Disc
- SIZE ID: 13/16
- SIZE OD: 7 1/8
- TEETH: 18T
Service Specifications:
- Deflection limit: 0.5 mm at 85 mm radius
- Height Diagphragm spring end: 29-31 mm at 62 mm diameter
- Facing depth to rivets: 0.3 mm or better
Clutch Release Bearing (release bearing, throwout bearing)
- Bore = 1.5748
- Outer Diameter = 2.8898
- Width = 0.752
Throwout Bearing
Mechanical Clutch (RHD)
- Withdrawal lever
- Return spring
- Release bearing
IMPORTANT Grease these locations:
Hydraulic Clutch (LHD)
See Hydraulic clutch
Bearing Sleeve
Discussion: Clutch Problems
For use with A12 Flywheel on A14 engine, use the longer Sleeve:
Or make your own longer sleeve:
Or just use the A14/A15 flywheel. People like the A12 flywheel because it is lighter, but you can lighten the A14 type.
Datsun Sleeve ID:
Pilot Bushing
Dimensions:
- O.D.: 0.671"
- Width: 0.723"
- Bore: 0.48"
Interchange: All A-series engines
- 1971 - 1973 B110
- 1974 - 1978 B210
- 1979 - 1982 B310
- 1976 - 1978 F10
- 1979 - 1981 N10
- Nissan 32202-18000
- Timkin PB22 $0.90
- Timkin PB21 $1.57
- Dorman 14678 $5.99
- Dorman 690051
- BCA/NATIONAL Part # PB21 $5.53
Adjustment
- Hydraulic clutch: See Hydraulic clutch adjustment
- Cable clutch: as follows
<Hey you Aussies, help by expanding this! How exactly do you adjust a Datsun 1200 cable clutch?>
On transmission: 3-4 mm play. Inside: pad height (139.5-143.5 mm from floor). Then check pedal free play -- it must have free play to avoid burning out the clutch -- check with fingertips). Pedal play is 11-15mm
Details are in the Datsun 1200 Factory Service Manual or any Repair manual (Gregory's, etc).
Clutch Kit (Clutch Pressure Plate & Driven Disc)
- 180mm Diameter (7-1/8" Diameter); 18 Splines, 13/16"
- BECK/ARNLEY 0619114 $78.89
- ACDELCO 381622,88989662, 88989662 $83.79
- RHINO PAC 06001
Nissan
- 1974 PRESSURE PLATE A13, 694 pounds (315KG)
- 30100-H5000 DISC. 18cm diameter
- 30210-H5220 420KG (926 lbs) NISMO HIGH-PERFORMANCE PRESSURE PLATE for A12, A12A
- 30210-A1200 550KG (1213 lbs) NISMO HIGH-PERFORMANCE PRESSURE PLATE for A14, A15
- CF420507 for A14
- Ball Bearing Bore=1.5748" Outer Diameter=2.8898" Width=0.752"
- BCA 01576 $21.89
- TIMKEN DNB01576C
Pilot Bushing
- Bushing O.D.=0.671" Width=0.723" Bore=0.48"
- BCA/NATIONAL PB21 $5.53
Clutch Alignment Tool (wood, plastic or metal)
- O.D. 13/16", 18 Splines
- DORMAN 14502 $2.58
RHD Clutch Cable
- 30670-H1001 CABLE ASS'Y-clutch operating B110
- small clutch cable hole in transmission [83 cm length]
- 30670-H5001 CABLE ASS'Y-clutch operating B210 all
- 1-inch clutch cable hole in transmission
- 63-series transmission JDM used hydraulic clutch
- 30670-H8500 -7909 B310 [bracket, no nut]
- 30670-H8510 7909- B310, 8110- Van
- 30670-G1600 7510-8304 B120
- 30670-G1601 8305-8910 B120
- 30670-G1500 8910- B120
Apparently 1973-up cables interchanges. 1970-1973 are smaller.
- 1982-1986 Stanza CA20 40.25 inches, BECK/ARNLEY Part # 0930558, ATP Part # Y348 #30670D2801, DORMAN Part # 14850 {TECHoice}
- 1983 Sentra E15 BECK/ARNLEY Part # 0930556, ATP Part # Y327 {Clutch Cable / 29.5 inches #3067004A00}, DORMAN Part # 14849 {TECHoice}
Suppliers
- Centerforce Clutches (USA)
- http://www.clutchnet.com (USA) lists B210 and 210 parts (which will fit the 1200)
