Clutch
Revision as of 02:53, 20 July 2008; view current revision
Category: Clutch
Disc
  • SIZE ID: 13/16
  • SIZE OD: 7 1/8
  • TEETH: 18T
Service Specifications:
  • Deflection limit: 0.5 mm at 85 mm radius
  • Height Diagphragm spring end: 29-31 mm at 62 mm diameter
  • Facing depth to rivets: 0.3 mm or better
Clutch Release Bearing (release bearing, throwout bearing)
  • Bore = 1.5748
  • Outer Diameter = 2.8898
  • Width = 0.752
Throwout Bearing
Mechanical Clutch (RHD)
  1. Withdrawal lever
  2. Return spring
  3. Release bearing
IMPORTANT Grease these locations:
Hydraulic Clutch (LHD)
See Hydraulic clutch
Bearing Sleeve
For use with A12 Flywheel on A14 engine, use the longer Sleeve:
Or make your own longer sleeve:
Or just use the A14/A15 flywheel. People like the A12 flywheel because it is lighter, but you can lighten the A14 type.
Discussion: Clutch Problems
Pilot Bushing
Dimensions:
  • O.D.: 0.671"
  • Width: 0.723"
  • Bore: 0.48"
Interchange: All A-series engines
  • 1971 - 1973 B110
  • 1974 - 1978 B210
  • 1979 - 1982 B310
  • 1976 - 1978 F10
  • 1979 - 1981 N10
  • Nissan 32202-18000
  • Timkin PB22 $0.90
  • Timkin PB21 $1.57
  • Dorman 14678 $5.99
  • Dorman 690051
  • BCA/NATIONAL Part # PB21 $5.53
Adjustment
  • Cable clutch: as follows
<Hey you Aussies, help by expanding this! How exactly do you adjust a Datsun 1200 cable clutch?>
On transmission: 3-4 mm play. Inside: pad height (139.5-143.5 mm from floor). Then check pedal free play -- it must have free play to avoid burning out the clutch -- check with fingertips). Pedal play is 11-15mm
Details are in the Datsun 1200 Factory Service Manual or any Repair manual (Gregory's, etc).
http://www.rockauto.com
Clutch Kit (Clutch Pressure Plate & Driven Disc)
  • 180mm Diameter (7-1/8" Diameter); 18 Splines, 13/16"
  • BECK/ARNLEY 0619114 $78.89
  • ACDELCO 381622,88989662, 88989662 $83.79
  • RHINO PAC 06001
Nissan
  • 1974 PRESSURE PLATE A13, 694 pounds (315KG)
  • 30100-H5000 DISC. 18cm diameter
  • 30210-H5220 420KG (926 lbs) NISMO HIGH-PERFORMANCE PRESSURE PLATE for A12, A12A
  • 30210-A1200 550KG (1213 lbs) NISMO HIGH-PERFORMANCE PRESSURE PLATE for A14, A15
Centerforce
  • CF420507 for A14
  • Ball Bearing Bore=1.5748" Outer Diameter=2.8898" Width=0.752"
  • BCA 01576 $21.89
  • TIMKEN DNB01576C
Pilot Bushing
  • Bushing O.D.=0.671" Width=0.723" Bore=0.48"
  • BCA/NATIONAL PB21 $5.53
Clutch Alignment Tool (wood, plastic or metal)
  • O.D. 13/16", 18 Splines
  • DORMAN 14502 $2.58
RHD Clutch Cable
  • 30670-H1001 CABLE ASS'Y-clutch operating B110
  • 30670-H5001 CABLE ASS'Y-clutch operating B210 all
    • 63-series transmission JDM used hydraulic clutch
  • 30670-H8500 -7909 B310 [bracket, no nut]
  • 30670-H8510 7909- B310, 8110- Van
  • 30670-G1600 7510-8304 B120
  • 30670-G1601 8305-8910 B120
  • 30670-G1500 8910- B120
Suppliers
