Parts for 60-Series Transmissions are listed below. This includes 4-speeds and 5-speeds from B210 and B310 vehicles.
Part Number Prefixes
* H90 B310 unique to F5W60L * 180 B10 56-series * H73 B210 60-series
Case Comparo
B210 F4W60A * 32100-H7300 ASSY-CASE,TRANSMISSION B210 F4W60A 0974-0776 * 32100-H7302 ASSY-CASE,TRANSMISSION B210 F4W60A 0876-0377 * 32100-H8902 ASSY-CASE,TRANSMISSION B210 F4W60A 0477-
B310 F4W60 * 32100-H8902 CASE COMP-TRANSMISSION B310 F4W60 CANADA * 32100-H8903 CASE COMP-TRANSMISSION B310 F4W60 0879- USA * 32100-H9301 CASE COMP-TRANSMISSION B310 F4W60 0879- USA (supercedes 32100-H8903)
B310 FS5W60A * 32100-H9001 CASE COMP-TRANSMISSION B310 FS5W60A -0779 [FS5W60L, dogleg] * 32100-H9300 CASE COMP-TRANSMISSION B310 FS5W60A 0879- CAN (supercedes 32100-H9001) * 32100-H9301 CASE COMP-TRANSMISSION B310 FS5W60A 0879- FED, CAL (supercedes 32100-H9001)
F4W60L
rally cross of F4W60L Gear ratio * 1st: 3.19 * 2nd: 2.38 * 3rd: 1.89 * 4th: 1.00
F4W60 gears - B210 USA CATALOG 32200-H7300 ASSY-GEAR MAIN DRIVE 20T 32210-H7300 GEAR-COUNTER 31-27-20-15T 32220-H7300 GEAR-REVERSE COUNTER 14T 32230-H7300 ASSY-GEAR 1ST SPEED 34T 32250-H7300 ASSY-GEAR 2ND SPEED 28T 32260-H7300 ASSY-GEAR 3RD SPEED 24T 32280-H7300 ASSY-GEAR REVERSE IDLER 22T 32245-H7300 GEAR-REVERSE MAIN SHAFT 34T
Rebuild Kit
Synchro Kit adds includes five (5) brass BAULK RING. See Synchros
FS5W60L
The 60L 5-speed is unique:
- 5th gear is added to the front
- It's a modified 4-speed. The newer 60A is a re-designed gearbox, sharing fewer parts with the 4-speed
Reverse GEAR/HUB on end of output shaft
(large 1st gear below, small rev/idler gears to right)
Gearset
* 32241-H9001 SHAFT-MAIN * 32264-H7300 BEARING-NEEDLE MAIN SHAFT 2 * 32260-H9000 GEAR ASSY-3RD 27T * 32604-H9000 RING-BAULK 4* 32603-18000 RING-SYNCHRONIZER 4 * 32609-18000 INSERT-SHIFTING 6 * 32601-H9001 HUB SYNCHRONIZER-2ND & 3RD * 32606-18000 SLEEVE-COUPLING 2 * 32250-H9000 GEAR ASSY-2ND * 32253-H7300 BUSH-1ST GEAR (MAIN SHAFT) 2 * 32246-H7300 WASHER-THRUST * 32273-H7300 BEARING-(BALL,) MAIN SHAFT * 32246-H9000 WASHER-THRUST MAIN SHAFT * 32267-H7300 BEARING-(NEEDLE,) MAIN SHAFT * 32230-H9000 GEAR ASSY-1ST * 32602-32200 SPRING-SHIFTING INSERT (SYNCHRONIZER INSERT) 3 unique to F5W60L * 32608-H9000 INSERT-SHIFTING 9 * 32258-H9001 HUB SYNCHRONIZER-1ST & REVERSE * 32245-H9000 GEAR-REVERSE, MAIN SHAFT * 32234-H9000 RETAINER SHIFTING INSERT Catalog is incorrect * 32354-H9000 NUT-HEX (M25 X 1.0) * 32228-H9000 RING-SNAP OVERDRIVE BEARING [Or 00922-12200?] * 00922-12200 RING-SNAP (T=1.2)? [Or 32228-H9000?] * 32227-H9000 BEARING-(BALL,) MAIN SHAFT END * 32228-H9000 RING-SNAP,MAIN SHAFT END BEARING [Or 00922-12200?] * 00922-12200 RING-SNAP (T=1.2) [Or 32228-H9000?]
