Also see: Crossmember
B110 and B120
Front: 1970-1973 1200 engine tall crossmember (B110/B120)
Rear: 1974-up 1200 tall/short engine crossmember
Not only does the new-style engine have a lower mount, but the mounts are further back 35mm (~1-3/8"). These photos shows how far back:
Original B110 engine brackets:
right side (high-mount)
Two types of right-side brackets
- Top: original style
- Bottom: new style for revised crossmembers
- Allows fitment of reduction gear starters
- Starting with 1978 B210 USA (H8500)
- All B310 (H8500)
- Starting with 1985 B120 JDM (G1900)
NOTE: If you mix early engine with late crosmember (or vice-versa) you need some modications. In this case see A-series Engine Swaps.
Early Engine Mounting
1970-1973 Datsun 1200
- 11222-H1000 BRACKET-engine mounting, front (L.H.)
- Stepped mounting. Lower boss is farther out than upper boss
Late Engine Mounting
1974 and up engines are different, and 1974-up 1200s use a corresponding crossmember
- 11223-H5000 INSULATOR-ENGINE MOUNTING, FRONT 7510-8503 [8mm studs]
- 11223-G1900 INSULATOR-ENGINE MOUNTING, FRONT 8504- [8mm studs]
- High side mount (similar to earlier)
- 11221-H5000 BRACKET-ENGINE MOUNTING, RH 7510-8503
- 11221-G1900 BRACKET-ENGINE MOUNTING, RH 8504-
- Low side mount (new crossmembers)
- 11222-H5001 BRACKET-ENGINE MOUNTING, LH 7510-8503
- Same part for 74-up B120 (ute), B210 and B310
- 11222-G1900 BRACKET-ENGINE MOUNTING, LH 8504-
B10 Mounts
As you can see these are different from newer (B110, etc) mounts.
- 11122-18000 BRACKET-engine mounting front (L.H.)
- flat (unstepped) bracket
B210 Mounts
- 11223-H5000 INSULATOR-ENGINE MOUNTING FRONT V [? mm studs]
- 11223-H7500 INSULATOR-ENGINE MOUNTING FRONT [except] V [10 mm studs]
- 11223-H7300 INSULATOR-ENGINE MOUNTING FRONT USA 0974- [10 mm studs, A14 engine softer mounts] $30.47 USD
- replaces 11223-H7500
- replaces 11223-H6100 INSULATOR-ENGINE MOUNTING FRONT USA -0874 [? mm studs, A13 engine harder mounts]
- 11221-H7301 BRACKET-ENGINE MOUNTING, FRONT RH
- USA -0777
- USA 11221-H5000 BRACKET-ENGINE MOUNTING FRONT RH -0874
- USA 11121-H7300 BRACKET-ENGINE MOUNTING FRONT RH 0974-1074
- USA 11221-H8500 BRACKET-ENGINE MOUNTING FRONT RH 0877-
- Bracket notched for Reduction Gear Starter?
Right-side mount comparison:
Middle pair is B110 early, right is B210? (thin), left is B310? (thick)
B210 crossmember change for 1978 North America
B310 Mounts
The B310 insulators have a metal wrap in case the rubber breaks, the engine won't move too far.
- 11223-H9100 INSULATOR-ENGINE MOUNTING FRONT RH [10 mm studs] $34.38 USD
- 11224-H9100 INSULATOR ASSY-ENGINE MOUNTING FRONT LH $44.32 USD
- B310 insulators have a larger studs and locating pins, but otherwise are the same dimensions as B110 mounts.
- 11221-H8500 BRACKET-ENGINE MOUNTING, FRONT RH
- stronger, more rigid than ever - perhaps to reduce NVH (noise, vibration and harshness)
Upgraded Insulators
- "These are the heavy duty engine mounts we were talking about. Broken engine mounts are a common thing in rally cars and this fixes the problem. Mounts are polyurethane and come out of a ford cortina and last for years of competition...Part number MT8156N. Kelpro make them...I usually just go to a good parts place and ask for cortina engine mounts and this is what they give me. Maybe there are two types, these are about 70mm in dia."
- http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=34366&forum=1 One guy said: "you might want to look at the poly-urathene style mounts. I am using some of a Jag. The part number is at home. but they are heaps wider but no tallers, so they make a good direct replacement, plus they are high temp rated."
keywords マウント エンジン マウンテング
