Trunk
(Redirected from Boot)
Category: Body
Datsun 1200 sedans have a regular trunk (boot) at the rear of the car. Coupes, being fastbacks but not hatchbacks, have a teensy-weensy trunk lid at the back. The sedan trunk is very roomy for a car this size, and can hold about eight grocery bags, or luggage for five people. The lids are secured with a key lock.
3049.jpgAlbum 3049 20398.jpgAlbum 20398
In sedans, the Fuel tank is inside the trunk, next to the rear Seat, hidden behind a finisher panel.
Standard Equipment
The trunk came factory equipped with:
  • Scissor Jack
  • S-shaped Jack Handle
  • Wheel Wrench in black Bag
  • Spare Tyre
For more details, see: Jack
Locks
Main: Locks
Sedan
Boot Lid
13610.jpgAlbum 13610
84300-H1000 ASSY-TRUNK LID SEDAN B110/PB110
All parts are same B110 & PB110 — lock, lid, hinges, jack equipment, mat, etc. — except for the finisher board.
with optional chrome #Handle
174_68b4d11eb557a.jpgPost 499034 174_68b4d14d9c69b.jpgPost 499034
rear corners have drain holes
174_68b4d15757b75.jpgPost 499034
Lock
174_68b4d18a165cb.jpgPost 499034 174_68b4d182035a5.jpgPost 499034
Holds the rear trim badge and the rear model badge
174_68b4d147ab0dc.jpgPost 499034 174_68b4d13a5c91d.jpgPost 499034
Parts
174_68b4d19d6b9f4.jpgPost 499034
Bumper
80833-78500 RUBBER-BUMPER (2) SEDAN
84830-H1000 RUBBER-bumper (1971 catalog)
28126.jpgAlbum 28126
diameter 14mm (at widest part)
height 16mm (cylindrical portion, not counting the tab)
28125.jpgAlbum 28125
Handle
Option: trunk lid trim "handle" (cosmetic finisher) is 44cm long
8610.jpgAlbum click to view
P5140816_1.jpg 174_68b4d11eb557a.jpgPost 499034
Handle is fastened with 3 screws
Also used on PB110
197106-2x.jpg 27062.jpgAlbum 27062 25551.jpgAlbum 25551
Per the catalog, is not specific to any specific trim
25551.jpgAlbum 25551 25552.jpgAlbum 25552
84820-H1000 HANDLE-TRUNK SEDAN
84821-H1000 WASHER-TRUNK LID HANDLE SEDAN
84832-H1000 SPACER-TRUNK LID SEDAN (*)
08310-50812 SCREW (3)
08915-13510 WASHER (3)
* 1971 catalog shows small piece and specifies 3 spacers
1973 catalog (for same part number) shows one large spacer
27063.jpgAlbum 27063 8610.jpgAlbum 8610
トランク モール
Finishing Panels
The trunk finishing panels are made out of pressboard:
3236.jpgAlbum 3236 3237.jpgAlbum 3237
5295.jpgAlbum 5295
Panel hides the fuel tank and fuel lines
4930.jpgAlbum 4930
84910-H1000 FINISHER-trunk room (head board) <> 84910-H2800
84910-H1900 FINISH-TRUNK ROOM T=2.5 SEDAN USA
84910-H2800 FINISHER-trunk room B110 (from C/#B110-174795), 1972, PB110 S-DX
84910-H2900 FINISHER-trunk room PB110 S-GL,S-GX
H19 VS H10 differs slightly in the region of the fuel filler hose cutout.
Hinges
17796.jpgAlbum 17796
84520-H1001 HINGE-TRUNK LID RH SEDAN
84521-H1001 HINGE-TRUNK LID LH SEDAN
29906.jpgAlbum 29906 29907.jpgAlbum 29907
Coupe
Coupe has a small trunk lid.
14161.jpgAlbum 14161 7034.jpgAlbum 7034
84300-H1800 ASSY-TRUNK LID COUPE B110/PB110
29904.jpgAlbum 29904 29905.jpgAlbum 29905 23470.jpgAlbum 23470
558.gifAlbum 558
Coupe boot lid has a stylish ridge down the centre
21414.jpgAlbum 21414
Of course, you can always fill the boot with speakers
7388.jpgAlbum 7388
Fitting
The 1200 coupe has interior plastic covers inside — lots 'o plastic. There is plastic on the bottom side of the trunk lid too.
