Flywheel
Revision as of 21:59, 10 December 2011; view current revision
Categories: Clutch | Engine Mechanical
Datsun 1200 uses a traditional type of flywheel at the back of the engine. The face matches the Clutch while a ring gear is attached to the perimeter for the Starting Motor to turn the engine. It uses a 271mm (10.7 inch) flywheel with a 105-tooth ring gear.
All flywheels for A-series engines interchange -- for rear-wheel drive vehicles. The A12 flywheel weighs 2.2 lbs (1 kg) less is the main difference. The A12 flywheel is also thinner.
  • A12 12310-H1000: 9.7 kg (21.0 pounds as measured)
  • A12 12310-H2310: 6.4 kg (14.1 pounds) GX, also sold as 'Race Option'
  • A14 12310-H7200: 10.7 kg (22.3 lbs)
A14/A15 flywheel is thicker than the A10/A12 flywheel. When fitting the thinner flywheel to A14, remove the Engine Plate to compensate.
  • A12: 28 mm thick
  • A14: 30 mm thick
In 1974 flywheel bolts changed from British Threads to Metric threads. So the bolts are not interchangeable from early to late. See Crankshaft for details.
A12 Flywheel Measurements:
thickness: 28mm
ring gear + backing: 20mm
back rim to flywheel face depth: 5mm
clutch face to inner face depth: 17mm
Lightening
For race cars, a light flywheel allows the engine to rev faster according to this principle:
The more weight, the more time it takes to accelerate
Now a street car wants a heavier flywheel, so that it will:
  • smooth out the combustion pulses
  • smooth out the drivetrain
These are the factory specs for flywheel weight reduction:
Finished wheight is about 6.5 kgs --a total of 2 kgs removal
Reference: Datsun B110 Competition Tune-Up Manual, Nissan Motor Co. Ltd., Tokyo Japan 1974
Bolts
Nissan flywheel bolts are very strong. Just clean the threads and use a torque wrench to install.
If using the A-series over 7500 RPM, run new factory bolts and Loctite them.
If using a very light flywheel, look at getting the crank flange dowelled. The flywheel is actually clamped on the head of the bolt not on the shank of the bolt (there is side-to-side play), so three dowels 120° apart should do the job. The end of the crank is soft unlike the journals and easy to drill.
  • 12310-18001 ASS'Y-FLYWHEEL B10
  • 12310-18002 ASS'Y-FLYWHEEL B10 (from E/# A10-87871)
  • 12310-H1000 FLYWHEEL ASS'Y A12, A12S, A12A, A13S
  • 12310-H6200 ASSY-FLYWHEEL A13
  • 12310-H7200 FLYWHEEL ASS'Y A14 -7909
  • 12310-H7201 FLYWHEEL ASS'Y A14 7910-8010
  • 12310-H8900 FLYWHEEL ASS'Y V A14S, A15 8011-
  • 12310-H8910 FLYWHEEL ASS'Y A14S, A15 8011-
  • 12315-18001 BOLT-flywheel & drive plate (from E/# 87871) (6) B10
    • 12314-18002 WASHER-flywheel
    • replaced 12315-18000 BOLT-flywheel & drive plate (6) B10
      • 12314-18001 WASHER-flywheel
  • 12315-H1001 BOLT-flywheel (6, 3/8") B110 -1973
  • 12315-H6200 BOLT-FLYWHEEL (6, 10mm) 1974-
  • 12313-10600 DOWEL (3) all A-series A10-A15
  • 12312-18000 GEAR-ring, flywheel A10/A12/A14
  • 12312-18010 GEAR-ring, flywheel A14S 8110-
  • 32202-18000 BUSHING-pilot all A-series A10/A12/A13/A14/A15/A12A
The flywheel "Assembly" includes these parts:
* 12312 GEAR-ring, flywheel
* 12313 DOWEL-flywheel
501.jpg 1268.jpg 1481.jpg 2513.jpg 3923.jpg 4890.jpg 5326.jpg 5428.jpg 6110.jpg 6208.jpg 6209.jpg 7979.jpg 10428.jpg 11108.jpg
