R31 Rear Disc Brake Swap
Revision as of 10:57, 4 November 2012; view current revision
R31 Australia
You can add rear disc brakes to H145 with a Australia-built R31 Skyline/Pintara setup. It will also fit H150. Fits over 13" steel wheels.
Click each photo to read the comments and find more detail.
Use a brake proportioning valve to set the balance. These are large rear brakes.
Modified caliper bracket to fit H145
Holes re-drilled for H145 housing pattern
click
Fitted the calipers facing forward as you can then run the cables back and loop around and utilise the existing hand brake bracket and cabling on the diff.
click
click
13997.jpg 12864.jpg 15465.jpg 15577.jpg 18579.jpg 18681.jpg 18682.jpg 18684.jpg 18821.jpg 19018.jpg 19022.jpg 19236.jpg 19237.jpg 19249.jpg 19250.jpg 19251.jpg 21725.jpg
Can you also fit them to H165? Mockups:
