports 1971 September Road Test
  • 1/4 mile ... 21.5 sec @ 66 mph
  • 0-60 mph ... 18 sec
Mechanix Illustrated 1973 article
  • 0 to 60 mph: 19.8 sec.
  • 1/4 mile: 21.6 sec.
Datsun 1200 Salesman Book, Nissan 1970
  • SS 1/4 mile: 18.6 seconds (pg 52)
Ddgonzal's timeslip (stock engine, but smaller diameter tires)
  • SS 1/4 mile: 19.887 seconds
0-60 Comparison to Other Vehicles
Comparison to Contemporary Vehicles
`The Datsun 1200 was not slow in comparison with other economy cars of the period. For example, it was faster than all these cars in 0-60mph:
  • 1973 Datsun 1200 16.5 <li>1971 Chevrolet Vega 2300 16.5 <li>1972 Dodge Colt Wagon 16.7 <li>1976 Datsun B210 (4spd) 17.2 <li>1976 Datsun B210 (5spd) 17.4 <li>1976 Renault R-5 17.4 <li>1972 Volkswagen Wagon 17.7 <li>1974 AMC Gremlin 17.8 <li>1975 Datsun B210 17.8 <li>1974 Datsun B210 sedan 17.9 <li>1979 Volkswagen Rabbit (Turbo Diesal) 17.9 <li>1971 Ford Pinto 1600 18 <li>1976 Chevrolet Chevette Rallye 19.7</ul> ... Yet slower than these:
      <li>1974 Honda Civic 15.7 <li>1980 Chevrolet Chevette 15.8 <li>1972 Fiat 128 SL 16 <li>1972 Ford Pinto Wagon 16 <li>1972 Opel Wagon 16 <li>1974 Toyota Corolla 1200 16.1
    Comparison to Modern Vehicles
    What about the Modern Era? To bring the 1200 into the modern performance era, 0-60 times would have to be improved. These are among the slowest cars of the '90s (yet their 1/4 mile times are similar to the 1200's):
      <li>1993 Subaru Impreza L Wagon 12.7 <li>1995 Geo Metro LSi 12.7 <li>1990 Hyundai Excel GLS 12.5 <li>1991 Toyota Previa LE 12.5 <li>1996 Plymouth Breeze (auto) 12.5
    reference: http://www.angelfire.com/pa3/ford/performance1.htm
    Top Speed
    I would guess the top speed is about 90 mph (144 kmh). The speedometer error in the Road & Track test vehicle was 7% off. It read out faster than the actual vehicle speed. This inflates speed, fuel mileage and distance traveled (if you go by the speedometer). My first 1200 speedo was off about 10%. My current speedo is off ~7.5%.
    Top Speed: 90+ mph Mechanix Illustrated 1973 article
    The FIA docs states a top speed of 140 kmh, and 150 kmh for the high-compression engine.
    To test the top-speed you need a long (5-mile) track or a banked oval. Mechanix Illustrated tested a stock but broken-in 1200 in 1973 on the Daytona Speedway:
    topping out at a shade over 90 mph
    MOTORMAN magazine out of New Zealand tested both a regular 1200 and a 1200 SSS and note this:
    We didn't take the 0-90mph time with the standard car because it was near the Datsun's top speed, but the SSS version took half a minute to reach this velocity, and continued to pull strongly to its maximum of 100mph.
    Braking Performance
    The disc-brake Datsun 1200 had decent brakes:
    FROM 60 MPH ... 160 feet
    ... with some or all wheels locked ... 140 feet
    It had significantly better braking performance than the Datsun 510. It was similar to the 240Z (the 1200 beat the 240Z when fully loaded).
    Stopping distance in feet from 60 mph: 190-195 feet
    256.jpg USA 1971 Nissan Consumer Information document
    Click for Nissan braking specifications
    Braking Comparison with Period Cars
    Compared to its time period, the 1200's brakes weren't necessarily bad: <li>disc-brake Datsun 1200: 190 ft <li>1964 Pontiac GTO: 197 ft <li>1970 LS-6 Chevelle: 194 ft
    It was also better than the Fiat 850 and the same as the Opel Kadette.
