Valve springs
Revision as of 09:02, 16 July 2016; view current revision
Category: Valvetrain
The A12 engine in the Datsun 1200 uses traditional coil springs for each valve. The A12GX Engine uses dual springs on each valve.
Specs and Testing
* Free Length: 46.5 mm (1.831 in)
* Valve Closed: 38.7 mm at 23.9 kg (1.524 in at 52.7 lb)
* Valve Open: 30.2 mm at 58.5 kg (1.19 in at 129 lb)
  1. Measure the free length and the tension of each spring. If the measured value exceeds the specified limit, replace the spring.
  2. Check each spring for deformation with a square. Any springs with excess deflection must be replaced.
* Squareness deformation limit: 1.6 mm (1.3 for dual springs)
Nissan Part Numbers
* 13203-H1000 SPRING-valve, outer ALL except GX
* 13205-18000 SEAT-valve spring ALL except GX
* 13209-H2301 RETAINER-valve spring ALL [all after 1973]
* 13210-73400 COLLET-valve
* 13210-H1000 COLLET-valve (from 72-2)
* 13210-U0100 COLLET-valve (from 71-10)
** All three collet PNs interchange
* 13219-H1000 SHROUD-valve, inner ALL except GX
GX-specific
* 13203-H2300 SPRING-valve, outer GX
* 13203-H2301 SPRING-valve, inner GX
* 13205-H2300 SEAT-valve spring GX
Valves & Seals
See main article: Valves
Racing Valve Springs
For RPMs in excess of stock (higher than 6400 RPM) use racing valve springs
* Stock springs are good to 6000 rpm
* Factory GX springs are good to 6400 rpm
* Tomei
* Iskenderian 455-JA-006 needs dual spring retainers, MAX RPM 10,000
18258.jpg 18703.jpg 19821.jpg 20353.jpg 20747.jpg 21686.jpg 21687.jpg 23378.jpg 23647.jpg 23648.jpg 23649.jpg 23734.jpg
