The stock rear brakes are fairly good, using large (for such a light car) 8" x 1.75 brake shoes. Make sure the brakes are clean and adjusted correctly every 3 months. Using a performance pad will improve it. But for coolness sake... read on.
R31 Australia
You can fit the Australian-built R31 Pintara/Skyline disc brakes onto H145/H150 or H165 axle assemblies.
![10076_4cf2acdd6c123.jpg](http://datsun1200.com/uploads/newbb/10076_4cf2acdd6c123.jpg)
R32
Pigdog adapted R32 calipers
300ZX rotors turned down to 290mm, 4-lug pattern drilled
Z31 300ZX 5-lug * 280 x 26 mm height 54 DBA 907 * 282 x 20 mm height 57.5 Rear * -8509 290 x 10mm height 47 DBA 605 * 8510- 280 x 18mm height DBA 927 * Turbo: all years use 927 part
Z32 300ZX * 280 x 30 mm height 54 DBA 909 * 292 x 18 mm height 64 DBA 908
H145
Pitroad Kit
Pitroad rear disc adapters for B110
- Uses late model S130 (280ZX) caliper and rotor (I think it says it uses Skyline HR30 adapters)
44155-N3202 machined with: * 4 new holes for the H145 pattern * an insert for the smaller diameter axle tube interface
Andy: The Pitroad rear disk brake kit only includes the brackets, E-brake cables, axle sleeve thingys, clips, rubber brake hoses, and axle bolts. You supply the calipers, pads, and rotors from an 82-83 280ZX, as well as new oil seals for the axles, wheel bearings, etc. It's pretty straight forward, you have to pull off the old drum brake assemblies and put on their new bracket just before you put the new wheel bearings in. You do have to drill two really small holes on the E brake cable holder, but other than that it's really easy.
In general, 1982 280ZX and 300ZX has a smaller rear caliper with larger pads than the early (1979-1981) 280ZX. The offset of the early vs. late caliper is quite different.
AE86
To fit AE86 calipers on B110 rear axle housing, create an adapter.
U12
Australia U12 Pintara 1989-1992 rear discs Same as 280ZX Brake Upgrade discs, but 45 mm height instead of 47 mm DBA 614 * Vent Solid * Diameter 258 * Height 45 * Thickness 10 * Centre Hole Dia 68
quik1000's rear caliper mounts are a bolt on for either H145 or H165 axles. Uses R31 Skyline Girlock calipers.
S13 AUS/USA 43206-35F00 rear rotors may also fit
* 1 mm thinner * 1.5 mm higher
H165
Sentra Rotor Adaption
3rotor designed bracket for box-shape Sentra (Nissan B12) 240mm rotor. The same bracket can also fit Maxima 250mm rotor.
The rotors slip over the hub (floating type). The pattern must be re-drilled to 4 x 4.5" (4 x 114.3 mm) before it will slip on. Center hole probably needs enlarging.
Rockauto.com Nissan 40206-61A11 BREMBO 08493210 Centric 121.42031 Solid floating type Diameter 240.3 mm Height 45.1 mm Nom. Thick 12 mm Hub Reg 11 61 mm Bolt circle: 4 x 100 mm Weight 9.5 lbs
Moar Piccies! See 3rotor's gallery
Factory Disc Adapters
Fits H165 and H190 rear axle assemblies, like the 1200 Ute axle assembly.
Disc Over Drum
"Disc Over Drum" -- easy conversion for H165 or H190 diffs! Fits over 14" wheels. Rotor approximately 280mm. Find an Australia-built Bluebird with rear discs and swap the brakes over to the H165.
910
910 Sedan (810/Maxima/Bluebird) use a conversion plate to bolt a rotor to drum-brake-spec hub.
Narrow Pattern
44155-N3202 ADAPTER-CALIPER 44165 $72 USD * yoke type/double piston (wide bolt pattern) * USA 910 1981 (0780-0681) sedan Datsun 810/Maxima IRS * JPN F30 8009-8208 L28E Leopard/TR-X 8009-8107 L20E# Stock Use: 44151 BAFFLE-PLATE 44151-U7800 0780-0681 44001 CALIPER ASSY-REAR RH,W/O PADS OR SHIMS [or yoke] 44001-F5490 0780-0681 <2> 44001-W1390 240Z use: use early 280ZX caliper & rotor 1200 use: same as 240Z?
Wide Pattern
Use the same install method as the Pitroad adapters (above). The Pitroad units appear to be 44155-N3202 machined with 4 new holes for the H145 pattern, and an insert for the smaller diameter axle tube interface.
44155-04S10 ADAPTER-CALIPER 44165 * single piston type (narrow bolt pattern) * USA 910 1982-1984 (0781-) sedan 810/Maxima * JPN C31 8111- GX#+K.L20.MD Laurel * JPN F30 8108- L20E# * JPN R30 8108-8108 L20ET Skyline Stock Use: 44151 BAFFLE-PLATE 44151-04S10 0781-0683 <> 44151-04S70 44151-04S60 0783- 44151-04S70 44001 CALIPER ASSY-REAR RH,W/O PADS OR SHIMS 44001-04S90 0781- <2> D4001-04S90
240Z use: use late 280ZX caliper & rotor
1200 use: 1982-1983 280ZX (Late ZX) caliper & Rotor
Compare various methods of use: Z Home
1985-88 Maxima (Bluebird) FWD bracket, the ID of the opening is different, and the offset is different. Machining needed, see HybridZ
Rear Axle Swaps
See Rear Axle Swaps
These include rear disc brakes:
- Complete rear end off a Toyoda with disk brakes (Corolla AE86)
- Complete rear end from a Mazda RX7 GSL-SE
- Complete rear end from a 1980 to 1981 S110 (Silvia, 200SX) H165
- Complete rear end from a 1982 to 1983 S110 H190
200SX either narrow the housing or use fender flares.
Toyoda...cheaper LSD from TRD.
Mad Dat Kit
Mad Dat sells a narrowed Nissan rear axle assembly with disc brakes. Shortened R31 28 spline unit (looks like an Aussie R31 BW78 unit).
