Transverse Link
Revision as of 02:09, 18 November 2015; view current revision
Category: Front Axle And Front Suspension
Sometimes called a "lower control arm" (LCA), the transverse link is the lower suspension member. The Tension Rod (castor rod) bolts to it, as do the Ball Joints. The inner end of the LCA bolts to the front Crossmember.
Also see Front_Suspension
The inner end of the LCA bolts to the front Crossmember:
Swaybar link bolts to the LCA
post
B310 and late 1200 LCA are identical
With B310 Ball Joints, the B310 Knuckle Arm fits, which will bolt to most Datsun-Nissan struts such as Stanza, 280ZX, etc.
Bushings: Stock vs Poly comparo
Racing
Racing heim joints on LCA
Custom LCA
Upgrading
Late 1200 vs Early 1200
Later utes used the H85 LCA, *same as B310*. This started in 1975 October.
B310/A10
B310 (Sunny/210) LCA and A10 (Violet/Stanza) LCA are the same. Also same as late (1976 and up) 1200 and 120Y. They can be swapped with earlier B110 if used as a set (LCA + Balljoint + Tension Rod).
See discussion Negative Camber
Stanza balljoints increase the track ~32mm -- too far to be registered in ACT.
per side
+8mm strut/hub offset
+8mm ball joint offset
Some say it increases track ~50 mm.
See Ball Joint Comparison
B310 vs B110 lower arms
As for the lower arms, they are indeed the same length. With the exception of the diameter of the bolts which hold the ball joint to them ...they are the same. However the [B]310 arms are made of a slightly heavier construction, so it would be a toss up between strength verses weight, when chosing which arms to use.
Utes ... use the bigger bolts like the [B]310's.
A14force
Backfire said the ball joint bolt pattern is smaller in B110 vs B310.
late ute ball joints (left) to stanza ball joints
Both fit late 1200 or Stanza/B310 LCAs. Depending on how much track you want.
The Stanza/B310 ball joint uses a larger diameter taper than B110.
Nissan Competition
10MM longer for increased negative camber
See Racing_Suspension_System#B310
NOTE: All parts are identical for 1971-1973 models (including sedan, coupe, wagon and truck).
  • 54110-H1060 Transverse link ass'y R.H (formerly H1000)
  • 54111-H1060 Transverse link ass'y L.H (formerly H1000)
  • 54131-H1000 tranverse link bushing $10.83 USD
These parts also fits 1973-1975 B210 w/A12 engine.
Early LCA uses these for Ball Joints:
40160-H1000 BALL JOINT ASS'Y-lower
fastening ball joint to knuckle arm
 08911-44210 NUT
fastening ball joint to LCA
 40178-H1000 BOLT "A" (2)
 40179-H1000 BOLT "B" (6)
 08911-60810 NUT (6)
 08915-13810 WASHER-lock (8)
1974-up B120 Truck
54100-H8500 ARM ASSY-LOWER RH 7712-8503
 superceded 54100-H7400* ARM ASSY-LOWER RH 7510-7711
54110-W5851 ARM ASSY-LOWER RH 8504-
54101-H8500 ARM ASSY-LOWER RH 7712-85037510-7711
 superseded 54101-H7400* ARM ASSY-LOWER LH
54111-W5851 ARM ASSY-LOWER RH 8504-
Late LCA uses this ball joint:
40160-H7400 JOINT ASSY-BALL LOWER (2) 7510-
 40177-H7400 NUT
 54480A outer tension rod bolt
  40178-H7400 BOLT 7510- (2)
 54480B inner tension rod bolt
  40179-H7400 BOLT 7510-7711 (4)
  40179-W5000 BOLT 7712- (4)
  08915-13810 WASHER
  08911-10810 NUT
 40160B outer ball joint bolts
  40179-H7400 BOLT 7510-7711 (2)
  40179-W5000 BOLT 7712- (2)
  08915-14010 WASHER
  08911-64010 NUT
B210 JAPAN
54100-H1060 LINK ASS'Y-transverse with bushing (R.H.)
54101-H1060 LINK ASS'Y-transverse with bushing (L.H.)
