Tail lights, tail lamps, or as Nissan calls them "rear combination lamps", combines the running lights, brake lamps (stop lights) and turn-signal lamps (blinkers). USA lights have no yellow section as it was forbidden by US law in the 1970s.
Sedan
Facelift
1972 Japan-market models had new tail lamps:
Coupe
Coupe tail lights have a silver, light gray, or dark gray surround in the chromed rim.
Custom
Wagon
1000
See main article: B10 Lights
Pickup
Datsun 1200 (Pickup) has three-segment rear lamps:
- Bottom section is clear for backup lights, 23W single filament bulb
- Middle section is red for running lights, 23W/8W dual filament bulb
- Top section is for turn signals: Red for older ones, Yellow or newer models.
- 23W single filament bulb, same as bottom section
- Aftermarket clear lenses are available, which use yellow bulbs
The lens frames were offered in various styles:
- Chrome through 1978 March
- Black from 1978 April
- 1971-1977: were originally silver
- 1978-1989: changed to black
Wiring early - Spade connector
Wiring late - Pin connector (positive locking)
- 26550-G1001 LAMP ASSY-REAR COMBINATION, RH -7803 [chrome]
- 26550-G1060 LAMP ASSY-REAR COMBINATION, RH 7804-8608 [black]
- 26550-G1900 LAMP ASSY-REAR COMBINATION, RH 8608- [black]
- 26555-G1001 LAMP ASSY-REAR COMBINATION, LH -7803 [chrome]
- 26555-G1060 LAMP ASSY-REAR COMBINATION, LH 7804-8608 [black]
- 26555-G1900 LAMP ASSY-REAR COMBINATION, LH 8608- [black]
- 08310-41620 screw, 8 needed per side
- 26521-G1000 LENS-COMBINATION LAMP, RH [top lens]
- 26541-G1000 LENS-REVERSE LAMP, RH [bottom lens]
- 26561-G1001 LENS-COMBINATION LAMP, TAIL & STOP, RH [Japan, middle lens]
- 26552-G1000 RIM-COMBINATION LAMP, RH [Chrome] -7803
- 26552-G1060 RIM-COMBINATION LAMP, RH [Black] 7804-
- 26557-G1000 RIM-COMBINATION LAMP, LH [Chrome] -7803
- 26557-G1060 RIM-COMBINATION LAMP, LH [Black] 7804-
- 26553-G1000 PACKING-LAMP, RH [gasket]
- 26558-G1000 PACKING-LAMP, LH [gasket]
- 26563-G1000 HARNESS ASSY-REAR COMBINATION -7803 [spade connectors]
- 26563-G1060 HARNESS ASSY-REAR COMBINATION 7804-8608 PIN CONNECTOR
- 26563-G1900 HARNESS ASSY-REAR COMBINATION -8608
Export
JDM vs Export
Round reflector section varies in size
輸出用 - Export , small reflector
国内 - Domestic, larger reflector
Aftermarket Ute
Custom
ストップラ ランプ レンズ ウインカー テールレンズ テール レンズ
