Instruments and Controls
Revision as of 06:13, 8 July 2007; view current revision
Category: Body
1972 USA Owners manual (starting page 8):
Dashboard
Various dashes were used. Check your owner's manual for particulars of your model.
Comparo
See the main article: Dashboard
Gauges
Tachometer
See Tachometer
Clock
See Clock
Fuel Gauge
10.jpg 1972 USA Owners manual
The position of the pointer will vary slightly during acceleration, braking and when the car is going up or down a hill.
Also see: Fuel tank
Indicator/Warning Lights
10.jpg 11.jpg 1972 USA Owners manual
  • Ignition Warning Light
  • Oil Pressure Warning Light
  • Headlight Beam Indicator Light
  • Brake System Warning Light
  • Turn Signal Indicator Lights
Also see: Wiring
Water Temperature Gauge
If the pointer stays on the "H" side for more than two minutes, stop the vehicle and let the engine cool down, keeping it at 1,000 to 1,500 rpm.
By "H" they mean out of the large middle range (way over to right-side -- the H area).
Also see: Thermostat
Switches
Also see: Wiring
Heat Glass Switch
Optional equipment.
13.jpg 1972 USA Owners manual
Horn
Just press the button to sound the horn.
Also see: Wiring
Ignition Switch
See Keys
Light Switches
Light switch operation differs between Australia models and other markets. Turn Signal operation (T/S) is the same?
12.jpg 1972 USA Owners manual
...first of two positions, parking lights, taillights, license plate lights and instrument panel lights are turned on.
Also see: Wiring
Wiper and Washer Switch
To operate the washer, turn clockwise and hold the knob for a moment, or until there is enough fluid on the glass to wash off the dirt. Do not operate the washer for more than thirty seconds continuously.
Also see: Wiring
Glovebox
Hot tip: replace the cardboard box with a plastic unit from an early B210.
Latchless door style
RHD glove boxes
LHD with latch
Hinge detail. If often wears away the box material. The B210 unit will fix this.
1972 USA tire inflation sticker and key sticker
Parking Brake Lever
If the ignition switch is on when the parking brake lever is applied, the brake warning light will glow.
