Rubber parts
Revision as of 06:47, 29 May 2015; view current revision
Category: Body
Datsun 1200 weatherstripping, pedal pads, door seals, window seals
Body Panels
Fender/gaurd/wing to body.
Pedals
Pedals: rubber part numbers
* Pedal Stopper
* Brake pedal cover - manual
* Brake pedal cover - automatic
* Clutch pedal cover
Clutch
See main article: Clutch#Rubber_Parts
Engine Seals
Also see: Engine Gasket Kit
Crankshaft front seal
Rear Main Seal
Oil pan front & rear seals
Gearshift
See main article: Transmission Gear Control
Interior shift boot (large)
Transmission shifter seal boot (small)
Leaf Springs
See Leaf_Springs#Bushings
Windscreen
See main article: Windshield#Rubber_Seals
Windscreen (windshield/front window)
Side
Side Welts cover the edges of the door frame, also known as the "pinchweld". 2-doors also have a side window frame that is covered by a welt. Generic welt (pinchweld edge trim) can be used , you will need a welt style that is 8mm high x 5mm wide and about 2.7 meters per (ute or 4-door front) door, and a little more for 2-door models. It is usually about $4 a meter on eBay.
generic aftermarket can be used for both Welts.
Same generic welt is used by B110, B210 and B310.
Also see factory 1200 part numbers:
Side Window frame: See Side Window Welt
Door frame: See Interior Side Trim Part Numbers
Doors
Door bump stop
Door Ventilator (quarter glass)
Door Glass Rubber
Door weatherstripping
ドア ウェザー ストリップ ドア インサイド モール
Rear Doors
Wagon (Van)
82242-H1400 WEATHERSTRIP-rear door partition (2)
Sedan 4-dr
82242-H1000 WEATHERSTRIP-rear door partition (2)
Bonnet
See main article: Hood#Small_Parts
Rear Hood Seal
Bonnet (hood) bump stops
Bonnet Core Support Rubber
Bonnet Hinge Seals
Wagon Hatch
90891-H1400 WEATHERSTRIP-back door
Trunk
See main article: Trunk#Weatherstrip
Suppliers
Note that 1200 fans around the world purchase new seals from Scott's mail order.
Worldwide
  • Nissan dealer has many rubber parts still available
  • Scott's Old Auto Rubber
  • eBay (quality from great to poor, check the ratings)
Australia
Canada
New Zealand
  • NZ - Para Rubber bulb seal for quarter windows
United States
  • Trim Lok "Trim Seal" I use the largest tube (3/4",19mm) mounted in the "A" position. This is the same trim used around the door openings of the 1200. Good for the 2-dr sedan pop-out windows.
  • California: Too Intense Restoration often has genuine Nissan seals.
Discussion
discussion in main forum
