Datsun 1200 uses a traditional type of flywheel at the back of the engine. The face matches the Clutch while a ring gear is attached to the perimeter for the Starting Motor to turn the engine. It uses a 271mm (10.7 inch) flywheel with a 105-tooth ring gear.
All flywheels for A-series engines interchange -- for rear-wheel drive vehicles. The A12 flywheel weighs 2.2 lbs (1 kg) less is the main difference. The A12 flywheel is also thinner.
- A12 12310-H1000: 9.7 kg (21.0 pounds as measured)
- A12 12310-H2310: 6.4 kg (14.1 pounds) GX, also sold as 'Race Option'
- A14 12310-H7200: 10.7 kg (22.3 lbs)
A14/A15 flywheel is thicker than the A10/A12 flywheel. When fitting the thinner flywheel to A14, remove the Engine Plate to compensate.
- A12: 28 mm thick
- A14: 30 mm thick
In 1974 flywheel bolts changed from British Threads to Metric threads. So the bolts are not interchangeable from early to late. See Crankshaft for details.
A12 Flywheel Measurements:
thickness: 28mm ring gear + backing: 20mm back rim to flywheel face depth: 5mm clutch face to inner face depth: 17mm
[http://datsun1200.com/modules/myalbum/photo.php?lid=11151
Lightening
For race cars, a light flywheel allows the engine to rev faster according to this principle:
The more weight, the more time it takes to accelerate
Now a street car wants a heavier flywheel, so that it will:
- smooth out the combustion pulses
- smooth out the drivetrain
These are the factory specs for flywheel weight reduction:
Finished wheight is about 6.5 kgs --a total of 2 kgs removal
Reference: Datsun B110 Competition Tune-Up Manual, Nissan Motor Co. Ltd., Tokyo Japan 1974
- 12310-18001 ASS'Y-FLYWHEEL B10
- 12310-18002 ASS'Y-FLYWHEEL B10 (from E/# A10-87871)
- 12310-H1000 FLYWHEEL ASS'Y A12, A12S, A12A, A13S
- 12310-H6200 ASSY-FLYWHEEL A13
- 12310-H7200 FLYWHEEL ASS'Y A14 -7909
- 12310-H7201 FLYWHEEL ASS'Y A14 7910-8010
- 12310-H8900 FLYWHEEL ASS'Y V A14S, A15 8011-
- 12310-H8910 FLYWHEEL ASS'Y A14S, A15 8011-
- 12315-18001 BOLT-flywheel & drive plate (from E/# 87871) (6) B10
- 12314-18002 WASHER-flywheel
- replaced 12315-18000 BOLT-flywheel & drive plate (6) B10
- 12314-18001 WASHER-flywheel
- 12315-H1001 BOLT-flywheel (6, 3/8") B110 -1973
- 12315-H6200 BOLT-FLYWHEEL (6, 10mm) 1974-
- 12313-10600 DOWEL (3) all A-series A10-A15
- 12312-18000 GEAR-ring, flywheel A10/A12/A14
- 12312-18010 GEAR-ring, flywheel A14S 8110-
- 32202-18000 BUSHING-pilot all A-series A10/A12/A13/A14/A15/A12A
The flywheel "Assembly" includes these parts: * 12312 GEAR-ring, flywheel * 12313 DOWEL-flywheel
- ATP ZA543 Flywheel Ring Gear $22.79
- http://www.rockauto.com/catalog/x,carcode,1208483,parttype,5360
- Outer Diameter=10.655"
- Inner Diameter 9.451"
- Pitch=10/12 Width=.400"
- Teeth=105
- Chamfer=FRONT #1231218000
