Brakes
Revision as of 18:42, 14 August 2009; view current revision
Category: Brake System
Datsun 1200s came with two brake systems: all drums, or front disc with rear drums. They were excellent brakes for the period.
Also see:
Types
The 1200 front-disc/rear-drum system was good for 1971. In fact, stopping power was better than most 'muscle cars' of the era. However, if you have a drum/drum system, you'll want to upgrade to disc/drum. The drum system stops well enough, but the disc system has less fading going down mountain roads.
Calipers
Caliper bolt spacing:
  • ~84 mm: B110, and all 12" wheel B210 and B310
  • 88.9 mm: B310 large struts for 13" wheels
Rotor Sizes
Dia. (mm)Part NumberSource
212.540206-H1006B110, B210 with A12 1974, 1975
220 (AN18)40206-H7500B210 A12 1976-1978,B310 with 12" wheels
23240206-A1155B210 A13, PB110?, PB210 early?
245 (AN20)40206-U6700A10, B210 A14, B310 A14/A15, PB210 late?
??B210 Australia-assembled
? (Girlock)?A10, Australia-assembled
Rear Drum Brakes
The same rear brake drum was used 1967-1994. It is an 8" diameter cast iron drum, that fits 1-3/4 wide brake shoes. Sunny Trucks started using a different brake shoe from Oct 1989.
Finned Alloy Brake Drums
  • The fins look like structural type, not cooling type.
quote
Datsun Competition Dept supplied it's favoured teams with many experimental parts that were never sold over the counter. 1200s had alloy drums and calipers fitted as wellas the alloy diff heads from the wagons.
  • Finned drums like these were offered by Datsun Competition in Japan.
brake cylindersB110 (disc)1977 US B2101980 US B310 (Disc-AN20)1980 Canada A12A (Disc-AN18)
Proportioning valvenot usedyes1,961 kPa x 0.4 psi1,961 kPa x 0.4 psi
Booster (Master-Vac)not used?M60 6-in diameter 135mm rod length (flange-to-pedal)M60 6-in diameter
Master diameter11/16 inch3/4 inch13/1613/16
Front cylinder diameter1.894 inch (drum brakes: 11/16)2.012 inch2.012 inch1.894 inch
Rotor diameter212.5 mm245mm245mm220mm
Pad (width x length)42.5 x 53.1 mm41.2 x 63.4 mm41.2 x 61.4 mm42.0 x 56.8 mm
Pad thickness10.310.010.010.3
Total front braking area (discs)14.0 sq in16.2 sq in~14.6~13.8
Total front braking area (drums)42.3 sq inn/an/an/a
Rear cylinder diameterdisc brake models: 11/16 inch (all-drum models: 13/16)13/16 inch13/1613/16
Drum diameter8.0 inch8.0 inch8.08.0
Drum width1.378 inch1.378 inch1.3781.378
Total rear braking area42.3 sq in42.3 sq in42.342.3
http://www.rockauto.com
Front Brake Hoses
  • Length=11" End A Size=M10X1 End B Size=M10X1
  • RAYBESTOS BH36892; DORMAN H96862; ACDELCO 18J2188, 18J126, 19173109
Rear Brake Hose
  • Length=13.188" End A Size=M10X1 End B Size=M10X1
  • RAYBESTOS BH36866; DORMAN H36866
Pads
Small Pad (58 mm for 212mm rotor) Fits:
  • 1971-1973 B110
  • 1973-1974 Civic USA
  • 1976-1978 F10 USA
  • 1979-1982 N10 (Datsun 310) USA
  • 1978-May 1979 PA10 Stanza GL, GLX
Raybestos PGD104, Wearever D41, Bendix D104, Beck/Arnley 0880100D?, ACDELCO 17D104 (18028686), ACDELCO ACD39, ACDELCO ACD122
Medium Pad (for 220mm rotor) fits:
  • B310 A12A Canada (220mm AN18 rotor)
Beck/Arnley 0820100 Premium Organic $9.18
Large Pad (63.5 mm for 245 mm rotor) RockAuto for AN20 rotor PartsAmerica fits:
  • 1974-1978 Datsun B-210
  • 1975-1979 Civic USA
  • 1977-1979 Datsun 200SX (S10)
  • 1979-1982 Datsun 210 (B310) USA
  • 1975-1976 Datsun 610
  • 1975-1977 Datsun 710
Raybestos SGD117, PGD117 or RPD117, Beck/Arnley 0870944, 0820944 or 0880944D, Wearever D103, Bendix D103, ACDELCO 17D117 (18028692)
D103 also D113. KD-29, MK D1008, AK A-33K
Rear Brake Shoe
set (8 x 1-3/8, fits B110, B210 and B310)
  • RAYBESTOS 371PG $15.36
  • WAGNER PAB371 $16.52
  • ACDELCO 17371B $19.02
  • WAGNER BD60368 $39.89
Rotor
  • Front disc inner wheel bearing {Taper Bearing Assembly / Cone Length=0.5906 Bore=0.9843 Outer Diameter=2.0472 Width=0.6398 Cup Length=0.5118 Cone Radius=0.06 Cup Radius=0.06}
    • BECK/ARNLEY 0513809 $13.61
    • BCA 30205 $14.73
Wheel Bearings
Rockauto.com
FRONT INNER
Same bearing is used on drum brakes and disk brake hubs.
