Datsun 1200 uses a common wheel bolt-pattern: 4 bolt holes on 4-1/2 inch circle (aka 4-on-4.5). Nissan engineers specified this in inches. In metric this is equivalent to a 4 x 114.3 PCD (Pitch Circle Diameter). Stock Datsun 1200 wheels are 12 inch diameter, 4J (4 inches wide). All models, even GX models and 1994 Sunny Truck models, used 12" wheels. Only the Datsun 1200 SSS used a special wheel. Wheels up to 18x7 will fit under the stock bodywork.
Stock Wheels
- 12" diameter
- 4-inch wide
wheels | B10 | B110 | 1977 US B210 A14 | 1980 NA B310 |
size | 3-1/2 J-12 | 4 J-12 | 4-1/2 J-13 | 4-1/2 J-13 5 J-13 (aluminum) Canada w/A12A: 4J-12 |
offset | ? | 30 mm | 30mm offset | 30mm 25 mm (aluminum) |
tire size | ?-12 | 6.00-12 155SR-12 | 155SR-13 | 6.00-12 155SR13 175/70SR13 |
balance | 10gr or less (0.35 oz) | 11gr or less | 10gr or less | |
lugnut torque | 8-9kg-m (58-65 ft-lb) | 8-9kg-m | 8-10 |
NOTE: 1976-1978 B210 large-brake wheels are 13" but have 4mm extra diameter inside, possibly for clearance of the large brakes. These wheels are same as Datsun 610 and can be identified by six thin slots on the face.
Datsun Option Wheels
Datsun Sunny B310 factory OPTION B & OPTION C wheels: 13" x 5"
- 40300-N5825 WHEEL SET-ROAD ALUMINIUM, B TYPE (5JX13)
- 40300-W6625 WHEEL SET-ROAD ALUMINIUM, C TYPE (5JX13)
- Also used on 200SX (S10 silvia) 1977-1979
B310 Wheels
NOTE: These do not fit the B110 front hubs due to the shape of the wheel.
ホイール
510
510 came with 4x13 wheels (4.5x13 option?), and are often used on 1200s. Offset is +30(?).
Compatible Wheels
- Rear-wheel drive Toyota
- Chevrolet Corvair (5 x 13)
- pefect for the rear
- may need a 1/4 inch spacer on fronts to clear the brake caliper
- Datsun 240Z wheels -- 14"
- Uni-lug alloy wheels
- Rear-wheel-drive Mitsubishi
What WONT work:
- early Honda
- Isuzu/Holden Gemini
- Ford Escort/Cortina
- early Mazda
- Subaru
- some SAAB
S13 Rims
15" x 6" +40, 4 Lug, 4.5" Bolt Pattern, 10-hole USA * Base: 195/60R15 * SE: 205/60R15
10-hole Spare 15" x 4", 4 Lug, 4.5" Bolt Pattern
FWD Rims
- Acura Vigor 1991-1994
- Acura TC 1992-1995
- Ford Laser (KA to KH)
- Hyundai Excel
- Kia 2001- (67.1 center)
Saab Wheels
- 1979-1983 SAAB 900
Also same as Nissan Pintara. These are 14" wheels. aka "Pursuit" or "chaser" style rims as they are similar to police car (plain) steel wheels.
Don't pay more than $15 per steel wheel
The 5.5 wide R31 steelies should fit.
The stock 6" and 7" wide Sillouettes won't fit the B110 or early B210 disc-brake strut. If you run Stanza or 240K struts, then no worries.
TRX Wheels
Alloy wheels from Datsun 910 "Bluebird Series II" Australia TRX package work nicely on a Datsun 1200.
Discussion: will trx 15"rims fit straight onto 1200 ute without flaring?
"If I see another 1200 with TRX rims I'm going to smack you across the face!"
On standard Datsun 1200 struts they will require fairly low profile tyres, and quite large spacers for the front and it will need to stay at standard height. Even then you might find they are a tight fit and might grab the guard a bit if you hit any speed humps too quick or take corners quick.
If it is lowered at all you will need to roll the guards for sure!
With Stanza and other similar struts they fit no problem with 195/50R15 tyres and will only need to cut the front bottom corner out of the front guards for clearance when turning.
With Sunny (B310) struts on front and 195/50R15 tyres, it requires to roll all the guard lips, and run spacers on rear as they were scrubbing the inner guard and on all wheel arches the sharp lip all around the guard was tearing into the tyre slightly so rolled it right up.
Lug Nuts
M12x1.25 thread
- B210: 13/16" lug nuts
See main article Wheel Studs
Torque
- 8.0-9.0 kg/m (58-65 ft-lb)
Wheel Balance
Wheel Offset
STOCK = 30 mm offset
Scrub Radius
Largest Sizes to Fit 1200
17-inch diameter wheels easily fit the 1200. The key is: width of the tyre and overall height of the tyre. Even 18" wheels are being used on 1200s with stock bodywork, if a low-profile tire is used.
The wheel mainly positions the tire within the wheelwell. The tire is the part that will rub on the fender or rub on the spring.
To make maximum use of the wheelwell width, +30 offset works best with Datsun 1200.
Rear
- 9": 13 x 9 zero offset, tire 215/50r13
Ute Rear
There is more room under the rear of the Datsun 1200 pickup model, compared to the sedans, wagons and coupes.
Wheel Adapters
Wheel Spacers
If the offset is too negative, they will fit the fenders (guards) and there is nothing you can do except cut out the bodywork, perhaps fitting large flares.
Suppliers
Wreckers are your best bargain here ... lots of 13, 14, 15, 16 and 17" wheels and tires.
Manufacturers
- SSR Speed Star Wheels sells new and classic designs
- http://www.panasport.com
- Konig makes a retro-style wheel with the proper offset for RWD application. Konig Rewind
- Minilite Wheels - The real deal! alloy racing wheels 12x5 only $159 each in Silver, Black, White. Gold and Anthracite also available.
Mail order
- tirerack.com
- http://classicdatsun.com has Panasports