Select only one 32204 * 32204-H7300 RING-SNAP MAIN DRIVE GEAR SELECT T=1.34-1.40 * 32204-H7301 RING-SNAP MAIN DRIVE GEAR SELECT T=1.40-1.46 * 32204-H7302 RING-SNAP MAIN DRIVE GEAR SELECT T=1.46-1.52 * 32204-H7303 RING-SNAP MAIN DRIVE GEAR SELECT T=1.52-1.58 * 32204-H7304 RING-SNAP MAIN DRIVE GEAR SELECT T=1.58-1.64 * 32204-H7305 RING-SNAP MAIN DRIVE GEAR SELECT T=1.64-1.70 * 32204-H7306 RING-SNAP MAIN DRIVE GEAR SELECT T=1.70-1.76 * 32209-H7300 SPACER-BEARING MAIN DRIVE GEAR * 32214-H7300 RING-MAIN BEARING 2 * 32203-H7300 BEARING-MAIN DRIVE * 32200-H7300 GEAR ASSY-MAIN DRIVE * 32272-H7300 BEARING-PILOT MAIN SHAFT 1 of 3 Select only one 32263 * 32268-H9000 RING-SNAP SELECT T=1.60 * 32268-H9001 RING-SNAP SELECT T=1.65 * 32268-H9002 RING-SNAP SELECT T=1.70 * 32601-H9000-HUB SYNCHRONIZER-4TH & 5TH [Also F560A] * 32340-H9000 GEAR ASSY-OVERDRIVE * 32345-H9000 BEARING-OVERDRIVE GEAR (NEEDLE MAIN SHAFT) * 32219-H9000 BEARING-COUNTER SHAFT [Also F460A 7812-] Select only one 32224 * 32224-H7200 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.30-2.35 * 32224-H7201 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.35-2.40 * 32224-H7202 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.40-2.45 * 32224-H7203 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.45-2.50 * 32224-H7204 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.50-2.55 * 32224-H7205 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.55-2.60 * 32224-H7206 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.25-2.30 * 32224-H7207 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.20-2.25 * 32210-H9000 GEAR-COUNTER ASSY * 32219-H9010 BEARING-COUNTER SHAFT * 32220-H9000 GEAR-REVERSE COUNTER Select only one 32222 * 32222-H9003 RING-SNAP COUNTER SHAFT SELECT T=1.3 * 32222-H9004 RING-SNAP COUNTER SHAFT SELECT T=1.4 * 32284-H9000 WASHER-THRUST COUNTER SHAFT REAR [Mistake? See 32285N] * 32282-H9000 GEAR-REVERSE IDLER * 32272-H7300 BEARING-REVERSE IDLER GEAR 2 2 of 3 * 32285-H9000 SPACER-REVERSE IDLER GEAR * 32292-14600 PIN-RETAINING [Also F560A] * 32281-H9000 SHAFT-REVERSE IDLER * 32284-N9000 WASHER-THRUST REVERSE IDLER 2
Bearings
RockAuto.com
BALL BEARING - input shaft 32203-H7300 BEARING-MAIN DRIVE $31.78 USA * 62 x 30 x 11 mm * Inside Diameter:30 mm,1.1811 in * Outside Diameter:62 mm,2.4409 in * Width:16 mm,0.6299 in * C3:radial clearance greater than Normal Interchange * Timken 206L* SUZUKI 08163-62063 * SKF 6206ZNRJ * Nachi 6026N C3
BALL BEARING - counter shaft, rear 32219M 32219-H7300 BEARING-COUNTER SHAFT, REAR $95.28 USD replaced by 32219-H8900 Specifications: * 52 x 20 x 15 mm * Width 15mm, 0.591 in. * Bore 20mm , 0.787 * OD 52mm, 2.047 Interchange * Nachi 6304N * Timken 304WB * Timken 304DD (sealed) * National 304 (open)![]()
ENCLOSED BEARING - counter shaft, rear 32219 32219-H9700 BEARING-COUNTER SHAFT, FRONT * replaced by 32219-H9702 $22 USD
NEEDLE CAGE - output shaft, rear 32272 32272-H7300 BEARING-PILOT * replaced by 32272-G3201 $26.02 USD > 32272-14600, 32272-H7300 * Koyo RS18/17P * 18x24x17 mm needle roller bearing
32264M 32264-H7300 BEARING-NEEDLE MAIN SHAFT $38.43 USD Rear 60A National B1616 * Cone Bore: 25.400mm, 1.00 inch * Outside Diameter: 31.750mm, 1.250 inch * Width: 25.400mm, 1.00 inch![]()
NEEDLE CAGE - output shaft, rear 32350 BEARING-overdrive gear * 32345-H9000 60L 5-speed * 32345-H9702 60A
32283 32289-H9701 > 32289-H9700 BEARING-REVERSE IDLER GEAR $28.60 USD * 60L 5-SPEED (2) * 60A 5-SPEED (1)
60L 5-speed Bearings/Bushings
PowerTorque BK139 F4W60 $144 USD
