Timing Cover
Revision as of 05:29, 30 March 2014; view current revision
Category: Engine Mechanical
The Timing Cover is the aluminum part on the front of the engine that covers the Timing Chain. It also has a timing mark on the cover and houses the crankshaft pulley seal.
Depending on the country, 1971 or 1973 saw newer timing covers which differ from earlier covers.
Water pump bolts to the timing cover. And the cover bolts to the front of the block, and passes water through two ports (the square hole, and the round hole).
Matched Set
Japan got this change in June 1970. North America: all A-series engines from 1972 including 1973 A12.
Early Set
Multiple-mark Crankshaft Pulley
Single-mark Timing Cover
Late Set
Single-mark Crankshaft Pulley
Multiple-mark Timing Cover
The same covers are used by A10, A12, A12A, A13, A14 and A15, except for the first type:
  1. original Datsun 1000 timing cover, for single-row timing chain
    • 13035-18000 ASSY-COVER TIMING CHAIN
  2. to June 1970, with single timing mark (pulley has multiple marks)
    • 13035-18001 ASSY-COVER TIMING CHAIN [updated to fit Double timing chain & pressure tensioner
  3. from June 1970, with multiple timing marks (pulley has single mark)
    • 13035-H1000 (or from second source: 13035-H1010) [Fits all A10 blocks]
Interchange is same for same. The last two will interchange if the complete set of pulley & cover is used.
Gasket
  • FEL-PRO Part # TCS24531
  • BECK/ARNLEY Part # 0380071 RockAuto.com
Seal
See Crankshaft Seal
Corrosion
Tach Drive
Race engines sometimes use a mechanical tachometer drive off the camshaft, with the Timing Cover modified to suit.
See Tach Drive
Customized
Tachometer drive
Access cover for adjustable timing gear
B110 RAW LIST
13035-H1000 ASSY-COVER TIMING CHAIN
13042-18000 SEAL-OIL CRANKSHAFT FRONT
13510-H1000 SEAL-OIL CRANKSHAFT FRONT (NOK)
13083-18001 TENSIONER-CHAIN TENSION SIDE
13084-18000 SUPPORT-TENSIONER TENSION SIDE
08110-62010 BOLT M6 FIXING TENSIONER
11046-73402 DOWEL-WATER PUMP
11023-32200 DOWEL-WATER PUMP
08110-64010 BOLT-HEX
08915-1361A WASHER-LOCK
08915-13610 WASHER-LOCK
13044-18001 GASKET-TIMING CHAIN COVER
th_timing_cover_a.jpg th_timing_cover_b.jpg th_timing_cover_c.jpg th_timing_cover_d.jpg th_timing_cover_e.jpg th_timing_cover_f.jpgth_timing_cover_g.jpg th_timing_cover_h.jpg
