Turbo Inlet Manifolds
Revision as of 00:05, 19 August 2016; view current revision
Category: Forced Induction
Intake manifolds for a Turbo engine. For more airflow, a higher flowing carb, intake, heads (ports and valves) and exhaust system is beneficial. Supercharging will increase power on a stock engine, but increasing the airflow capability of the engine will bring your blown engine to its full potential.
A15 Turbo using factory Twin Hitachi sidedraft manifold
17526.jpgAlbum click to view
#Top-hatted Carburetor on stock manifold
10474.jpgAlbum 10474
#Boxed Carburetor
2253.jpgAlbum 2253
#Log Manifolds
4862.jpgAlbum 4862
#Tuned-port Intake
661.jpgAlbum 661
Stock Manifold
Blow-through or draw-through systems can use the stock Intake Manifold.
Draw-through
Blow-through with carburetor hat
526.jpgAlbum 526
Stock manifold with EFI throttle body
6746_551625dbea3e4.jpgPost 465360
Blow-through
Log Manifolds
A log manifold is a cylindrical plenum type with individual runners to each cylinder. Log manifolds can either be fed by an EFI throttle body or by a sidedraft carburetor. They can be used with either blow-through or draw-through systems.
Log Manifold
20267.jpgAlbum click to view 20268.jpgAlbum click to view 20269.jpgAlbum click to view
UM-1 Manifold
301.JPGAlbum 301
Ram plenum manifold
652.jpgAlbum click to view 653.jpgAlbum click to view 654.jpgAlbum click to view
clyon's A-series Turbo Manifolds
7952_51415765a064e.jpgPost 432220 7952_514157d6a5905.jpgPost 432220 7952_5156836ba4deb.jpgPost 432220
This kind of stock manifold-runner is limited in horsepower. The turbo can force more air through it (for more HP) but the air temp will escalate, limiting the power to be made.
21086.jpgAlbum 21086
Corolla manifold adapted
Draw-through with very small plenum
Tuned Runner Length
For scavenge effect at 5000 RPM, the runners should be 20" long!
23939.jpgAlbum 23939
Optimum runner length vs RPM
intakerunnerlength.jpgPost click for topic
Feeding the carburetor via a top hat was a popular OEM method. phunkdotaspok say the stock Hitachi can handle 10 psi with a good top-gasket seal. In an NA application, a warped top is not a problem, as there is no pressure in the float chamber. This only becomes important in boosted application.
Blow-through system feeding carb top-hat
519.jpgAlbum click to view
Weber 32/36 Carburetor with custom top hat
21572.jpgAlbum 21572 21573.jpgAlbum 21573
downdraft Dellorto carburetor on custom manifold
21056.jpgAlbum 21056
Weber 32/36 Carburetor hat
22271.jpgAlbum 22271
Good for 10psi
13860.jpgAlbum 13860
3496.jpgAlbum 3496
Twin Sidedraughts
Blow-through
Boxed Carburetor
Blow through works well. The main reason to use this over a draw-through is so an intercooler can be used. The boxed carburetor can take more boost than the top-hatted carburetor.
Boxing the carb allows a more or less stock carb to be used, the outside pressure balancing the inside pressure. Special non-crushable fuel floats are needed.
2249.jpgAlbum 2249 2253.jpgAlbum 2253 535.jpgAlbum 535
