Large 268 mm disc brake rotors from S110 or 280ZX can be adapted to B310 (Sunny/210) or A10 (Stanza/510) struts - and still fit over 13" wheels. Swap developed by Doug Morrisun.
Works with stock master cylinder.
This setup fits over most 13" wheels. Wheels with inside diameter less than 11.7" won't fit.
Rotors: 1980-1983 S110 (Gazelle/Silvia/200SX) Calipers: 1983-1990 Nissan B11/B12 (Sentra/Sunny) Adapter brackets: Morrisun Productions Brake hoses:
As these rotors fit over the hubs, it adds about 13mm to the total track.
B310 hub diameter: ~154 mm S110 rotor inside diameter: ~145 mm
Comparison
Rotor 268mm diameter this swap (solid disc) vs 220mm B310 Sunny A-12 powered 245mm B310 Sunny/210 245mm A10 Stanza JAP 252mm A10 Stanza AUS solid disc 252mm 280ZX vented front disc 250mm S13 Brakes Caliper 48mm single vs 48mm girling anette stock B310 A12-powered 51mm girling anette stock B310 A14-powered
Pads D275/D233 108mm vs D41/D104 58mm stock 1200
B310 pad![]()
D275/D233 pad![]()
Note: D275 is used by the factory Sunny Truck Disc Brakes, used with 208mm rotors to fit under 12" rims.
Machining
S110 268 mm rotor & caliper requires some machining. But it gains ventilated rotors suitable for racing applications.
Stock hub is too large to fit inside the rotor hat
Machine outer diameter of hub down about 1/4"
Adapter
Buy or fabricate caliper adapter bracket to fit the 130mm bolt-spacing caliper to the 75mm bolt-spacing struts.
Adapts the B12 Caliper to the B310 strut.
Parts
Rotors
The 268 mm rotors (NISSAN 43206-P6500/43206-R4800) are from the rear of:
USA 1979-1981 S130 "Datsun 280ZX" rear 1979-1981 S110 "Datsun 200SX" rear 1981 910 "Datsun 810" rear (except gasoline wagon)
JAPAN 1979 910 "Datsun Bluebird" October to December 1981-1982 C31 "Nissan Laurel" upper models
Only $16 from Rockauto.com * Centric 12142014 * Bendix PRT1181 * Beck/Arnley 0831750 * Raybestos 9225R * Wagner BD97313
280ZX USA catalog (Turbo or Non-turbo. 2+2 or Coupe) * 268 mm <-- this one * 43206-P6500 ROTOR-DISC BRAKE,REAR 0778-0881 (1979-1981 Model year) ** superceded 43206-R4800 0778-0881 * 258 mm <-- NOT this one * 43206-N9501 ROTOR-DISC BRAKE,REAR 0981- (1982-1983 Model year)
Rotor Specs
268 mm * 268 mm Diameter (10.565 inch) * Overall Height: 68.5 mm * Thickness (nominal): 9.6 mm * Thickness (minimum): 8.6 mm * Hub Reg: 68 mm * Bolt size: M12x1.25 (10.75 mm diameter) * Bolt circle: 4 on 4.5" (114.3 mm) * Weight: 5kg (11 pounds)
Calipers
Nissan calipers 41001-05A90 (right) and 41011-05A90 (left)
Uses type D275 brake pads
The calipers are from:
AUSTRALIA DB293 * ??? 1982-1991 M10 Prairie wagon * ??? 1981-1986 B11 Sunny (NZ) * ??? 1983-1987 N12 Pulsar * ??? 1987-1991 N13 EXA * ??? 1989-1994 G20 S-Cargo van EUROPE * B11 Sunny * B12 Sunny * N12 Cherry * N13 Sunny JAPAN * B11 Sunny * B12 Sunny * G20 S-Cargo * M10 Prairie S5 * N12 Pulsar * N13 Langley USA * 1982-1990 Nissan B11/B12 (Sentra/Sunny) * 1983-1990 Nissan Pulsar N12/N13
Wreckers are full of these, but re-manufactured are only $21 each. Make sure you get the brackets with the calipers.
NOTE: These are Japan-built models all (Tokico, etc), so Australia PBR-equipped are not the same.
B110: caliper cylinder 1.894" KN13: caliper cylinder 1.893" (48mm)
KN13 USA Catalog CA <-- Not this * 41001-02Y00 0887-0989 CA18D * 41001-58A01 0986-0887 CA16D This <-- * 41001-05A90 GA15, E16 ** superceded 41001-61A01 *** superceded 41001-62A01 * 1982-1988 B11 * 1986-1989 B12 * 1988-1989 KN13 except CA engines * 1983-1985 N13 RockAuto (1990 Pulsar NX SOHC Type) * BECK/ARNLEY 0770371S Left * BECK/ARNLEY 0770372S Right * Centric 14142048 Left * Centric 14242047 Right
Caliper Specs
Takes pad FMSI type D275/D233 130mm caliper bolt spacing
Brake Hoses
The calipers require banjo-type hoses. Many different hoses can be used. If you are buying new hoses, we recommend these common Nissan hoses:
1989-1994 Nissan S13/S14 "240SX" RockAuto.com $5 each
Additionally, this set allows the choice of running calipers either in Leading or Trailing positions. Switching position is sometime done with extreme lowering. This is done by switching struts from side to side for mounting calipers in Leading position.
Lug Studs
Since the rotors fit over the hubs, they add about 1/4" to the mounting face of the wheels. So you *may* need slightly longer Wheel Studs, which are common from a wreckers or buy them new.
See 280ZX_Brake_Upgrade#Lug_Studs