    Braking Comparison with Modern Cars
    The braking performance doesn't compare well with todays vehicles: <li>disc-brake Datsun 1200: 190 ft <li>2002 Mitsu Lancer: 144 ft <li>2002 Toyota Camry: 118 ft
    Weight
    Weight Distribution (Front/Rear)....54/46
    Consumer Reports Sep 1971
    Weight .................. 14cwt
    MOTORMAN magazine
    CURB WEIGHT (pounds) ... 1613
    Curb Weight: 1,609 lbs.
    CURB WEIGHT ... 1613 pounds
    Curb weight 2-dr coupe: 1650 lbs
    Curb Weight 2-dr sedan: 1630 lbs
    Add 75 lbs for automatic transmission
    Source: Nissan statistics for coupe and sedan
    Datsun 1200 Weight
    4-dr manual 1532 lbs
    4-dr auto 1609 lbs
    2-dr coupe 1520 lbs
    5-dr wagon 1609 lbs
    Source: Aussie brochure:
    Fuel Economy
    The Datsun 1200 got a fuel economy of about 24 city and 38 highway. I used to keep records, and I got about 32 rural/38 highway (after adjustment for speedometer error, see 'top speed' above).
    You don't believe it? Here are some actual test results:
    MOTORMAN magazine: Range between 24 and 32 miles per gallon. Average on test, 28.9mpg.
    Consumer Reports 1971 September Road Test: RANGE OF AS MILEAGE TO BE EXPECTED IN NORMAL USE (mpg) ... 23-41 TANK MILEAGE OBSERVED ON 300-MILE TEST TRIP (mpg) ... 35
    28 mpg overall: Road Test - Road & Track (November, 1970)
    32.5 on the 1973 Datsun 1200: Motor Trend
    35.3 mpg:
    We drove the little Datsun from Daytona to St. Augustine and back -- a total of 106 mi. -- on some second-grade roads. At an average speed of 48-plus mpd, the rig from the Land of the Rising Sun got 35.3 mpg, making the round trip on exactly 3 gallons of gas. Mechanix Illustrated
    End of Datsun 1200-specific information.
    General Information
    How much horsepower does my engine have?
    Engine ratings can vary from the engine in your car:
      <li>Different countries, different ratings <li>Different emissions controls, camshafts and other parts <li>Production tolerances. Your engine might have a little more or a little less than advertised <li>Manufacturer reports may not have been accurate <li>Ratings prior to 1971 cannot be compared directly to newer ratings (to get a ballpark comparison, subtract 20% from the gross rating)
    The best way to measure your engine is to put it on a dyno. Use the same air cleaner and exhaust and all accessories, or use a correction factor to estimate the Net hp from the Gross hp.
    Hp can also be estimated from top speed (if a lot of other things are known, like the aerodynamic numbers or the car), or from 1/4 mile drag race elapsed time.
    Horsepower Ratings Standards
    Note that engines are not rated by independent testers -- it's the manufacturer's word. They are supposed to follow a standard though, or they could be held liable for false advertising.
      <li>Japan: In Japan, the JIS standard is used</li> <li>Europe: The DIN rating in Europe. This is slightly higher numbers than SAE (for the same engine. 70 DIN = 69 SAE)</li> <li>Asia: In Asia, Kw is used. 69 hp = 51 kw</li> <li>US: In United States, SAE ratings are use (see below)</li>
    What is horsepower?
    Horsepower is a measurement of the engine's ability to perform work. For example, the work of accelerating a car through a 1/4 track.
    Note that the horsepower "number" is independent of weight. It is simply the measure of work over time.
    Horsepower is a computed factor based on the torque measured on an engine dynomometer. Torque is just the force of the engine, but doesn't say how much work is getting done. Horsepower is the work made possible by the rotating engine, so RPM is also a factor along with the torque in determining power.