40160-H1000 BALL JOINT ASS'Y-lower, front suspension
 08911-42210 NUT [castle]
 40178-H1000 BOLT (2)
 40179-H1000 BOLT (6)
 08911-60810 NUT (6)
 08915-13810 WASHER-lock (6)
B211 A12S + A14 (from 75-12) + B210 VAN (from 75-10)
54100-H7400 LINK ASS'Y-transverse with bushing (R.H.) -7711
54101-H7400 LINK ASS'Y-transverse with bushing (L.H.) -7711
54101-H8500 ARM ASSY-LOWER LH 7712-
40160-H7400 BALL JOINT ASS'Y-lower, front suspension
 40177-H7400 NUT [castle]
 40178-H7400 BOLT (2)
 40179-H7400 BOLT (6)
 08911-60410 NUT (8)
 08915-14010 WASHER-lock (8)
B310 JAPAN
54529
54100-H8500 ARM ASSY-LOWER RH B310
54530
54101-H8500 ARM ASSY-LOWER LH B310
B310 use one LCA, but two different ball joints. The parts catalog is ambiguous on usage.
40160-H7400 JOINT ASSY-BALL LOWER RH [short type]
 S,K A12S,A13S
 Van
40160-W5000 JOINT ASSY-BALL LOWER RH [long type]
 S,K.A14,A15
 Wagon [W=Sunny California from introduction Jan 1979-]
 40177-W5000 NUT [castle]
40179-W5000 BOLT (4 OR 6)
08911-60410 NUT (8)
A10 Japan
54101-H8500 LH 7712-
54111-W5000 LH -7711 <> 54101-H8500
54100-H8500 RH 7712-
54110-W5000 RH -7711 <> 54101-H8500
B210 USA (HB210) - same as JDM PB210 (L-series engine)
40160-U7000 ASSY-BALL JOINT,LOWER 0775-
 superseded 40160-A8600 ASSY-BALL JOINT,LOWER -0675
40179-A8600 NUT-HEX SLOTTED M14
54499-H7600 COMP-LINK,TRANSVERSE RH 0177-
 superseded 54499-U0102 COMP-LINK,TRANSVERSE RH -1276
54500-H7600 COMP-LINK,TRANSVERSE LH 0177-
 superseded 54500-U0102 COMP-LINK,TRANSVERSE LH -1276
54535-A0801 ASSY-BUSH,TRANSVERSE LINK
08130-82065 BOLT-HEX WITH WASHER M8X1.25 (4) 0875-
 supersed 08130-32065 BOLT-HEX WITH WASHER M8 (4) -0775
08134-04510 BOLT-HEX M10 (4)
08912-44010 NUT-HEX M10 (4)
B310 USA
Ball Joint
H74 CAN B310
W50 USA B310
Castle nut is listed as same for both.
Uses three LCA, including the late B120 Part number. All use same ball joint & bushing
54110-W5801 LINK ASSY-TRANSVERSE RH FED,CAN
54110-W5000 LINK ASSY-TRANSVERSE RH CAL -0878
54110-H8500 LINK ASSY-TRANSVERSE RH CAL 0978-
54111-W5801 LINK ASSY-TRANSVERSE LH FED,CAN
54111-W5000 LINK ASSY-TRANSVERSE LH CAL -0878
54111-H8500 LINK ASSY-TRANSVERSE LH CAL 0978-
40160-H7400 JOINT ASSY-BALL SUSPENSION, LOWER CAN,A12
40160-W5000 JOINT ASSY-BALL SUSPENSION, LOWER
 40177-W5000 NUT-SLOTTED HEX
 40178-H7400 BOLT-FIX BALL JOINT [transverse link inner] (2)
 40179-W5000 BOLT-HEX(BALL JOINT C) (6)
 08915-14010 WASHER-SPRING LOCK(M10) (8)
 08911-64010 NUT-HEX HEAVY(M10 X 1.25) (8)
All B210,B120 and B310 use the same LCA bushing as B110 (except USA B210 and PB210).
B10
Datsun 910 & R31 LCAs
