Timing Cover
Revision as of 03:10, 2 July 2011; view current revision
Category: Engine Mechanical
The Timing Cover is the aluminum part on the front of the engine that covers the Timing Chain. It also has a timing mark on the cover and houses the crankshaft pulley seal.
Depending on the country, 1971 or 1973 saw newer timing covers which differ from earlier covers.
Water pump bolts to the timing cover. And the cover bolts to the front of the block, and passes water through two ports (the square hole, and the round hole).
The same covers are used by A10, A12, A12A, A13, A14 and A15, except for the first type:
  1. original Datsun 1000 timing cover, for single-row timing chain
    • 13035-18000 ASSY-COVER TIMING CHAIN
  2. to June 1970, with single timing mark (pulley has multiple marks)
    • 13035-18001 ASSY-COVER TIMING CHAIN [updated to fit Double timing chain & pressure tensioner
  3. from June 1970, with multiple timing marks (pulley has single mark)
    • 13035-H1000 (or from second source: 13035-H1010) [Fits all A10 blocks]
Interchange is same for same. The last two will interchange if the complete set of pulley & cover is used.
Gasket
  • FEL-PRO Part # TCS24531
  • BECK/ARNLEY Part # 0380071 RockAuto.com
Seal
See Crankshaft Seal
Corrosion
Tach Drive
Race engines sometimes use a mechanical tachometer drive off the camshaft, with the Timing Cover modified to suit.
Customized
Tachometer drive
Access cover for adjustable timing gear