FS5W60A
NTN 7E-BKS20X32X20-4 181410 DRAWN CUP NRB (CAGE TYPE)
60A 5-speed Gearset
full
Input shaft, Counter shaft, Reverse/Idle shaft
full
Output shaft
full
5th gear bolted to end of cluster shaft
Cluster shaft and free-gears (1st, 2nd, 3rd)
32604-H9700 Synchro BAULK RING & matching gear surface
Kit
O'Reilly Auto Rebuild Kits PowerTorque BK173WS w/synchros $254 USD PowerTorque BK173 w/o synchros $146 USD
Input Shaft Bearing
BALL BEARING-MAIN DRIVE (Input shaft) 30x62x16 * Nissan 32203-H7300 (type 6206) * Timken 206SL * Nachi 6206N FITS: 60L, 60A
Output Shaft Bearing
BALL BEARING - MAIN SHAFT (Output shaft, mid) 25x62x17 * Nissan 32273-H7300 * NSK 6305NR * SKF 43305C * Nachi 6305 N C3 150314 * Timken 305L FITS * 60 4-speed, 60L 5-speed, 60A 5-speed, 56A 4-speed
BALL BEARING - MAIN SHAFT (Output shaft, rear) 22x50x14 * Nissan 32227-H9700 [32275] * Nachi 62/22XA1 140827 (22x50x14 ball bearing)
NEEDLE BEARING - PILOT (output shaft, front) 18x24x17 mm * Nissan 32272-H7300
NEEDLE BEARING - MAIN SHAFT * Nissan 32264-H7300 (2) [32264M]
NEEDLE BEARING - MAIN SHAFT * Nissan 32267-H7300 (2) [32264]
NEEDLE BEARING - OVERDRIVE GEAR (input shaft, 5th gear) * Nissan 32345-H9702 [32350]
Cluster Bearings
60A 5-speed Bearings/Bushings
32219 BEARING-COUNTER SHAFT 32219-H9700 FS5W60A $95.28 USD * enclosed needle bearing (pilot bearing)?
32219M BEARING-COUNTER SHAFT 20x52x15 * Nissan 32219-H7300 * Timken 304WB * National 304 * Nachi 6304N CE 150525 (20x52x15 ball bearing) Fits * F4W60L * FS5W60A
32224 WASHER-THRUST COUNTER SHAFT FRONT * SELECT USE T=2.30 - T=2.25
32283 BEARING-REVERSE IDLER GEAR 32283 32289-H9701 > 32289-H9700 BEARING-REVERSE IDLER GEAR $28.60 USD * 60L 5-SPEED (2) * 60A 5-SPEED (1)
32287 WASHER-THRUST REVERSE IDLER 32265-18000 * F4W56 * FS5W60A
Thrust Washers
32287 32265-18000 WASHER-THRUST REVERSE IDLER [center] 32318 32287-H9700 WASHER-THRUST [REVERSE IDLER, rear] 32285N 32283-H9700 WASHER-THRUST REVERSE IDLER [front] 32224 WASHER-THRUST COUNTER SHAFT FRONT SELECT USE 32224-H7200 T=2.30-2.35 32224-H7201 T=2.35-2.40 32224-H7202 T=2.40-2.45 32224-H7203 T=2.45-2.50 32224-H7204 T=2.50-2.55 32224-H7205 T=2.55-2.60 32224-H7206 T=2.25-2.30 32224-H7207 T=2.20-2.25
Seals
Front Cover O-ring
32112M 32112-H7300 RING-O FRONT COVER
Front Cover Seal
Front Cover Oil Seal for Aichi R4W60L/W60 4-speed, W60L/W60A 5-speed, RS5W60R 5-speed
Nissan 32114-Y4000 * A12/A14/A15,KA20DE/KA24E/KA24DE,TD23/TD25/TD27,NA20 * RD28,RB20,L18/LD20/L20,H20,Z18/Z20,VG20/VG30,FJ20,CA18 * 60-series, 71-series 71B/71C
Specs * shaft size: 30 mm * bore size: 45 mm * seal outer diameter: 45.2 mm * seal width: 8 mm * Polyacrylate or Nitrile
RockAuto TCM 30X45X 10TC-BX National 1981 Timken 1981 Fits: * Nissan 32113-Y4000, 32114-20100, 32114-Y4000 * 8942152200 * 8943270620, 8943270621, 8943348450, 8943895931 * 9004310029, 9004311141, 9031130010, 9031130014 * 9031130115, 94215220, 94327062 * Ford EBTZ7052D * Toyota W55 transmission * Isuzu 8943270620 camshaft seal
Output Shaft
32136-18000 45mm![]()
32136-G1001 60mm
32150-H7300 C2136-H8900 > 32136-H8900 $10.00 USD C2136-H5000 > 32136-H5000 OIL SEAL-REAR EXTENSION [4-speed & 5-speed 60-series] $23.87 USD * 56A,60A,60L * Nitrile Seal, Counter-Clockwise-Spiral Design * Shaft Size: 1.181" * Housing Bore: 1.772" * Seal Width: 0.591" * Seal Outside Dia: 1.78" * Flange Outer Diameter=2.441" (?)![]()
32160- many EXTENSION ASSY-REAR
Factory Service Manual says:If rear extension bushing is worn or cracked, replace it as an assembly of bushing and rear extension
