Tail Lights
Revision as of 05:12, 8 November 2009; view current revision
Tail lights, tail lamps, or as Nissan calls them "rear combination lamps", combines the running lights, brake lamps (stop lights) and turn-signal lamps (blinkers). USA lights have no yellow section as it was forbidden by US law in the 1970s.
Sedan
Facelift
1972 Japan-market models had new tail lamps:
  • 26550-H3101 LAMP ASS'Y-rear combination (R.H.)
  • 26555-H3101 LAMP ASS'Y-rear combination (L.H.)
    • 23W bulb (4)
    • 23/8W bulb (2)
    • 3.4W bulb (2)
  • 26552-H3101 RIM ASS-Y (2)
  • 26553-H3101 PACKING ASS'Y (2)
  • 26551-H3101 LENS ASS'Y (R.H.)
  • 26556-H3101 LENS ASS'Y (L.H.)
Coupe
Coupe tail lights have a silver, light gray, or dark gray surround in the chromed rim.
Coupe vs Sedan
Custom
Wagon
Repair
1000
See main article: B10 Lights
Pickup
Datsun 1200 (Pickup) has three-segment rear lamps:
  • Bottom section is clear for backup lights, 23W single filament bulb
  • Middle section is red for running lights, 23W/8W dual filament bulb
  • Top section is for turn signals: Red for older ones, Yellow or newer models.
    • 23W single filament bulb, same as bottom section
    • Aftermarket clear lenses are available, which use yellow bulbs
The lens frames were offered in various styles:
  • Chrome through 1978 March
  • Black from 1978 April
  • 1971-1977: were originally silver
  • 1978-1989: changed to black
Gasket
Wiring early - Spade connector
Wiring late - Pin connector (positive locking)
2785.jpg 2851.jpg 2852.jpg 2994.jpg 5355.jpg 16760.jpg 16887.jpg 17561.jpg 18255.jpg
  • 26563-G1000 HARNESS ASSY-REAR COMBINATION -7803 [spade connectors]
  • 26563-G1060 HARNESS ASSY-REAR COMBINATION 7804-8608 PIN CONNECTOR
  • 26563-G1900 HARNESS ASSY-REAR COMBINATION -8608
Right Hand
  • 26550-G1001 LAMP ASSY-REAR COMBINATION, RH -7803 [chrome]
  • 26550-G1060 LAMP ASSY-REAR COMBINATION, RH 7804-8608 [black]
  • 26550-G1900 LAMP ASSY-REAR COMBINATION, RH 8608- [black]
    • 08310-41620 screw, 8 needed per side
  • 26521-G1000 LENS-COMBINATION LAMP, RH [top lens]
  • 26541-G1000 LENS-REVERSE LAMP, RH [bottom lens]
  • 26561-G1001 LENS-COMBINATION LAMP, TAIL & STOP, RH [Japan, middle lens]
  • 26552-G1000 RIM-COMBINATION LAMP, RH [Chrome] -7803
  • 26552-G1060 RIM-COMBINATION LAMP, RH [Black] 7804-
  • 26553-G1000 PACKING-LAMP, RH [gasket]
Left Hand
  • 26555-G1001 LAMP ASSY-REAR COMBINATION, LH -7803 [chrome]
  • 26555-G1060 LAMP ASSY-REAR COMBINATION, LH 7804-8608 [black]
  • 26555-G1900 LAMP ASSY-REAR COMBINATION, LH 8608- [black]
  • 26526-G1000 LENS-COMBINATION LAMP, LH [top lens]
  • 26546-G1000 LENS-REVERSE LAMP, LH [bottom lens]
  • 26566-G1001 LENS-COMBINATION LAMP, TAIL & STOP, LH [Japan, middle lens]
  • 26557-G1000 RIM-COMBINATION LAMP, LH [Chrome] -7803
  • 26557-G1060 RIM-COMBINATION LAMP, LH [Black] 7804-
  • 26558-G1000 PACKING-LAMP, LH [gasket]
Export
JDM vs Export
Round reflector section varies in size
輸出用 - Export , small reflector
国内 - Domestic, larger reflector
Aftermarket Ute
White?
Clear
1783.jpg 1948.jpg 1949.jpg 2137.jpg 9306.jpg 14390.jpg 15841.jpg 17087.jpg 17088.jpg 20376.jpg 20377.jpg 20381.jpg
Custom
ストップラ ランプ レンズ ウインカー テールレンズ テール レンズ
