Timing Chain
Revision as of 07:44, 18 December 2009; view current revision
Category: Engine Mechanical
The Timing Chain drives the Camshaft.
Also see: Timing Cover
  • We have seen a couple of single link timing chains on A12, which is probably the original A10 single row chain. Insist on the factory specified double-chain, like Nissan did for later A10s.
  • A rattle can be the trait of a stretched timing chain. Pinging/pinking has also often been mistaken for timing chain rattle
A-series engine has a short timing chain -- and with an automatic adjuster -- it rarely stretches or goes bad.
Compare to the loooooong chaing used in the Nissan KA24E engine:
  • KA24 often has timing chain problems
Replacement
Alignment
3639.jpg http://datsun1200.com/modules/myalbum/photos/thumbs/3640jpg
The timing chain kit (timing set) includes: Cam, Crank, Chain, Tensioner
Cam Sprocket
(38 teeth)
Chain
  • 0240226-1.jpg $17.99, Partsamerica.com
Tensioner
Crank Sprocket
19 teeth