    The HP "rating" is a static setting for a certain condition (like full throttle, maximum engine load at a certain RPM) and so only tells a little bit about the engine. An engine performance curve, generated by by taking torque readings at a sequence of RPMs, will give more insight into the performance of a car.
    For a detailed discussion of horsepower and torque and how they relate to cars, see Vettenet's Torque and Horsepower Primer
    Power and Top Speed
    It takes a certain amount of power to push a particular car through the air due to aerodyamics, and friction of the tires agains the road. For a Datsun 1200 coupe or sedan, it takes about 35 rear-wheel-horsepower to push the car along at 90mph (140 kph).
    Torque and HP conversions
      <li>Nm = ft. lbs. * 1.38273</li> <li>SAE HP= kW * 1.341</li> <li>Torque = Horsepower x 5252 / RPM</li>
    What is SAE?
    SAE is the Society of Automotive Engineers. Their standard is used by the auto manufacturers. Prior to about 1971, the SAE Gross rating (aka bph - brake horespower) was used. This was the engine without accessories. Since about 1971 the Net SAE rating has been used. This is the engine with all accessories (alternator, air cleaner, etc) as fitted in the car, so it is more realistic. Both SAE ratings are based on an engine dynamometer (not a rear-wheel dyno). The "brake" is referring to the dyno's putting a retarding force on the engine.
    Rear Wheel Horsepower
    With rear-wheel HP there are standards sometimes used, but the "chassis" dynos which measure rwhp are notoriously uncalibrated. So comparing rwhp figures is to be taken with a grain of salt.
    If the horsepower is measured according to certain standards, then it tells you something about how the HP number was arrived at. For a long time, new car manufacturers have been using JIS, DIN or SAE measurements to ensure the number is accurate even on different engine dynos. For 2007, a new improved SAE standard is making the measurement even more precise. A lot of engines were de-rated about 5 HP (e.g. Honda) while Fords were generally unchanged and a few even were uprated a touch.
    This means you can generally have good faith in new-car manufacturer's power number (as least in USA where the new standard is used).
    When measuring rwhp, the dyno operator needs to factor in an appropriate loading weight for the dyno rollers. If done correctly, the resulting HP number should theoretically stand alone, independent of weight.
    Another way to look at it, theoretically 200 HP is 200 HP, whether put out by a turbine engine, rotary engine or piston engine. Or even an electric motor. Yet as others pointed it, the HP alone doesn't tell you how fast a car will accelerate. For that you need other factors, especially weight (lighter cars accelerate faster than heavy cars with the same engine). And then suspension setup has a huge effect on the first 60 feet of acceleration (cars that spin the tires too much accelerate slower, all else being equal). For top speed, HP alone is a good indicator, while the "power band" (average hp over a wide RPM range) affects acceleration: for example a supercharged engine which typically makes high power at low, medium and higher RPM will out-accelerate a modified engine of the same size -- even when both make the same peak HP (this is because modified non-turbo/non-blower engines make little HP at low RPM).
    Size Comparison
    Size is not a performance item, but it is the single most important factor for weight, which is directly related to performance. Less weight = Faster acceleration.
    Overall Length (Coupe, USA models)
    • Mini: 3630 mm, 143 in (11'9")
    • Mini: 3700 mm, 148 in (12'4") (2007 model)
    • B110: 3825 mm, 150 in (12'6")
    • B210: 4065 mm, 160 in (13'4")
    • B310: 4190 mm, 165 in (13'9")
    Overall Width: (Coupe, USA models)
    • B110: 1515 mm, 59.6 in (5'0")
    • B210: 1545 mm, 60.8 in (5'1")
    • B310: 1580 mm, 62.2 in (5'2")
    • Mini: 1690 mm, 66.5 in (5'6")
    New Mini stats from wikipedia:MINI (BMW)
