Grille
Revision as of 05:43, 14 September 2016; view current revision
Category: Body
Datsun 1200 grilles vary between Coupe and Sedan. The Sedans used a stainless steel grille, while Coupes used a sporty plastic type. Wagons and early utes used the sedan grille, while newer utes use a coupe-like plastic grille. In Japan, the sedan grilles change for 1972.
#Stainless Grille: Sedan, Wagon & 1971-1978 ute
#Facelift Grille (1972 Sedan)
#Coupe Grille (black headlight surrounds)
#1978-1989 Ute Grille (silver headlight surrounds)
#Late Sunny Truck Grille (1989-2007)
#Sunny Excellent Grille
Stainless Grille
See main article: Sedan Grille
Sedan grille "D" and "S" emblems
Late JDM intricate "S" grille emblem
Plastic Grilles
1. Silver headlamp surrounds (#mid-model ute)
2. Black headlamp surrounds (coupe GX)
3. With Silver center strip (coupe non-GX)
Black headlight surrounds: (coupe)
Silver headlight surrounds: Mid #Pickup (1978-1989)
 full
Emblems: Rectangular for pickup, Round for coupe
Coupe Grille
See Main Article: Coupe_grille
Sunny Truck Grille
Early Truck
1971-1977 Sunny Truck, ute and bakkie used the stainless Sedan Grille.
Mid-Model Truck
1978-up Ute. This grille looks nearly identical to the Coupe grille:
  • Silver headlight surrounds (coupe has black surrounds)
  • Rectangular center emblem (Coupe is round)
  • Emblem screws have horizontal arrangement (Coupe is diagonal)
Coupe emblem - screws arranged diagonally
Pickup emblem - screws arranged (nearly) horizontally
To fit a Plastic grille to an early ute or sedan, add these tabs:
full
full
full
Square Headlight Truck
See main article: Square Light Grille
From October 1989
* JDM Sunny Truck (late B122)
* South Africa bakkie (B140)
Facelift Grille
For 1972, Japan-model 1200s received a minor facelift.
Coupe
Coupe continued to use the original grille during the 1972 facelift.
1972 Sedan grille fitted to a coupe:
17958.jpgAlbum click to view
Sedan
See main article: Sedan Grille, Facelift
Customized Grilles
Blackout center ornament
24625.jpgAlbum click to view
120Y grille
174_55ea1becdb6be.jpgPost 471955
four-eye
10528.jpgAlbum 10528
Chrome highlights
FRP
Kustom grille
Color Matched
Coupe-grille with custom insert
th_D24072E4-2A90-459A-B283-0524CDAE5C9B-2750-0000029234EC224E.jpg th_D7822A8C-D64F-42CF-9EAA-5F02EE2BF7FF-2750-00000291C170DCDC.jpg th_D24072E4-2A90-459A-B283-0524CDAE5C9B-2750-0000029234EC224E.jpg th_3bcf07cd.jpg
Datrotor: Made up my own mirror finish stainless grill that deffenetly is a 1off.every single bolt that isn't hi tensile has been mirror polished finish and is all stainless
Blackout Grille
Coupe grille painted black
Ute grille painted black
Square Eye Retrofit
See Square Light Grille
square grille
Late Sunny Truck retro-fit on Coupe
Billet
Aluminum Slat
Billet Grille
GDM Style
Mercedes
8584.jpgAlbum 8584
BMW
VW Caddy look (see post for more pics)
174_56d798f9ac013.jpgPost 476836 5668.jpgAlbum 5668
Bimmer E30 datsunb120
fgjfgj435.jpgPost click for topic 103_0143.jpgPost click for topic
Mounting
Each grile type has unique mounting variation.
A plastic grill will not bolt in place of a sedan grille and vice-versa.
Ditto for round vs square headlight grilles.
The four Datsun 1200 grille types and their mount points
See:
  • Sedan Grille Mounting
  • Coupe Grille Mounting
  • Coupe Grille in Sedan: add the missing brackets.
  • Sedan Grille in late Sunny Truck
  • Coupe Grille in late Sunny Truck
    • For a late Sunny Truck with square headlights, you also need to fit round headlights. See Converting
Dimensions
Coupe/Mid-ute/Late-ute
  • 123 x 22 x 10 cm box
Sedan/Early-ute
PB110
PB110 Sunny Excellent Grille
full
full
full
full
PB110 Custom
PB110 sedan retrofitted with chromed B110 Coupe grille. The chrome matches nicely with the PB110 corner lights
full
full
full
full
See main article: Grille Photo Index
keywords: グリル
