Turbo Inlet Manifolds
Revision as of 03:54, 17 May 2016; view current revision
Category: Forced Induction
Intake manifolds for a Turbo engine. For more airflow, a higher flowing carb, intake, heads (ports and valves) and exhaust system is beneficial. Supercharging will increase power on a stock engine, but increasing the airflow capability of the engine will bring your blown engine to its full potential
Stock manifold with carburetor hat
21572.jpg See #Boxed Carburetor
661.jpg Tuned-port Intake
4862.jpg Log manifold
Log Manifold
301.JPG UM-1 Manifold
Ram plenum manifold
clyon's A-series Turbo Manifolds
This kind of stock manifold-runner is limited in horsepower. The turbo can force more air through it (for more HP) but the air temp will escalate, limiting the power to be made.
Tuned Runner Length
For scavenge effect at 5000 RPM, the runners should be 20" long!
Optimum runner length vs RPM
Stock Manifold
Blow-through systems can use the stock Intake Manifold.
Stock manifold with EFI throttle body
post
Blow-through system feeding carb top-hat
This was a popular OEM method. phunkdotaspok say the stock Hitachi can handle 10 psi with a good top-gasket seal. In an NA application, a warped top is not a problem, as there is no pressure in the float chamber. This only becomes important in boosted application.
Boxing carb. This allows a more or less stock carb to be used, the outsided pressure balancing the inside pressure
535.jpg Inside the box
downdraft Dellorto carburetor
Weber DGV hat
datto1000wagon
16585.jpg 16584.jpg 16583.jpg 16582.jpg 16563.jpg 16562.jpg 16561.jpg 16560.jpg
