AFRacer
Revision as of 08:12, 12 January 2016; view current revision
Categories: Engine Swaps | User Community
SR20DET-powered Datsun 1200 coupe. 'Nuf said.
Club member AFRacer built one of the first SR20 Turbo 1200s back in 2004-2005. He used an automatic-tunneled 1200 to make the fit easy.
Looking good with S30 fender mirrors
Hakosuka-style Air dam
Engine out
Intercooler, 26x9" air-to-air type fits between the grille and the radiator
Oil pan fits inside the sway bar like it was made for the 1200!
Clearance of steering gearbox on LDH 1200
Plenty of room
Donor
S13 "180SX" is a Silvia Coupe (RS13)
SR20DET
Engine in RS13, 3 April 2004
Engine Mounts
Firewall clearance
Room enough, Engine can go back another inch
Rear. Here's a pic from behind the engine in a automatic tunneled 1200. The coolant lines running behind the engine should be run elsewhere to allow more space behind the engine. Also the brake and fuel lines need to be redone from at least half way back so they're not inside the tranny tunnel
Left side. Plenty of room for headers, put a shield next to brake cylinder
Cooling System
Start with one A-series powered Datsun 1200
Remove the A15 engine
Remove radiator extension and battery tray
Stock RS13 radiator fits nicely
Consider changing water outlet to Pulsar SR20 straight type
Fuel System
The fuel system will consist of a high volume low pressure electric pump (Holley) sucking out of the gas tank into a surge tank, then the Walbro will suck out of the Surge Tank to the engine.
Walbro 255LPH inline fuel pump, high pressure for EFI and plenty of volume for high horsepower
Surge tank made from stock coupe tanklet
Upgrades
Greddy style intake, Nismo 555 cc injectors, Nismo fuel pressure regulator, and S15 T28 ball bearing turbo
Top-mount exhaust, not needed for a 1200
4.5" exhaust pipe, not needed
Brake System
The SR swap only adds a few hundred lbs to the car, so it doesn't necessarily require bigger brakes. However you will likely be going faster, so it's a good idea to upgrade the brakes. Use a large diameter rotor to increase braking leverage while reducing pedal force needed -- the S13 Brakes swap is the easiest way.
