Datsun 1200s were equipped with an easy-to-use scissor-type jack. It shipped in the boot (sedan and coupe) or attached to the passenger's seat (truck and van).
Sedan & Truck jacks differ only by the diagram (sticker) on the jack.
Cautions
CAUTIONS (Details: See owner's manual)
- Use this jack on this vehicle only.
- Set parking brake firmly and set automatic transmission in "P", manual transmission in First or Reverse.
- Use #wheel chocks or blocks to fix other wheels.
- Place jack at #jack-up points only.
- Never jack up more than necessary.
- Never get beneath vehicle when it i supported by jack.
- Never use blocks on or under jack.
- Park on hard level surface.
⑤
Jack-up Points
1972 USA Owners manual (Page 27 ... 27):
There are four jack-up points at the floor panel
1974 B120 Owner's Manual (Page 25 ... )
Jack-up Points
You can jack-up the 1200 at these points
Using OEM jack (see Owners Manual above):
- under rocker panel front notch
- under rocker panel rear notch
- truck/wagon: rear body jack point
Be sure to use a Nissan /Toyota/Subaru jack with a "slot" to fit over the rocker panel seam. Jack here, at the point of the the half-round indents:
Using other jacks:
- Under lower A-arm (Transverse link), near tire
- Middle of engine crossmember (lift entire front end)
- center of Differential (lift entire rear of car)
- Outboard ends of rear axle housing
CAUTION: Before sliding underneath the car, be sure to place jackstands under the suspension. In a pinch a tree stump or beefy timber can work. Make certain it is secure, and lower the weight of the car on the jackstands.
Also useful when removing/reinstalling transmission
Standard Equipment
- Scissor Jack
- S-shaped Jack Handle
- Wheel Wrench in black 'Nissan' tool bag
- Tire retaining clamp (sedan and coupe)
Tools
1200 Factory Tool Kit was option and the contents vary by year and region.
See #Part Numbers section below also see #Alternative Datsun Jacks
Jack Location
The Jack and its equipment is stored in special place.
Coupe
Sedan
The Jack and its equipment is stored in the Trunk (Boot). Sedan uses a hold-down clamp, while Coupe uses a fixed bracket (the opposite of usage for B10).
Truck
The ute Jack is stored POST under front of passenger's seat.
1974 B120 Owner's Manual (Page 24 ... 24)
The tools and jack components are stored in the storage compartment as shown. The tool bag is stowed under the assist seat.
![25791.jpg](http://datsun1200.com/uploads/photos/25791.jpg)
Mounts similar to this VB310 jack:
Sunny_Truck jack handle features tabs going other way truck | sedan/coupe
Wagon
Wagon jack fits in front of passenger seat.
120Y wagon VB210 jack mount in engine bay
Sunny van VB310 jack
Datsun B10
Upgrades
Roller Jack Handle
Nissan jack handle with built-in rollers (no more pinched hands!). Source one from a more luxurious Datsun or Nissan. I got mine from a 1985 S12.
Wheel Stops
From B310 and many other Datsuns:
- 99595-H7400 TIRE STOPPER
ジヤッキ、パンタグラフ タイパ゚ ハンドル、ジヤッキ クランク
Part Codes: 99610, 99611
- 99550-H1000 SET-JACK B110 $74.14
- 99553-H1400 HANDLE-JACK CRANK VB110P, B120 [right-angle]
- looks similar to 99552-D0100 U11
- 99551-G1400 JACK-PANTOGRAPH TYPE B120
- 99595-18000 BAG-TOOL $3.89
Others
- 99504-50Y00 bag-tool $4.14
- 99501-01A00 tool kit-complete with jack $118.12
- 99552-01G00 rod-jack D22 [straight] $17.25
- 99553-01W00 Handle Jack 280ZX [crank] $9.33
- 02996-01100 handle-jack 310/810 [with plastic roll surfaces] $19.33
- 99595-H7400 tire stopper 810 [non-folding]
- 99595-U1400 tire stopper 280ZX [folding type] $24.30 [99595-F2700]
- 99545-8B400 Wrench-wheel Nut & jack handle Frontier $32.88
99596 oil filter wrench bag 99547 oil filter wrench 99548 oil filter wrench handle 99540 spark plug wrench
99512-25660 HAMMER 99509-Z0000
Datsun 910
99545 wrench 02995-45200 WRENCH-WHEEL NUT 99610 jack 02996-10421 JACK-PANTOGRAPH TYPE sedan [groove type a la B110] 02996-01631 JACK-PANTOGRAPH TYPE wagon [finger type]
99595 wheel stop 99595-H7400 sedan [fixed type] (2) 99595-U1400 wagon [folding type] (1) * 99595-F2700
99596 Tool bag 02995-95300 BAG-TOOL
99614 jack handle 02996-01100 HANDLE-JACK LEVER 910 sedan
99613 jack handle, 2-piece 02996-03200 ROD-JACK HANDLE wagon 99612 jack crank 02996-02100 HANDLE-JACK HANDle wagon
99501-89903 TOOL SET-STANDARD Includes: * 99545 wrench * 99596 tool bag
U11
995 TOOL KIT 99501 TOOL SET-STANDARD 99596 bag 99535 phillips driver 99545 lug wrench 99525 pliers 99507 spanner 99507 spanner
02995-07100 spanner 8x10 99507-01A00 02995-07300 spanner 12x14 99512-01A00
02995-25100 PLIER 99525-01A00
02995-30300 SCREWDRIVER/DRIVER-PLUS & MINUS [phillips + regular] 99530-50Y00 $6.12 USD * S13, R50 USA
620 Pickup: rotary type for heavy loads
521 pickup handle
Long & Short handle (long one is for pickup)
1970-1976 S30 Tool Kit
1977-1978 S30 Tool Kit
280ZX Tool Kit
ジャッキ