Nissan 52 mm O.D.
  • 40210-H1000 ASSY-BEARING FRONT WHEEL INNER from 0570
  • 40210-18000 ASSY-BEARING FRONT WHEEL INNER to 0470
    • BCA/NATIONAL 30205
    • TIMKEN 30205M
Specs: Taper Bearing Assembly
  • Cone Length=0.5906"
  • Bore=0.9843"
  • Outer Diameter=2.0472"
  • Width=0.6398"
  • Cup Length=0.5118"
  • Cone Radius=0.06" Cup Radius=0.06"
FRONT OUTER
Nissan 42mm O.D.
  • 40215-H1000 ASSY-BEARING FRONT WHEEL OUTER from 0570
  • 40215-18000 ASSY-BEARING FRONT WHEEL OUTER to 0470
    • BCA/NATIONAL 30302
    • TIMKEN 30302
  • Cone Length=0.5118"
  • Bore=0.5906"
  • Outer Diameter=1.6535"
  • Width=0.561"
  • Cup Length=0.4331"
  • Cone Radius=0.06"
  • Cup Radius=0.06"
Rear Wheel Bearings
See Axle Shaft. These are not easily replaced.
Caliper
  • Bore Size=1.89" Inlet Thread=M10X1 Bleeder Thread=M10X1
  • Right: RAYBESTOS FRC3021 $30.79, RC3021, A-1 CARDONE 19124, 17124
  • Left: RAYBESTOS FRC3022 $30.79, RC3022, A-1 CARDONE 19125, 17125
Parking Brake Cable
  • 48-1/4" Overall Length, 2 Per Car
  • RAYBESTOS BC92888 $39.79
  • ACDELCO 18P154, 18033072 $48.79
Master Cylinder
  • Bore Size=11/16" Number of Ports=2 Primary Outlet Size=M10x1 Secondary Outlet Size=M10x1
  • A-1 CARDONE 111655 Remanufactured $26.79
  • RAYBESTOS MC39087
  • ACDELCO 18M1072, 19106858
B120
Front Disk Brakes from 8910. These are unique as they fit the same strut as the former drum brake setup.
  • 41060-G1985 PAD KIT-DISC BRAKE [Nissan/Subaru]
  • 41001-G1500 CALIPER ASS'Y-FRONT RH W/O PADS OR SHIMS [Floating caliper]
  • 41121-05A10 PISTON-CYLINDER $31.23 [~1.8 inch (~45.2 mm)]
  • 47210-G1500 BOOSTER ASSY-BRAKE
  • 40207-G1501 ROTOR-DISC BRAKE, FRONT [about 8"? (203 mm)?]
Master cylinder has two bolts in horizontal plane; previous drum brake system used two bolts in vertical plane (like B110).
Same as these?
  • GBP666
    • CHERRY 1.0 1.3 1.3VAN 1.5 DE 09/82 A 08/86
    • CHERRY 1.5TURBO DE 09/82 A 05/84
    • CHERRY 1.6 DE 09/85 A 08/86
    • SUNNY 1.0 DE 06/86 A 10/88
    • SUNNY 1.3 DE 05/82 A 05/89 + 1.3 KOMBI DE 05/82 A 08/90
    • SUNNY 1.4 DE 10/88 A 12/90
    • SUNNY 1.5 DE 05/82 A 09/88 + 1.5 KOMBI DE 09/83 A 05/86
    • SUNNY 1.6 1.6COUPE DE 08/86 A 05/89
    • SUNNY 1.6I 1.6I COUPE DE 10/88 A 09/90
Rear Drum Brake Shoes
  • 44060-G0300 SHOE ASSY-REAR BRAKE SHOE 7510-7611
  • 44060-G0325 7612-8910
  • 44060-G1225 8910-
  • 43206-18000 DRUM BRAKE-REAR
Disc pads
For Sunny Truck
  • Tockico Stopal XN289
  • Stopping Revolution (SR) SR289 B122 8910-
    • 4996327027218, SRPF159N
  • Endless ES149NA
  • D-Speed DP071
Akebono
  • akebono.jpg 1216594955
Kashiyama
  • kashiyama.jpg 1216595007
Friction Materials
  • FMSI 782-D41
  • FMSI 7059 (D41) Nissan, Honda
  • FMSI 7039 (D103) Nissan, Honda
    • 1976-1982 Cherry
    • 1980-1982 Pulsar
    • 1970-1974 1200
    • 1974-1976 B210
    • 1979-1981 Sunny
    • 1972-1979 Civic
    • 1969-1970 S800
  • FMSI 7040 (D104)
  • FMSI 7064-D113
