A remote-mounted Hydraulic clutch Master cylinder may also be needed if there is not enough room in the engine compartment.
Mount the clutch master under the dash, and connect it to the gearbox slave cylinder via a hydraulic line.
- Fabricate L-shaped bracket, bolt (or weld) to the under-dash steering column brace
- Lengthen clutch pedal, attach the master rod ABOVE the fulcrum
- Place the filler tube under the dash, connect to master via rubber hose
Girling
Under-dash mounted Girling clay pipe master
Girling "claypipe" master cylinder, available in 5/8" and 3/4" bores (about $70 AUD). Threads are 3/8 unc for pipe outlet and 7/16 unc for fluid in
Urvan
https://en.wikipedia.org/wiki/Nissan_Caravan
- Use with Nissan Urvan remote-fill tops
- A simple 90-degree bracket is fabricated to mount it to the under-dash steering column brace
Sentra
https://en.wikipedia.org/wiki/Nissan_Sentra
Nissan Sentra Clutch Master Cylinder
Fluid reservoir is connected to the cylinder via a rubber hose.
Lancer
https://en.wikipedia.org/wiki/Mitsubishi_Lancer_(A70)
For ideas, could something like this be used on a 1200?
Cable-to-Hydraulic custom remote clutch m/c found on Mitsubishi LA Lancer
