Turbo Inlet Manifolds
Revision as of 11:52, 18 August 2016; view current revision
Category: Forced Induction
Intake manifolds for a Turbo engine. For more airflow, a higher flowing carb, intake, heads (ports and valves) and exhaust system is beneficial. Supercharging will increase power on a stock engine, but increasing the airflow capability of the engine will bring your blown engine to its full potential
A15 Turbo using factory Twin Hitachi manifold
17526.jpgAlbum click to view
Stock manifold with carburetor hat -- see #Boxed Carburetor
21572.jpgAlbum 21572
Tuned-port Intake
661.jpgAlbum 661
Log manifold
4862.jpgAlbum 4862
Log Manifold
20267.jpgAlbum click to view 20268.jpgAlbum click to view 20269.jpgAlbum click to view
UM-1 Manifold
301.JPGAlbum 301
Ram plenum manifold
652.jpgAlbum click to view 653.jpgAlbum click to view 654.jpgAlbum click to view
clyon's A-series Turbo Manifolds
7952_51415765a064e.jpgPost 432220 7952_514157d6a5905.jpgPost 432220 7952_5156836ba4deb.jpgPost 432220
This kind of stock manifold-runner is limited in horsepower. The turbo can force more air through it (for more HP) but the air temp will escalate, limiting the power to be made.
21086.jpgAlbum 21086
Tuned Runner Length
For scavenge effect at 5000 RPM, the runners should be 20" long!
23939.jpgAlbum 23939
Optimum runner length vs RPM 408161
Stock Manifold
Blow-through systems can use the stock Intake Manifold.
526.jpgAlbum 526
Stock manifold with EFI throttle body
6746_551625dbea3e4.jpgPost 465360
Top-hatted Carburetor
Blow-through system feeding carb top-hat
519.jpgAlbum click to view
Weber 32/36 Carburetor with custom top hat
21572.jpgAlbum 21572 21573.jpgAlbum 21573
This was a popular OEM method. phunkdotaspok say the stock Hitachi can handle 10 psi with a good top-gasket seal. In an NA application, a warped top is not a problem, as there is no pressure in the float chamber. This only becomes important in boosted application.
downdraft Dellorto carburetor
21056.jpgAlbum 21056
Weber 32/36 Carburetor hat
22271.jpgAlbum 22271
Boxed Carburetor
Boxing carb. This allows a more or less stock carb to be used, the outsided pressure balancing the inside pressure
Inside the box
535.jpgAlbum 535
datto1000wagon
18884.jpgAlbum 18884 18885.jpgAlbum 18885
16585.jpgAlbum click to view 16584.jpgAlbum click to view 16583.jpgAlbum click to view 16582.jpgAlbum click to view 16563.jpgAlbum click to view 16562.jpgAlbum click to view 16561.jpgAlbum click to view 16560.jpgAlbum click to view
