Many different Datsun alternators and alternators from other makes can easily be fitted to the Datsun 1200. If you are running high-power headlights, off-road lighting systems, or high-power stereo gear, using a high output alternator is called for. Or, if you need to replace the 1200 alternator and have free or inexpensive access to different alternators, you might consider a swap. Lastly you might have a bad Voltage regulator, and by swapping to an internally-regulated alternator reliability increases since these use a solid-state (no moving parts) regulator.
There are two major considerations in a swap:
- Physical swap. How does it bolt to the A12 engine?
- Electrical swap. How will the new alternator be connected to the wiring?
Early A engine (1966-1973) has limited room for alternator. It is mounted low, under manifolds, on left side of engine. The larger 50A alternator will bolt to the bracket, but the alternator rubs against the lower radiator hose. It could be made to work, but is not recommended.
Physical Specifications
Alternator Comparison & swap info
Stock Hitachi LT-135 35A
- Weight: 8.4 pounds with pulley
- Front flange (bolt ears): 13mm thick
- Distance between engine-side mounting ears: 80mm
- Distance between Adjustment bolt and mount bolt: 156mm
- 10.5mm diameter mount holes
- Diameter of body: 114mm (4.5")
- Fan belt center: 29mm from front bolt face
- Pulley diameter: 69mm
- Adjustment bolt: Flange threaded for M8x1.25 bolt
Electrical Connector
Datsun 1200 uses the typical 1970s Hitachi T-shaped connector:
- F: Field
- N: Neutral point
Other alternators use different connectors. Since the LT-135 uses spade connectors, wiring should be pretty simple.
Hitachi LT-150
High amperage Hitachi LT looks like it will bolt right in place of stock LT-135 -- but on a B110 the alternator rubs against the lower radiator hose. It could be made to work, but is not recommended.
On later A12 it bolts right in place of the 35A unit, though a slightly larger fan belt is needed.
- 9.6 pounds: Bosch AL237X 50A 1974-1978
- 60AMP Hitachi LT-160 (Bosch #AL241X)
- CHEVROLET LUV PICKUP (1981 - 1982)
- ISUZU PICKUP (1981 - 1986)
- ISUZU PICKUP NORMAL CAB 1987
- ISUZU TROOPER (1984 - 1985)
- DATSUN 200SX 1977
- DATSUN 610 (1974 - 1976)
- DATSUN 710 (1975 - 1977)
- DATSUN B210 (1975 - 1977)
- DATSUN F10 (1976 - 1978)
- Fits same as Bosch #AL241X 60AMP
240Z
45A - looks very similar to B110 unit * Same black plastic brush cover grille * Bigger around * Datsun 240Z
Internal Regulator Alternator
Sunny Truck
Nissan 23100-B9810 (Mitsubishi A1T22971/Hitachi LR135), 35A internally regulated is a direct physical replacement for the original (small) B110 alternator. It even will use the same fan pulley belt. It is wired differently however (see Hitachi LR Alternator Wiring).
Nissan 23100-B8910
Mitsubishi Electric Corporation A1T22971
12V 35A 1X23
LS wiring (see Hitachi LR Alternator Wiring)
CAUTION: T-connector is LS wired, not FN wired
Also see Alternator Part Numbers
keywords: dynamo, generator, ダイナモ
Hitachi LR
Newer Datsuns from about 1978 came with an alternator with internal-regulator, the LR150/LR160, including fitment on newer A-series engines.
See main article: Hitachi LR Alternator
Bosch E65
Bosch E65-1003 from 1980s Ford/Holden/Toyota
Basically it puts out max of 70-85amps (depends which u get), instead of 35 amps, good for BIG stereo, BIG driving lights or injection setups
70-85A Bosch internally-regulated 1988-1991 Ford Falcon EA * a bit of grinding away * the wiring needs to be changed * Fan belt different size
mounting diagram (Early Engines - left side)
Late engines with cast-iron engine bracket needs 13mm ground off the rear of the bracket.
Adjustment Hole (mm) M10x1.25 Pivot Hole (mm) 10xM10x1.25 Adjustment to Pivot 187mm Inside Feet To Feet 67mm (stock: 80) Pulley 70mm No Of Grooves 1A Plug RP93
RP93 connector AUSTRALIA * 1988-2002 Holden Commodore * 1988-1991 Ford Falcon EA * 1994-2000 Ford Transit heavy duty * 1991-1997 Toyota Lexcen * 1991-1996 Mitusbishi Magna * 1989-1993 Nissan Skyline
More Swaps
Chrysler alternator upgrade on Yahoo! Clubs Datsun 210 - photos
unknown "bolt-in" 70A internally-regulated alternator
