Sunny Truck Model Changes
Revision as of 06:02, 9 July 2008; view current revision
Production in Japan ended March 1994. Common equipment includes:
The following equipment was not offered:
  • No Tachometer
  • No automatic transmission offered
  • No 5-speed transmission
  • No A14 (except in South Africa B140 truck)
Chassis ID Numbers
Applied Model code: G16
  • B120T to 7907
  • GB120T to 7907 Long Body (long bed)
  • B121T 7908-8109
  • GB121T 7908-8109 Long Body
  • B122T 8110-
  • GB122T 8110- Long Body
1970-1977
B120
Same as Datsun 1200 Standard trim cars:
  • Black interior
  • H145 rear axle assembly
  • Front Drum brakes
  • Stainless grille (same as sedan/wagon)
  • Standard dash
  • EVAPO Flow Guide Valve (same as USA models)
  • Gray wheels
  • 'Sunny' sedan-style rear quarter badges (to 8102)
    [http://datsun1200.com/modules/myalbum/photo.php?lid=16661 16661.jpg
  • Disc Wheel Caps (dog-dish hubcaps)
  • Silver-trimmed rear tail lights
from 1974:
  • H165 rear axle assembly
1978 - 1988
B120 to 7903, B122 from 7908
  • Aero mirrors
  • Round gauges
  • Dark Brown interior (7804-7907)
  • Brown interior (7908-8110)
  • Hi-back seats (no headrests)
  • B210-style steering wheel
  • Intermittent wiper switch
  • black rubber ends on front bumper
  • from 7804: Coupe-style plastic grille -- but with silver surrounds and rectangular center emblem
  • Black-trimmed rear tail lights
From 7901
  • Silver TOPY wheels
From 7908
  • B122 designation
  • New-style intake manifold bolt pattern (dry manifold)
  • EGR added
  • Disk wheel ornaments (Center wheel caps replacing dog-dish)
from 8103
  • Rear label: "Sunny", "Sunny Long Body" block-style
from 8110
  • emergency signal holder on passenger side kick panel
  • door pocket
  • New-style VIN plate
  • IC alternator (some)
From 8504 "Minor Change"
  • Cold Air duct for air cleaner
  • Hood insulator
  • Exhaust Resonator added
  • Silver Nissan wheels
1989- 1994
B122 from 8910
  • Nissan front emblem
  • Front disk brakes
  • Single-reservoir, tandem master cylinder
  • Brake booster
  • New rear brake design (still using B10 brake drum)
  • Gray interior
  • Rear label: "Nissan"
  • Integrated seat/shoulder belt standard (previously optional)
  • Square headlights
  • Electronic ignition
  • Fuse box with rectangular fuses
  • Wet intake manifold
  • Oxygen Sensor 22690-F5300
    Superceded by 22690-17B00
    Same as Sentra, E16i eng 1984 - 1986
  • Engine Control Module 220604-95W00
  • Catalyst (catalytic convertor). 3-way type.
  • Heated air-cleaner motor
  • Fuel tank with return line
  • Larger muffler and resonator
  • EVAPO Charcoal Cannister replaces Flow Guide valve. Rocker cover has right-angle breather outlet
  • Revised F4W56 transmission with Neutral switch
  • 19T gear up from 18T
  • 1991 engine
Trim Code
For 1989-up
Trim code: K (Gray ???)
Seats are gray edged with white inserts. Black mats with raised dots seem to be common.
Body Color
  • #002 White ????
  • #EH3 Dark Yellow ????????
  • #544 Blue????
  • #BG9 Greenish Blue metallic ????????????????
Options
  • Passing light switch & relay
  • Low horn
  • Clock
  • Package tray
  • Carpet floor
  •  ? heater
  • side visor set
From 7804
  • ELR 3-point seatbelts
  • Cooler (air conditioning)
  • hard ??leafspring
  • hard ? starter
  • Guard frame (rear window bars)
Long Body
The Long Body (LB) has these differences from standard short body (SB):
  • Wheelbase is longer
  • Cargo box (bed) is longer
  • Has two-piece drive shaft with Center Bearing (carrier bearing)
  • Front exahust pipe is longer up to 8909
  • longer exhaust system from 8910
  • no resonator from 8910
Parts
  • 90500-01W00 Back Door Lock Ass'y (tailgate handle) available in USA $27.34
  • 96321-95W00 Inside Mirror $26.43