174_57932af0f2961.jpgPost 480061 23469.jpgAlbum 23469
The lid finisher also covers the lid hinges
30534.jpgAlbum 30534 30535.jpgAlbum 30535
Left and Right side panels are covered by stylish plastic
30537.jpgAlbum 30537 30538.jpgAlbum 30538
Without the finisher panels, showing floor support brackets and jack bracket
30536.jpgAlbum 30536
Trunk Lid Finish panel
84911-H1800 FINISH-TRUNK LID T=1.5
84905-H1800 STOPPER-TRIM TRUNK FLOOR
23358.jpgAlbum 23358 23359.jpgAlbum 23359 23357.jpgAlbum 23357
Rear Floor
  • 08510-51612 SCREW-TAPPING M5 FIX TRIM (16)
  • 08963-20540 NUT-SPRING TYPE A M5 FIX TRIM (16)
  • 08915-43510 WASHER-PLAIN M5 FIX TRIM (16)
  • 84902-H2500 TRIM-TRUNK FLOOR CENTER
  • 84902-H7100 TRIM-TRUNK FLOOR CENTER (BLUE,LB-211
  • 84902-H7101 TRIM-TRUNK FLOOR CENTER (BEIGE,LH-20
  • 84902-H7102 TRIM-TRUNK FLOOR CENTER (BLACK,LG-13
  • 84902-H1800 TRIM-TRUNK FLOOR CENTER
Rear Side
  • 01553-00291 CLIP-TRIM (14)
  • 66919-H1099 CLIP-TRIM (15)
  • 84921-H1800 FINISH-TRUNK SIDE RH T=1.5
  • 84921-H1900 FINISH-TRUNK SIDE RH T=2
  • 84921-H2500 FINISH-TRUNK SIDE RH T=1,5
  • 84922-H1800 FINISH-TRUNK SIDE LH T=1.5
  • 84922-H2500 FINISH-TRUNK SIDE LH T=1.5
23364.jpgAlbum 23364 23365.jpgAlbum 23365 23363.jpgAlbum 23363
Rear
  • 01553-00291 CLAMP (24)
  • 84931-H1800 FINISH-TRUNK REAR T=2
  • 84931-H1801 FINISH-TRUNK REAR T=2
  • 84931-H2501 FINISH-TRUNK REAR T=2
23360.jpgAlbum 23360 23361.jpgAlbum 23361 23362.jpgAlbum 23362
Floor trim panels are fastened by the typical B110 sheet screws (B210 changed to bolts/machine screws).
Plastic Panel Fasteners
  • 01553-00291 CLAMP/CLIP
    • superseded 66919-H1001 CLIP-TRIM
23356.jpgAlbum 23356
76983-68400 LOCK-MALE
76982-68400 ASSY-LOCK FEMALE
08410-41210 SCREW-TAPPING
08915-43410 WASHER-PLAIN
08915-13410 WASHER-LOCK
84932-H1800 MASK-REAR LAMP T=2
84932-H2500 MASK-REAR LAMP T=2
84941-H1800 COVER-TRUNK LID HINGE
84939-H1800 WELT-TRUNK FINISH
Carpet
17794.jpgAlbum 17794 17795.jpgAlbum 17795 17796.jpgAlbum 17796 2879.jpgAlbum 2879 2884.jpgAlbum 2884
Floor Fitting
  • 32021-35000 PLUG-INSPECTION HOLE 55D USA
  • 74891-H2500 ASSY-COVER INSPECTION HOLE
  • 08510-61212 SCREW (6)
23366.jpgAlbum 23366 23367.jpgAlbum 23367
Truck
See also: Jack
Weatherstrip
84810-H1001 WEATHERSTRIP-TRUNK LID Sedan $53.73 USD
* superseded 84810-H1800 WEAHERSTRIP-TRUNK LID Coupe
378 mm long - Sedan
Boot (trunk) seal is same material as 510. Possibly 510 part will fit with trimming for length.
84806-A4600 Weatherstrip 510 $60.75 USD
510 Trunk Weather Strip 84810-21001
Trunk Opener
B210 had an option of electric trunk opener. Possibly could be retrofitted to 1200?
FRP
1200 boot lid, 4.5kg, $220 AUD
13888.jpgAlbum 13888 13688.jpgAlbum 13688 13687.jpgAlbum 13687 13889.jpgAlbum 13889 13890.jpgAlbum 13890
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Trunk"
This page has been accessed 36,512 times. This page was last modified 23:19, 31 August 2025. Content is available under Datsun 1200 Club.
