Datsun 1200 grilles vary between Coupe and Sedan. The Sedans used a stainless steel grille, while Coupes used a sporty plastic type. Wagons and early utes used the sedan grille, while newer utes use a coupe-like plastic grille. In Japan, the sedan grilles change for 1972.
#Stainless Grille: Sedan, Wagon & 1971-1978 ute
#Facelift Grille (1972 Sedan)
#Coupe Grille (black headlight surrounds)
#1978-1989 Ute Grille (silver headlight surrounds)
#Late Sunny Truck Grille (1989-2007)
Stainless Grille
See main article: Sedan Grille
Sedan grille "D" and "S" emblems
Late JDM intricate "S" grille emblem
Plastic Grilles
1. Silver headlamp surrounds (mid-model ute) 2. Black headlamp surrounds (coupe GX) 3. With Silver center strip (coupe non-GX)
Black headlight surrounds: (coupe)album
Silver headlight surrounds: Mid Pickup (1978-1989)full
Emblems: Rectangular for pickup, Round for coupe
Coupe Grille
Coupe grille always has black headlight surrounds. Silver surround are for mid-model ute.
Black headlamp surrounds * All black paint * Silver center outline + silver center bar * Silver center outline (GX)
62302-H1800 (exc. GX) Silver oval with Silver across the middle:
62302-H2400 GX - black center bar
1972 Facelift GX - same as pre-facelift except the emblem:
GX-5 Coupe grille winged 'S' emblem
South Africa GX (uses non-GX grille)
Clone GX (using non-GX grille)
GX Coupe
full
Sunny Truck Grille
Early Truck
1971-1977 Sunny Truck, ute and bakkie used the stainless Sedan Grille.
Mid-Model Truck
1978-up Ute. This grille looks nearly identical to the Coupe grille:
- Silver headlight surrounds (coupe has black surrounds)
- Rectangular center emblem (Coupe is round)
- Emblem screws have horizontal arrangement (Coupe is diagonal)
Coupe emblem - screws arranged diagonally
Pickup emblem - screws arranged (nearly) horizontally
To fit a Plastic grille to an early ute or sedan, add these tabs:
Square Headlight Truck
See main article: Square Light Grille
JDM - From October 1989 Bakkie (B140)
Facelift Grille
For 1972, Japan-model 1200s received a minor facelift.
Coupe
Coupe continued to use the original grille.
Sedan
See main article: Sedan Grille#1972_Minor_Facelift
Customized Grilles
Coupe-grille with custom insert
![th_D24072E4-2A90-459A-B283-0524CDAE5C9B-2750-0000029234EC224E.jpg](http://i1117.photobucket.com/albums/k595/brentshane/th_D24072E4-2A90-459A-B283-0524CDAE5C9B-2750-0000029234EC224E.jpg)
![th_D7822A8C-D64F-42CF-9EAA-5F02EE2BF7FF-2750-00000291C170DCDC.jpg](http://i1117.photobucket.com/albums/k595/brentshane/th_D7822A8C-D64F-42CF-9EAA-5F02EE2BF7FF-2750-00000291C170DCDC.jpg)
![th_3bcf07cd.jpg](http://i1117.photobucket.com/albums/k595/brentshane/th_3bcf07cd.jpg)
Datrotor: Made up my own mirror finish stainless grill that deffenetly is a 1off.every single bolt that isn't hi tensile has been mirror polished finish and is all stainless
Blackout Grille
Square Eye Retrofit
Late Sunny Truck retro-fit on Coupe
Billet
GDM Style
Mounting
Each grile type has unique mounting variation.
A plastic grill will not bolt in place of a sedan grille and vice-versa.
Ditto for round vs square headlight grilles.
The four Datsun 1200 grille types and their mount points
See:
- Sedan Grille Mounting
- Coupe Grille Mounting
- Coupe Grille in Sedan: add the missing brackets.
- Sedan Grille in late Sunny Truck
- Coupe Grille in late Sunny Truck
- For a late Sunny Truck with square headlights, you also need to fit round headlights. See Converting
Dimensions
Coupe/Mid-ute/Late-ute
- 123 x 22 x 10 cm box
Sedan/Early-ute
PB110
PB110 Sunny Excellent Grille
full
keywords: グリル
